35mm F1.8 SP Di VC USD Tamron lens
    • Angle of View (diagonal): 63°26' (for full-frame format): 43°29' (for APS-C format)
    • Optical Construction : 10 elements in 9 groups
    • Minimum Object Distance: 0.2m (7.9 in)
    • Maximum Magnification Ratio: 1:2.5
    • Filter Size : 67mm
    • Maximum Diameter : 80.4mm
    • Length: for Canon 80.8mm (3.2 in): for Nikon 78.3mm (3.1 in)
    • Weight: for Canon 480g (16.9 oz): for Nikon 450g (15.9 oz)
    • Aperture Blades: 9 (circular diaphragm**)
    • Minimum Aperture: F16
    • Supplied with Flower-shaped lens hood, Lens caps
    • Canon, Nikon, Sony mounts
    • $599 at http://www.adorama.com/TM3518EOS.html
  • 31 Replies sorted by
  • General PR
    Tamron Co., Ltd. (President & CEO: Morio Ono), a leading manufacturer of optics for diverse applications, announces launch of a new series of SP lenses that are optimized to make the most of the superior imaging performance delivered by the latest advancements in digital photography. Sporting a totally revamped external appearance, the new lenses provide the ultimate in functionality and operation. The first two lenses in the series are compatible with full-frame DSLR cameras and offer fast apertures and versatile, fixed focal lengths. The pair consists of the SP 35mm F1.8 Di VC USD (Model F012) and SP 45mm F1.8 Di VC USD (Model F013), and both can be used with APS-C format cameras as well.
    Background of the SP Series Renovation
    In 1979, Tamron unveiled the first SP Series lens, the 90mm F2.5 Macro, a legendary product that was designed to achieve the highest level of performance possible. Since then, a significant number of lenses designated SP have been introduced. During the ensuing 35 years, cameras and imaging devices have made dramatic advancements and diversification centered mostly around innovations in image sensor technology and sophisticated signal processors.
    Constantly innovating, Tamron developed new lenses to stay abreast of the exciting technological evolution. Lenses launched after 2012, including SP 24-70mm F2.8 VC USD, SP 70-200mm F2.8 VC USD, SP 90mm F2.8 MACRO 1:1 VC USD, SP 15-30mm F2.8 VC USD and SP 150-600mm F5-6.3 VC USD, received rave reviews for their high performance and richly refined functionality to sustain sophisticated requirements of the latest DSLRs with high pixel counts.
    To leap forward, Tamron has gone back to the root of optics to redefine all of the core attributes of lenses to be selected as photographers' “ultimate partners.” The new series of SP lenses are developed seeking the highest level of performance, functionality and maneuverability, and a prestigious external appearance that reconfirms the high quality of the properties that are inside.
    Features of fast-aperture fixed focal lenses: 35mm and 45mm, the first of new SP Series
    To develop these two standard fixed focal lenses, goals were established to provide exquisite characteristics certain to set them distinctively apart from ordinary, conventional models. This required a new approach. All of the key performance criteria were redefined to achieve the ultimate in optical performance. VC (Vibration Compensation) was incorporated as an integral part of the opto-electronics design to expand shooting freedom. Priority was set to allow dramatically closer focusing capability to remove what would otherwise be a barrier to the subject. Yet with all this innovation, the overall mechanical package had to be kept within practical size limits with an elegantly sophisticated external design as a human interface.
    Having optimized every prerequisite, remarkably versatile lenses have been developed that boast amazing performance from F1.8 wide open aperture. These lenses can be enjoyed by users of APS-C cameras as well as full-frame.
    1. F1.8 fast-aperture, fixed focal lenses aimed at ultimate performance Optimal use of the latest glass materials, coupled with Tamron's world renowned optical design technology, thoroughly compensated for aberrations of all types to achieve higher resolving power, while fine textures of materials and details are reproduced with subtle tonal gradations. The F1.8 aperture delivers more light to the viewfinder—making it brighter for easier focusing – and more light to the sensor, allowing use even in very dim lighting conditions. In addition, the bokeh (background blur) effect obtained using the F1.8 fast aperture delivers impressively smooth and soft transition from the main subject to the background.
    2. Dynamic close-focusing capability, unprecedented among standard lenses Both models deliver astonishingly short MOD (Minimum Object Distance) not available from other 35mm or 45mm standard lenses. Photographers can get closer to the subject with ease, unleashing new photo opportunities with an expanded scope of freedom. Superb image capture is ensured throughout the entire range from the closest to normal shooting distances, thanks to Tamron's proprietary Floating System built into both lenses.
    3. VC (Vibration Compensation) system, a feature crucial for high-pixel-density cameras Beneficial under all lighting conditions and especially useful in low light levels, the VC function provides noticeable advantages for handheld shooting by minimizing the adverse effects of camera shake. Cameras with high pixel densities, in particular, are sensitive to minute vibrations which cause unsharpness and degradation of image quality. VC works to ensure the maximum imaging performance even in dim lighting to allow photographers to enjoy the fast F1.8 maximum aperture to the fullest extent.
    4. User-friendly product design with close attention to all details Opening a new chapter in the SP legend, product design, opto-mechanical construction and engineering processes are totally integrated. Every single detail and operating function has been thoroughly reexamined, explored and matured to a form that has a friendly, human touch.
    External Design
    1. Product design with maximum emphasis on the human interface in order to achieve the ultimate in functional beauty
      While the lens is constructed with the absolutely most modern technologies inside, the exterior is articulated to offer the best possible comfort and confidence under a product design philosophy of “Human Touch.” Organically composed lines and patterns on the barrel produce subtle changes in its appearance by reflecting ambient light on the surface. Metal-based barrel materials provide a pleasant feeling of comfort, high quality and durability, fitting firmly in the hands of the photographer. Design of the front face of the lens is also taken into consideration so that it is not intimidating.
    2. Brand ring and SP emblem
      A brand ring that's tinted “Luminous Gold” adorns the lens just above the lens mount. On one side of the lens barrel there is an SP emblem in the same luxurious color.
    3. Design of distance and aperture scales
      The window over the distance scale has been enlarged by 20% to maximize visibility and legibility. Font style of the characters and numbers has been newly developed to enhance the legibility as a critical element of the overall product design.
    4. Switches with optimized geometric shape and tactile feedback
      The geometric shape and sliding torque of the AFMF change-over and VC On/Off switches have been configured and engineered to deliver the utmost comfort with secured operational feedback.
    5. Lens hood and caps
      To complete the lens product design, accessories such as the lens hood and caps for front and rear have been totally redesigned as well. Attaching and removing the lens hood has been fine-tuned by optimizing the connection interface to render both secure seating and durability.
  • 35mm PR
    • 35mm Standard Wide-Angle Lens with VC and World's First 0.2m (7.9”)
    • Minimum Object Distance for Full-Frame DSLR Cameras
    Overview
    • Natural perspective and field-of-view for instinctive image capture.
    • Provides the ideal balance of performance and functionality to deliver unexpected opportunities for creative imaging.
    • A fast, primary standard lens for those who prefer wide-angle shooting.
    • Provides an equivalent focal length of 54mm on APS-C cameras.
    Key Features
    1. Even when used wide open at F1.8 aperture, provides outstanding image quality with maximum aberration compensation, thanks to optimal use of sophisticated glass materials and highly advanced optical design SP 35mm F1.8 Di VC USD (Model F012) is a 10-element, 9-group construction, utilizing two molded glass aspherical elements, one LD (Low Dispersion) and one XLD (eXtra Low Dispersion) element.
      Two of the aspherical elements effectively correct the field curvature to ensure planarity of the image plane, while efficiently compensating for spherical and comatic aberrations to achieve superb uniformity across the field with high-fidelity point spread reproducibility. Outstanding resolution is rendered from corner to corner and the sagittal comatic flare (a type of aberration that a point image at corners induces a comet tail-like blur), which tends to become prominently noticeable in night scenes, is corrected.
      The LD and the higher grade XLD glass elements optimally compensate for chromatic aberrations, which tend to become particularly prominent in fast-aperture lenses in general, and deliver crystal clear images without any residual color fringe.
    2. 35mm focal length with fast F1.8 maximum aperture and integral VC (Vibration Compensation) for full-frame DSLR cameras
      The desirable maximum aperture of F1.8 was chosen as part of the very challenging design goals which included achieving superb optical performance, minimizing the closest shooting distance and integrating VC functionality while packaging those key attributes in a reasonably-sized barrel construction for better practical handling. Repeated performance simulations were conducted throughout the entire design phase to assure achieving the essential, fundamental property of a fast-aperture lens in full-frame format, namely the harmony between excellent resolving power and beautifully-tuned background blur (bokeh).
      The VC feature has become virtually indispensable in the era of high-pixel-density cameras. Freedom in handheld shooting at dusk or in a dimly lit room is dramatically expanded by cancelling the camera shake that often occurs under such low light conditions due to slower shutter speeds. Minute vibrations that plague cameras with high pixel count can be well muted to make the most of the performance of the camera and lens outfit.
    3. MOD (Minimum Object Distance) of 0.2m (7.9”), the best-in-class close-focusing capability
      MOD measures just 0.2m (7.9”), yielding a magnification ratio of 1:2.5, the shortest close focusing capability among fast-aperture fixed focal lenses in full-frame format*. Since the lens allows for shooting at distances extremely close to the subject (similar to a macro), close-up pictures with spectacular background blur effect (bokeh) can be obtained with the aperture wide open, thereby expanding the scope of photo opportunities. Tamron's proprietary Floating System, which places a group of elements at the optimal location as the focusing group travels relative to shooting distances, ensures the best imaging performance at any range. From the closest to a normal shooting distance range, image quality is excellent.
    4. Optimal relative illumination means no dark corners
      Some fast-aperture lenses “vignette” or have darkened corners due to uneven light distribution. However, even at the full open aperture, the overall illumination level across the entire field is well balanced and optimized. Because there is a sufficient amount of corner illumination, photographers can enjoy making full use of the wide open aperture.
    5. eBAND Coating deployed to thoroughly suppress ghosting and flare
      eBAND (Extended Bandwidth & Angular-Dependency) and BBAR (Broad-Band Anti-Reflection) coatings, both providing outstanding anti-reflection effect, are applied to critical element surfaces for maximum light transmission. Internal reflections from element surfaces which cause ghosting and flare are reduced to an absolute minimum. Flawless, crystal clear images can be obtained. eBAND Coating, a hybrid nano-structured layer with extremely low refractive index coupled with multi-layered anti-reflection coating technology, efficiently minimizes reflection of extremely angulated incident light—something that cannot be achieved by conventional anti-reflection coatings alone.
    6. High-speed AF with USD (Ultrasonic Silent Drive)
      Fast, quiet AF is achieved by employing a USD ring-type ultrasonic motor which enables remarkably precise focusing drive with high torque and responsiveness. Because the rotational torque of the USD is generated by waves of ultrasonic vibrations, inherent operating noise is extremely low and practically imperceptible. In addition, Full-time Manual Focus override is available at any point during the autofocus operation for deliberately shifting focus without switching the AF-MF mode back and forth.
    7. Fluorine coating on the front element repels water and fingerprints
      Fluorine coating technology, developed for use in industrial optics applications, has been adapted to photographic lenses. The water and oil repellant coating applied to the front element surface allows instant removal of dirt or smudges with ease. The coating also provides a reasonable level of durability, and will sustain its effectiveness for years.
    8. Moisture-resistant construction for shooting outdoors under adverse weather conditions
      Seals are located at the lens mount area and other critical locations to prevent infiltration of moisture and/or rain drops and provide moisture-resistant construction. This feature provides an additional layer of protection when shooting outdoors under adverse weather conditions.
    9. Circular aperture for enhanced bokeh
      The 9-blade diaphragm retains a nearly circular opening even when stopped down by two stops. Marvelously tuned blur in the subject background can be obtained without generating undesirable shapes of aperture patterns.
    800 x 528 - 52K
  • Really hoping the focus throw is greater than 90 degrees on this lens. Im going to assume it is mechanically focused and not "by-wire" since its a 3rd party lens. Any info about possible Sony E mount?
  • Interview on Japanese about two Tamron primes
    http://dc.watch.impress.co.jp/docs/review/tamronsp/20150918_721493.html
    800 x 527 - 71K
    Both center and edge sharpness are outstanding between f/2.8 and f/8. At f/11 and f/16 sharpness is beginning to drop off to diffraction.
    http://www.photographyblog.com/reviews/tamron_sp_35mm_f1_8_di_vc_usd_review/
    800 x 526 - 64K
    This lens offers premium features, such as weather sealing, silent autofocus and Vibration Compensation, which will make it an interesting alternative to other similar lenses. It is certainly capable of delivering excellent quality images, with high sharpness in the center of the frame.
    https://www.ephotozine.com/article/tamron-sp-35mm-f-1-8-di-vc-usd-lens-review-28147
    726 x 480 - 56K
    800 x 526 - 45K
    This isn’t one of the sharpest lenses out there, and indeed this isn’t one of the lenses strongest points. Of all the 35mm lenses that we’ve tested, this is one of the softest, but again that isn’t saying a lot considering how good modern lenses are.
    http://www.thephoblographer.com/2015/09/17/review-tamron-35mm-f1-8-di-vc-canon-ef/
    800 x 513 - 53K
