Has anyone actually gone through with the modding at this point for a 70d. I have tried the -25Db attenuator and actually didn't have any luck with it. While there was some reduction it was not that good. However, I'm using this into a D5300 and people in general say the D5300 recordings are always very noisy. That being said, I've been using it for about a month now and overall have been satisfied apart from the grumblings of individual monitors, etc.
The pres on the 70D sound really neutral to my ears so my interest in the mod is not in improving the "top end" which is just not relevant in dialogue rcordings. Lowering noise, however, is never a bad thing as it allows you to record at safe levels (thereby bypassing the need to engage the limiter=noise) knowing you can boost your recording in post (if your gain was too low) without having to stress about the noise inherent in the signal becoming conspicuous; to draw an analogy, imagine if for $100 someone could mod your camera sensor allowing you to raise your shadows 20 ire in post without introducing any noise... I think that's a very worthy investment.
I doesn't really drop the noise, it reduces some of the added noise. Suppose you took a microscope and removed only the hexagonal dust particles from the dirty floor. You look at the floor, it's still dirty. I don't hear any noise on my Tascam pres worth mentioning for video work. The modded units I heard sound ever so slightly smoother--and it is a very small difference.
@joethepro SD USBPre 2 limiter, I use 100dmkii just to save .wav file.
@Sage Used SD 702 would be better, but still almost twice the money than used 100dmkii + SD USBPre 2 + new USB battery. And advantage with USBPre 2 is that it's also audio interface. I use it also in my home studio :)
I'm seriously considering the mod. If it can drop the noise floor by at least 6db's on the 4 preamps then I think it's worth it. That's about $50 (incl shipping) a channel to give you the confidence of adding 20db in post without having to stress about hiss/noise. Dropping the external preamp is a most welcome evolution in the OMB workflow.
Here's a couple of clips from last night I've not done anything with them level wise or anything recorded at 48,000 Hz 24 Bit Good enough for me for what I do and really like the form factor as well with the cam they thought that out well.
Off the mixer mono https://www.dropbox.com/s/g8i7zil8umbvk1u/mixer.wav?dl=0
Internal Mics https://www.dropbox.com/s/k04ehg36qiqdrfx/internalmics.wav?dl=0
No point sharing the cam on as it mixed all 4 tracks i.e. the internal mics, the high mixer and low mixer but it still synced ok, I need to see if there's an option to select, I might have missed something.
I used mine properly for the first time last night (I'm not pro at this, guy on mixer desk was tho ;-) ), the new firmware is a must I had hiss over the camera line out with the original firmware (glad I checked first) seems fine with the new firmware. I left limiters off and just split the xlr cable from the mixer desk and recorded a backup at a lower level just in case and set the inputs to line level for 1 & 2 with low gain. I think you can do that internally as well but didn't want to risk it for the first time. Setting the line out to cam and left at 0db and my gh4 to -12db it was fine, I left the limiter off the gh4 as well, it got close but was ok, I think i'll change the output to -6db to be on safe side next time, just used a shielded cable no attenuation at all. [edit] Also I need to see if you are recoding 4 tracks if you can pick which tracks got to the camera i just noticed my camera has all 4 tracks mixed which is fine i just wanted it for reference audio and you can still sync it with pluraeyes I just tried but that might be problematic in some situations, need to read manual!
Had internal mics for ambient noise they seemed ok as well for internal mics and managed fine when my zoom was clipping even with the levels down to 0.
Worked well, much easier to use than my zoom and sounds better to me but that could just be the guy doing the mixing really knew what he was doing I thought I knew a little about audio I now realise I know nothing after watching him :).
Had 4 new Duracell batteries recorded 2 x 1 hours sets no problem with room probably another hour left but I wouldn't risk it over, there's were nothing special battery wise tho and you can run it off usb anyway.
@joethepro Speaking with Busman Audio, a popular modder, I learned that apparently all limiters introduce some noise. He advised avoiding the limiter and simply keeping peaking around -12 to -16 (because of 24 bit precision, it is not necessary to push levels, as the noise floor is not lifted relative to the signal). Also, I believe the 70D is capable of recording the same input at two different levels.
Tonalt is referring to digital in, which takes the 100's analog processing out of the question - its just storing bits. Of course that combo goes a good bit of the way to the cost of a used SD702, which would be much more preferable. I am looking into a modded 70d specifically so I don't have to rely on the SD preamp + recorder tangle of wires/batteries/coordination that I have been doing.
Busman will do a cap and op amp mod on the 70d for $150 - http://www.busmanaudio.com/contact.html
@sam_rides_a_mtb Has the limiter noise issue been solved, or is that just a hardware problem? I know its generally a very decent and versatile recorder.
@tonalt Ive only heard good things about the 100 mkii, well except for the omni mic noise and the handling noise, but those are not really mic issues. Were you talking about the 100mkii limiter, or the USBPre 2 limiter, being great?
@joethepro 100dmkii has digital in. I use SD USBPre 2 with it. It's audio interface with supreme preamps, but works also in standalone mode. Excellent limiter also, my audio never clips. The best budget combo for truly professional quality. I'm surprised how no-one is talking about this combo. Instead they try all the cheaper alternatives one by one.
I just never see the point of upgrading audio gear with new components, it's just not for the average user to be messing around sending off gear that should have been made better in original design. So Tascam like the rest of the pro-sumer manufacturers build to a price not a quality. I guess that's why Sound Devices always gets a top rating.
with the latest firmware, the 70D has vastly improved. I will try to post some tests soon, though I find it so much quieter than any Zoom recorder. The noise people are hearing from the GH4 recording that is not present in the 70D recording is (based on my own tests) from the slightly noisy noise floor on the GH4. Solution, bring GH4 levels to -12dB and make sure limiter is off on GH4 and Tascam.
With regards to the earlier discussion of recorder self noise, I found this little gem about the 70D:
"3. Limiter adds 12dB noise due to poor implementation and should be avoided."
https://www.gearslutz.com/board/10842631-post31.html
You can swap the op amps for the famous LME49720, which I use in my sound card (they are awesome)
Jim Williams is a well known techie there
In the case of good modern preamps/recorders (i.e. not h4n, rather tascam & up), the inherent noisefloor is quite low - on the order of several times lower than the average mic. And thats the case here; unless you've got a uniquely quiet mic (like the large diaphragm BP4025), its probably the microphone's self-noise. To isolate the noise floor of said recorder (haven't used the 70D), use a bent paperclip to close the loop between pins 2 & 3 on the XLR in (don't touch exposed metal while running phantom power). This is what a mic with no noise floor would sound like on the recorder.
@spacewig I'm not sure I follow you.. I'm trying to attenuate the signal, not amplify it. And if I output from the 70d as line it is way to powerful for the GH4 as it's not capable of accepting line level signals, therefore nowhere near unity gain.
@smoke23 yes it seems this is the way to do it - I found this post where more people were having this problem and seems like people are having success with the Sescom cables as stauffec suggested above.
I've been thinking of getting a DR-70 to go along with my DR-40. I've used this Sescom cable with my DR-40 to my GH4 & GH2 without any problems, I'm guessing this would work with the line-out of the DR-70?
