PR
The Sigma Corporation is pleased to announce the new generation of high image quality compact cameras “SIGMA dp” that incorporates a newly developed Foveon X3 direct image sensor (generation name: “Quattro”).
Unique and without peer among image sensors, the Foveon direct image sensor is similar to traditional color film in that its multiple layers capture all of the information that visible light transmits. Along with Sigma’s proprietary image processing technology, this sensor produces incredible resolution, precise gradation, gorgeous color, breathtaking realism with a 3D feel. In other words, full-bodied image quality.
For the new dp series, we rethought and redesigned every aspect of the camera, including the sensor, engine, lens, and body. While retaining its famous textural expression, which seems to give form to the air itself, the updated Foveon direct image sensor produces images that are more colorful, rich, deep, and faithful than ever before.
To a radical degree, the new-generation dp series embodies Sigma’s philosophy of creating cameras that produce works of art. Featuring the highest level of fundamental performance, this series unites artistic expression and daily experience as no other cameras can.
Special Features
With every element optimized for image quality, this camera is ready to produce works of art
Thanks to its optimized design featuring a fixed focal length lens and integrated body, the dp series offers both sensor and lens performance at the highest level. The result is full-bodied image quality.
In addition to superior holding performance, the camera body offers a balanced shape, layout, and weight distribution. With all of its elements designed for image quality, the dp offers highly intuitive operation. Its complete and robust specification allows the photographer to concentrate fully on photography itself and leverage the camera’s potential to produce outstanding images.
In everyday life, the dp series lets photographers find unexpected opportunities for experiencing emotion and enjoy photography and personal expression in exciting new ways. It is an outwardly simple yet extremely powerful embodiment of Sigma’s philosophy of photography.
Wide-angle, standard, and medium telephoto options
All of the fundamental photographic approaches in one lineup of three cameras
The dp series comprises three fixed focal length cameras, each of which features a different basic focal length for a different fundamental photographic approach: the wide-angle dp1 Quattro at 19mm, the standard dp2 Quattro at 30mm, and the medium telephoto dp3 Quattro at 50mm (respectively equivalent to 28mm, 45mm, and 75mm on a 35mm lens). Moreover, the three models share an exciting new camera body that brings out the best performance from the lens and image sensor.
It’s a simple but powerful lineup that delivers medium format-level image quality anywhere, anytime. Take all three with you and select as needed for the perfect shot. Only the dp series puts so much luxurious photographic potential in your hands.
The world’s only image capture system to use vertical color separation technology
Starting with our very first digital camera, we have featured the Foveon direct image sensor, which offers radically better image quality than any other sensor available. Leveraging the light absorption characteristics of silicon, the sensor comprises three layers of photodiodes, each at a different depth within the silicon and each corresponding to a different RGB color. Since it is the only sensor to use this superior vertical color separation technology, it is also the world’s only direct image sensor.
Almost all other image sensors are mosaic sensors, which use an array of RGB color filters in a single horizontal plane to capture color information. Each pixel is assigned only one of the three colors and cannot capture all three colors at once. In contrast, the Foveon direct image sensor captures color vertically, recording hue, value, and chroma accurately and completely for each pixel.
In the Foveon direct image sensor, there are no color filters, which cause a loss of information transmitted by light. Moreover, there is no low-pass filter needed to correct the interference caused by a color filter array. Finally, unlike the data from other sensors, which requires artificial interpolation to “fill in” missing colors, the data from the Foveon direct image sensor is complete for every single pixel and requires no interpolation. The unique technological principle of this sensor produces consistently outstanding image quality.
Newly developed Foveon X3 Quattro direct image sensor. Now featuring 39 megapixel-equivalent ultrahigh resolution
Capturing the information transmitted by light vertically instead of horizontally, the full-color image capture system of the Foveon direct image sensor is the only one of its kind in the world. This system makes possible the sensor’s full-bodied image quality, which is characterized by rich tone and gradation and texture that one can almost touch.
The newly developed Foveon X3 Quattro is the latest generation of this unique sensor. While retaining the distinctive characteristics of its predecessors, it offers an even higher level of image quality. In addition to 30% higher resolution, the volume of image data has become lighter, and it enables much faster image processing and lower current consumption.
At the same time, Able to maintain the same exacting standard of image quality while increasing megapixels and enhancing noise characteristics, this 1:1:4 solution was the inspiration for the name of the current generation of Foveon sensor: “Quattro.”
Newly developed TRUE III image processing engine. Optimized for processing Foveon X3 Quattro direct image sensor data.
The new dp series cameras feature the newly developed TRUE (Three-layer Responsive Ultimate Engine) III. This image processing engine has evolved in pace with our Foveon direct image sensor and incorporates all of the image processing expertise we have developed over the years. Thanks to new refinements, it is the ideal engine for processing the rich and complex image data produced by the new-generation Foveon X3 Quattro direct image sensor. Our proprietary algorithm makes possible ultrafast processing of an immense volume of image data without any deterioration of the final images. The result is high-definition, 3D-like photographs with outstandingly rich color detail.
Sigma dp1 Quattro Digital Camera and LVF-01 Viewfinder Kit for $999
Means essentially free LVF.
https://www.bhphotovideo.com/c/product/1237920-REG/sigma_ze900_dp1_quattro_digital_camera.html
New firmware
https://www.sigma-photo.co.jp/english/new/new_topic.php?id=559
slow and awkward to use Sigma Photo Pro software
Yes, Sigma, please ditch the Microsoft NET - based Photo Pro. It no longer works with Linux /Wine, forcing me to install Windows.
Compared to some of the ultra-wide lenses available the Sigma dp0 Quattro offers quite good value for money if you consider that you are buying an ultra-wide rectilinear lens with a camera that has a sensor capable of delivering 35+ megapixel images. Perhaps the biggest problems facing the camera are the rather unusual design of the camera (which has made it larger than the Sigma dp Merrill series), as well as the slow and awkward to use Sigma Photo Pro software.
http://www.ephotozine.com/article/sigma-dp0-quattro-review-27860
The Sigma dp3 Quattro delivers some of the most detailed, crisp and sharp photos available, although there are some image quality issues with JPEG images.
https://www.ephotozine.com/article/sigma-dp3-quattro-review-27833
Foveon sensor performs quite well in brightly lit environments. The built-in 50mm f/2.8 Sigma glass produces beautifully contrasted, vibrant imagery. If you intend to be shooting with the camera out during the day, you will be quite happy with the images produced.
Sigma continue to take a solitary path with the new DP0 Quattro, remaining the only camera manufacturer to use the Foveon sensor technology. Despite some improvements to the processing speed, the Sigma DP0 Quattro is a rather slow camera that's really only suited to static or slow-moving subjects, while the rather radical new design favours image quality over usability.
http://www.photographyblog.com/reviews/sigma_dp0_quattro_review/
The dp3 Quattro won't suit everyday snapshooters and may not be ideal for some photo enthusiasts. It's more ponderous to use than its dp2 Quattro sibling and the raw conversion software, though capable, is quirky. But that Foveon sensor is hard to beat if you're after rich colour rendition plus detail that rivals the best DSLRs we've reviewed.
http://www.photoreview.com.au/reviews/advanced-compact-cameras/fixed-lens/sigma-dp3-quattro
Version with 14mm lens.
PR
Sigma Corporation of America, a leading researcher, developer, manufacturer and service provider of some of the world's most impressive lines of lenses, cameras and flashes, today announced the new Sigma dp0 Quattro, the fourth compact camera in the series that was announced last year. The news comes at the start of the CP+ Camera and Photo Imaging Show 2015, which begins on Feb. 12 in Yokohama, Japan.
The dp0 Quattro incorporates a fixed, high performance 14mm F4 lens, which is equivalent to a 21mm lens on a 35mm DSLR and is optimized to maximize the performance of the series’ Foveon “Quattro” Direct Image sensor. The Quattro line is great for photographers seeking a unique product, and the 14mm F4 lens is meant to take full advantage of the Foveon sensor.
“The Quattro series is such an unique line of cameras and we couldn’t be more thrilled to add the dp0 Quattro camera to the line-up,” said Mark Amir-Hamzeh, president of Sigma Corporation of America. “It’s this wide angle lens combined with the high resolution sensor, that makes this perfect for architectural and landscape photographers, and something the dp fans can be excited for.”
In order to achieve the highest optical performance, the dp0 lens features four “F” Low Dispersion (FLD) glass elements, which have performance equal to fluorite, two Special Low Dispersion (SLD) glass elements, and two aspheric lenses, including a wide double-sided aspheric lens. This reduces chromatic aberration and distortion, which are characteristics typically present in super wide angle photography. The camera offers sharp rendering performance from the maximum aperture, and the superior telecentric optical design improves image quality throughout the frame and maximizes the sensor’s ability by passing on information about subjects to the sensor. In addition, the wide angle of view of 91 degrees and depth of field are ideal for architectural structures, interior photography and landscapes. With this powerful lens and sensor, numerous glass elements to reduce distortion, and a 91 degree angle of view, this lens is ideal for landscape and architecture photography.
As with all the cameras in the Quattro series, the dp0 Quattro features the distinctive styling of the line. The Quattro sensor is the equivalent of a 39 MP conventional Bayer sensor in resolution testing. The next generation sensor builds on the distinctive properties of the X3 technology, which uniquely records red, green and blue wavelengths at each pixel location within three layers.
The Quattro sensor is a three-layered, panchromatic silicon chip whose green-sensitive middle and red-sensitive bottom layers each have 4.9 MP and record only color/chrominance information. The top blue layer captures chrominance and resolution/luminance information with 19.6 MP, resulting in greater detail capture and resolution capabilities that are higher than the Merrill DP camera line. The Quattro sensor’s architecture also contributes to true color rendition, more detail capture, and faster image processing, all of which delivers even more realistic images.
With four cameras now in the line-up, photographers can select the most suitable camera based on their photographic needs with the Sigma dp0 Quattro 14mm F4 lens, Sigma dp1 Quattro 19mm 2.8 lens, Sigma dp2 Quattro 30mm 2.8 lens, Sigma dp3 Quattro 50mm F2.8 lens and Sigma dp3 Quattro with dedicated conversion 1.2x lens 90mm.
The dp0 Quattro camera will also feature:
- Optional dedicated Optical Viewfinder VF-51 that offers accurate framing and makes composition easier as it is unaffected by external light conditions
 - The TRUE III Image processor, providing ultrafast processing of an immense volume of image data without any deterioration of the final image
 - Better high ISO performance with one to two stops of improvement
 - Improved 3A performance: Auto Color Mode, Auto Focus and Auto White Balance
Wow. Impressive quality from the Sigma.
Oh, it is great news! Hope to get it soon. My dp2q wants to have a brother for taking portaits and macro work. I love such funny comparisons between newest big FF bayers and small foveon DP series, where bayer FFs feel bad every time.
