90mm F2.8 Tamron Di MACRO 1:1 VC lens, 2016
    • Aperture Range - F2.8 to F32
    • One LD and Two XLD Glass Elements
    • eBAND, BBAR, and Fluorine Coatings
    • USD AF Motor, Full-Time Manual Focus
    • VC Image Stabilization
    • 1:1 Max. Magnification, 11.8" Min. Focus
    • Rounded 9-Blade Diaphragm
    • Moisture-Resistant Construction
    • Nikon, Canon EF and Sony A mounts
    • $649, available at https://www.amazon.com/Tamron-AFF017N700-90mm-2-8-USD/dp/B01C6CTT1K/
  • 16 Replies sorted by
  • PR
    With a heritage spanning over 30 years, the Tamron 90mm Macro lens has a great Legacy, and now with the launch of the new SP 90mm F/2.8 MACRO 1:1 Di VC USD lens the legacy is ready for a new chapter.
    The new 90mm VC USD lens inherits many of the outstanding features of its predecessor, however is now improved with an enhanced VC image stabilization with XY-Shift compensation making handheld shots even easier from infinity to Macro. The near silent USD focusing system has also been improved and fine-tuned to give outstanding speed and control, regardless of whether you are focusing at infinity, or at macro distances where the USD focusing continues to compensate for slight movements common with handholding at short distances.
    The construction of the lens now includes a newly designed all-metallic barrel as part of Tamron’s “New SP” design, with larger switches which are reconfigured for smoother function. Tamron have incorporated a new standard of Moisture-Proof & Dust-Resistant construction that assures even more wide-ranging opportunities for using this lens, plus Tamron’s Fluorine coating which is applied to the front element to help repel water & oil, makes the front element easy to keep clean & condensation free.
    This new 90mm VC USD lens will also be the first Tamron lens incorporating the facility for users to update firmware, customize autofocus positions and adjust the mechanical setup and preferences of the lens by simply attaching it to the optional TAMRON TAP-in Console and connecting it via USB to a personal computer. This TAP-in console will be released in March 2016.
    Date of launch: 25 February 2016
  • Highlights
    Built upon the outstanding optical performance of the legendary Tamron 90mm Macro
    The new 90mm VC USD lens (Model F017) delivers excellent resolving power and remarkably soft background blur effects (bokeh). The advanced construction includes one LD (Low Dispersion) glass element and two XLD (eXtra Low Dispersion) glass elements. These special elements optimally compensate for on-axis and lateral chromatic aberrations from macro through to infinity. Furthermore, the optical design ensures the best imaging performance at any range by adopting the Floating System that shifts the location of a group of elements to the best possible position as the focusing group travels relative to shooting distances. From 1:1, life-size close-ups to the most distant horizon, this new 90mm Macro lens achieves outstanding image quality.
    VC enhanced with shift compensation
    An accelerometer has been integrated into Tamron’s highly accredited VC (Vibration Compensation) to compensate for movement on the x-y plane. In unison with a gyro sensor, the accelerometer detects and enables motion compensation for camera shake, providing maximum efficiency in image stabilization optimized for all distance ranges from infinity to macro.
    USD actuator maximized for macro photography is fast, accurate and quiet
    With improved focusing speed and accuracy, the latest USD (Ultrasonic Silent Drive) focusing system quickly addresses any out-of-focus condition caused by back-and-forth camera movement (which commonly occurs during macro photography) ensuring better results when shooting at close range.
    Moisture-Proof and Dust-Resistant Construction
    Special seals provide stronger protection against the intrusion of dirt, dust and moisture around switches and the boundary between the focus ring and the lens barrel. This latest advance over the Moisture-Resistant Construction used previously, provides additional protection & assures even more wide-ranging opportunities for using this lens.
    A durable Fluorine Coating on the front element repels water and fingerprints
    The Fluorine Coating is a water and oil repellant coating applied to the front element surface making it much easier to keep clean & remove dust & deposits with ease.
    Advanced coating technology reduces flare and ghosting
    Two advanced coating technologies, both providing outstanding anti-reflection performance, are applied to critical element surfaces for maximum light transmission. eBAND (Extended Bandwidth & Angular-Dependency) Coating boasts outstanding anti-reflection performance across nearly the entire range of visible rays, and BBAR (Broad-Band Anti-Reflection) Coating utilizes traditional multi-layered, anti-reflection technology. This combination virtually eliminates extraneous reflections and substantially reduces ghosting and flare which enables the lens to achieve flawless, crystal clear images.
    Use of circular aperture to achieve beautiful, rounded blur effects (bokeh)
    The 9-blade diaphragm retains a nearly perfect circular opening when stopped down by just two stops, creating beautiful circular highlight blur (bokeh) for pinpoints of light in the out of focus background. In combination with the optical design, spectacular background blur effects can be achieved.
    Focusing options perfectly suited to a macro lens
    The new 90mm macro has a focus limiter that makes it possible to shorten the time for accurately focusing on a subject when the working range is known. The lens also features an Internal Focusing system, so the overall length of the lens never changes, not even when focusing. As a result, the user is assured of a comfortable working distance of at least 139 mm (5.5 in.) from the front of the lens. In addition, the lens is equipped with a Full-time Manual Focus override mechanism which makes it possible to flexibly choose focal points. Even with the AF driving system in action, it is possible to instantaneously override it to make manual fine focusing adjustments without switching the AF-MF mode back and forth.
    Compatibility with TAMRON TAP-in Console
    You can update firmware, customize autofocus positions and adjust the mechanical setup and preferences of the 90mm lens by simply attaching it to the TAMRON TAP-in Console and connecting it via USB to a personal computer. (The TAP-in Console is an optional accessory that will be released in March.)
    Digital image editing software optimized for Tamron lenses
    Included in the new 90mm macro package is SILKYPIX Developer Studio, a popular RAW conversion and editing program preloaded with correction menus for various aberrations based on the optical data that pertains exclusively to Tamron’s SP Series lenses. In addition, lens profile information has been supplied to Adobe Systems, Inc. to facilitate selecting the precise lens data required for more sophisticated adjustments in RAW processing when using Adobe Photoshop and Lightroom.
    The new model is the improved version of its older self. Although to be honest, the improvements over its predecessor are not that outstanding to justify a mark-up of 100% in the price.
    Tamron macro lens delivers very good performance: it's very sharp across the full-frame sensor whether at infinity or in 1:1 close-up shots. It has low coma and pretty low longitudinal color aberrations and magenta ghosting.
    http://www.cameralabs.com/reviews/Tamron_SP_90mm_f2-8_Di_VC_USD_Macro/
    800 x 530 - 53K
  • In addition to the more professional looking design, better build quality and improved weather-resistance, this new edition of the Tamron 90mm Macro lens also offers faster auto-focusing, enhanced image stabilisation, and compatibility with the new TAP-in Console, whilst delivering even better image quality than the older version of the lens. The only real optical issue is obvious corner shading at the maximum aperture, something that you can easily remove in post-processing.
    http://www.photographyblog.com/reviews/tamron_sp_90mm_f2_8_di_macro_1_1_vc_usd_f017_review/
    The 10th installment of the iconic Tamron 90mm Macro lens adds a few upgrades that really puts this lens at the top of the category. A faster AF system and improved VC (Vibration Compensation) lead the way in making this redesigned lens even easier to use. The faster and more accurate AF system also combines with a few state-of-the-art lens coatings that go a long way to increase image quality by reducing image flaws that are common with macro shooting. Finally we get to the new look of the all-metallic barrel with new larger switches and typeface. They have even stepped away from the gold ring on the lens, which we also noticed on the SP 15-30mm lens we reviewed earlier this year.
    http://www.steves-digicams.com/camera-reviews/tamron/90mm-f28-di-macro-11-vc-usd/tamron-90mm-f28-di-macro-11-vc-usd-review.html
    800 x 542 - 42K
  • August 18, 2016, Saitama, Japan – Tamron Co., Ltd. (President & CEO: Shiro Ajisaka), a leading manufacturer of optics for diverse applications, announces the launch of the SP 90mm F/2.8 Di MACRO 1:1 USD (Model F017) for Sony mount.
    Date of Launch is August 25, 2016
    The Tamron 90mm ƒ/2.8 Di Macro VC USD SP produces tack-sharp results without much stopping down. On our full-frame body we see excellent results even wide open at ƒ/2.8, with only very light corner softness: stopping down to ƒ/5.6 gets results as sharp as the camera can manage.
    http://www.imaging-resource.com/lenses/tamron/90mm-f2.8-di-macro-1:1-vc-usd-sp-model-f017/review/
    800 x 442 - 59K
