Firmware is now pulled from the site due to some color rendering problem.
And now fixed one is back again at
THAILAND - In the Garden of the Dragon
Available soon from Canon will be an accredited Canon service center installed feature upgrade for the EOS C300 Digital Video Camera that will offer an autofocus mode to help ensure sharp focus and smooth focus transitions. The upgrade provides a new Continuous AF (Autofocus) Function for all Canon EF autofocus Lenses, using Dual Pixel CMOS AF technology. A new AF Lock setting also lets you change the image framing while holding the desired focus. These critical focusing capabilities are designed to help reduce out of focus video while providing for smooth focus transitions and assist users when operating with small crews.
http://www.usa.canon.com/cusa/professional/standard_display/eos_c300_feature_upgrade
Canon U.S.A., Inc., a leader in digital imaging solutions, announced today that its parent company, Canon Inc., will be releasing free firmware1 upgrades for both the Cinema EOS C500 4K and C300 Digital Cinema Cameras, as well as Cinema RAW Development 1.3, an updated version of Canon's Cinema RAW Development software, in November 2014.
Support for ITU-R BT.2020 next-generation broadcast standard color space (for EOS C500 and EOS C500 PL camera models)
Offering compliance with the ITU-R BT.2020 (Rec. 2020) color space employed in the 4K TV broadcasting tests carried out earlier this year in Japan, the firmware upgrade for the EOS C500 and EOS C500 PL camera models facilitates the capture of high-resolution video supporting the color space employed in the ITU-R BT.2020 next-generation broadcast standard. When used in combination2 with Canon's DP-V3010 professional 4K reference display (released in January 2014), the system effectively responds to input and output needs within the realms of next-generation motion-picture production and broadcasting.
Enhanced Cinema RAW Development functionality (for EOS C500 and EOS C500 PL camera models)
The upgraded Cinema RAW Development software features the addition of 3D-LUT for converting from Cinema Gamut/DCI-P3+ to such highly versatile color space standards as ITU-R BT.709 (Rec. 709) and DCI-P3, enabling efficient video editing while maintaining low-chroma color reproduction and high-chroma color gradation. Additionally, support for EDLs (edit decision lists)3 enables only necessary time code-designated segments to be converted to the DPX and ProRes formats suitable for editing, effectively doing away with the need to process unnecessary files. Also, when using a PC equipped with Intel® Iris™ Pro graphics, Cinema RAW Development 1.3 makes it possible for faster development of 4K Cinema RAW data.4
Improved operability when setting color temperature of white balance (for EOS C500 and EOS C300 camera models)
The new firmware upgrades contribute to improved operability by allowing users to easily set color temperature values using the camera's FUNC button.
Firmware Version 2.1.3.1.00 available, it incorporates the following improvements and fixes:
@MikeLinn Doesn't ISO6400 look incredibly noisy in that video? I thought the C300 was good in low light?
New firmware coming
Canon U.S.A., Inc., a leader in digital imaging solutions, today announced firmware updates for both the Canon EOS C300 and EOS C300 Mark II Digital Cinema Cameras being showcased at NAB Show New York 2016, November 9 and 10 at the Jacob K. Javits Center in New York City. These firmware updates support a number of feature updates for users including improvement of accessory support, ease of use, Dual Pixel CMOS AF (DAF) and creative flexibility.
The EOS C300 Digital Cinema Camera (EF-Mount) updates will allow various functions such as support for the WFT-E8 Wireless File Transmitter, Shutter Angle Priority, Grip Zoom Function when using CINE-SERVO 17-120mm EF-mount, CINE-SERVO 50-1000mm EF-Mount and COMPACT SERVO 18-80mm lenses, Auto Iris and Push Iris when using CINE-SERVO 17-120mm EF-mount, CINE-SERVO 50-1000mm EF-Mount and COMPACT SERVO 18-80mm lenses and Peripheral Illumination Correction when using the new EF 24-105mm f/4L IS II USM lens.
The EOS C300 Digital Cinema Camera DAF (EF-Mount) updates will allow various functions such as support for the WFT-E8 Wireless File Transmitter, Shutter Angle Priority, Dual Pixel CMOS AF (DAF) when using CINE-SERVO 17-120mm EF-Mount and COMPACT SERVO 18-80mm lenses, Grip Zoom Function when using CINE-SERVO 17-120mm EF-mount, CINE-SERVO 50-1000mm EF-Mount and COMPACT SERVO 18-80mm lenses, Auto Iris and Push Iris when using CINE-SERVO 17-120mm EF-mount, CINE-SERVO 50-1000mm EF-Mount and COMPACT SERVO 18-80mm lenses and Peripheral Illumination Correction when using the new EF 24-105mm f/4L IS II USM lens.
The EOS C300 Digital Cinema Camera (PL-Mount) updates will allow various functions such as support for the WFT-E8 Wireless File Transmitter and Shutter Angle Priority.
Canon EOS C300 with Dual Pixel AF firmware ver. 2.1.8.1.00 available
Canon EOS C300/EOS C300 PL firmware ver. 1.1.8.1.00 available
Canon Cinema EOS C300 firmware v2.1.9.1.00
- When CN-E70-200mm T4.4 L IS KAS S is attached the following features are enabled:
- Autofocus using the Dual Pixel CMOS AF function
 - The joystick on the camera’s grip unit can be set to operate the zoom.
 - Manual control of the iris with Camera’s Control dial.
 - Control of focus, zoom and iris using the separately-sold Remote Controller RC-V100.
 - Automatic aperture and push auto iris functions.
 - Start/stop recording on the separately-sold lens grip ZSG-C10.
 - Retrieval of Lens metadata, such as the model name and the focal distance will display on the camera.
 - When the camera is turned off the IS mechanical lock will be active regardless of the position of the switch.
 - Adds peripheral illumination correction for the following lenses:
- COMPACT-SERVO Lens
- CN-E70-200mm T4.4 L IS KAS S
 - EF Lens
- EF 70-300mm f/4-5.6 IS II USM
 - EF 16-35mm f/2.8L III USM
 - EF-S 18-55mm f/4-5.6 IS STM
 - EF-S 35mm f/2.8 Macro IS STM
 - EF 85mm f/1.4L IS USM
