I'd love to see 4fps via the e-shutter for time lapses ala Magic Lantern.
Hi All --- I posted this a while ago, but it was in a different topic and I never heard anyone expand upon it until I now, these tests could be of interest...
2fps E-SHUTTER LIMIT
I have been doing some tests using the electronic shutter in the still mode... which I know is not the main focus of the hack... however I have found some very interesting results that might spark the interest in terms of using it to shoot video.
The manual shutter is slow... we know that. However the electronic shutter will shoot 2.3K images at 40fps in SH burst mode, but only for one second before it needs to buffer that info.
I began to wonder... using a modified external controller instead of a shutter release, how many frames could fire through the camera consistently before the camera needs to buffer?
I have come up with some interesting results...
The still's manual shutter, when shooting a full 16 megapixel image will consistently do 1fps on a class 10 card with no buffer. At 2fps it will do 57 frames before skipping three frames to buffer and continue for another 57 frames, then buffer three etc... When you set the camera to burst mode using the H setting, the manual says it can do 4-7fps before "slowing down half way through".
When you lower the size to a 2.3k image (there about, full JPEG 3.8 megapixel) it can take photos at 4fps, no problem, fully buffering as it goes, no lag time (at 6fps it skips frames so we'll say 4fps is its max at 2.3K).
So if the manual shutter can perform at 4or 5fps consistently at 2.3K without slowing, this all makes one think that the electronic shutter could vastly outperform this.
Wrong-- !
The electronic shutter has a built in "cripple limit" at only 2fps!!! Half of what the manual shutter can do with ease!!
This cripple is really disconcerting.. as I feel there is the possibility for the GH2 to perform in the SH burst mode at 24fps (taking single still images) with no buffer on a class 10 or higher card. Seeing how the camera is capable of taking 40 still photos in one second with one second to buffer after... theoretically at 20fps it may have enough time to buffer electronically in between stills and perhaps that could be pushed to 24fps.
So....
I would love to find out, if at all possible, if the 2fps electronic shutter burst mode limit could be removed.
This limit's terminology pretty much states:
"when consecutive (not held down burst) shooting is firing the camera, limit those pulses to only 2 stills per second".
This is of course arbitrary, because the manual shutter will keep trying to take as many stills as it can physically keep up with no matter how many a second.
In an interesting note, at 1fps the e-shutter is fine. At 2fps the e-shutter is fine. At 4fps the e-shutter skips exactly half the pictures (mathematically) and when you send 100 shots to the camera the number taken is only 50. This continues at 6fps, 8fps etc... the total shots taken only ever amount to 2fps which is how I know it is an imposed limit.
With my present set up I would be able to test the camera's ability to take stills at 1/2/4/6/8/12/16 and 24fps and assemble the stills as a movie (standard procedure for animators). If I am correct and the camera can process 2.3K stills in 24 stills per second, we will have uncovered a new 2K imaging device... with the full range of JPEG settings available (not just video mode and bit rates... but still frames like a film camera!) Perhaps even the hack could rewrite the burst mode to take 24fps instead of 40fps and we'd have a built in mode for shooting those stills as frames.
At the very least, if the camera could only produce a max of 18fps (stills per second) or 16fps, before buffering, then there is the possibility that with a simple timing device, the camera could offer multiple frames per second shooting... an option for fast motion, animation, timelapse.
My request is to see if the 2 stills per second electronic shutter "cripple limit" in the SH still mode on the camera could be removed or modified via the firmware. I strongly feel this could be a breakthrough and would love the opportunity to explore and test this possibility.
Thanks,
Dbdaws
 The Personal View video mode!
_gl_gl 11:09AM
lolololo 11:20AM
 velociveloci 11:23AM
lolololo 11:47AM
_gl_gl 12:26PM
lolololo 12:33PM
lolololo 1:10PM
johnnymjohnnym 1:22PM
lolololo 1:37PM
_gl_gl 1:45PM ReportAwesome
lolololo 2:03PM
lolololo 2:25PM
lolololo 4:18PM
_gl_gl 4:27PM
lolololo 4:29PM
lolololo 4:32PM
lolololo 6:25PM
 lolololo 8:42PM
