28-105mm F3.5-5.6 ED Pentax FA DC WR Lens
    This new compact, lightweight standard zoom lens provides a focal-length range from wide angle to medium telephoto.
    Despite its compact, highly maneuverable body, this versatile zoom lens is designed to accommodate the image circle of a large 35mm full-frame image sensor, thanks to the adoption of state-of-the-art optics and high-performance optical elements. When mounted on the PENTAX K-1 camera body, it delivers high-resolution imaging power, making it an ideal everyday lens for the new 35mm full-frame digital SLR camera.
    Main Features
    Standard zoom lens covering most frequently used ranges
    This standard zoom lens accommodates the image circle of a 35mm full-frame image sensor, and covers focal lengths between 28mm wide angle and 105mm medium telephoto. By incorporating the latest optics and a number of high-performance optical elements, it retains a sufficient brightness level even at edges of the image field, while effectively compensating for various aberrations. It delivers high-resolution images by optimising the imaging power of the PENTAX K-1’s (approximately) 36.4 effective megapixels. Its compact, lightweight body and excellent cost performance make this lens an ideal regular lens for the PENTAX K-1.
    Excellent image description, complementing the full-frame digital SLR camera performance
    In its 15-element, 11-group optics, this zoom lens incorporates two high-precision aspherical optical elements, one ED (Extra-low Dispersion) glass optical element and one anomalous-dispersion glass optical element, to deliver bright, sharp images with minimal chromatic and spherical aberrations. Since its optics are designed to assure ample resolving power for the large, high-pixel image sensor, it produces well-defined, fine-detailed images.
    HD Coating to improve image description
    This lens is treated with the high-grade, multi-layer HD Coating. Compared with conventional multi-layer coatings, this PENTAX-original coating assures higher light transmittance and less reflection to deliver bright, high-contrast images that are free of flare and ghost images, even under demanding lighting conditions including backlight.
    Quick-Shift Focus System
    This PENTAX-developed system allows for flawless, delay-free switching from autofocus to manual-focus operation, after the subject is captured in focus by the camera’s AF system.
    Weather-resistant construction
    This lens features a dependable weather-resistant construction with eight sealing parts to effectively prevent the intrusion of water into the lens interior. Paired with a weather-resistant PENTAX digital SLR camera body, it creates a durable, dependable digital imaging system that performs superbly in demanding shooting settings — even in rain or mist, or in locations prone to water splashing or spray.
    Other features
    • SP (Super Protect) Coating applied to the front surface of the lens to effectively repel water and grease
    • Rounded diaphragm to produce a smooth, beautiful bokeh (defocus) effect, while minimising the streaking effect of point light sources
    • Built-in DC motor to assure smooth, quiet, high-speed autofocus operation
  • 4 Replies sorted by
    695 x 547 - 49K
    696 x 544 - 53K
    800 x 530 - 49K
