Noise Test: Panasonic GH2 with Driftwood's 176mb GOP1
  • 78 Replies sorted by
  • i had an extreme amount of noise with driftwood's 172Mbs patch when shooting AVCHD 1080i, so when NOT shooting 24p cinema. That is odd cause the average bitrate is around 50. Not that this is a problem. Just saying. I'll probably always shoot 24p from now on.
  • Thats because it relentlessly reaches superb constant buffer fullness and reliably matched bitrate and i frame size.
  • I have been noticing that there is allot of chatter about the GH2 testing. I have been trying to get the 244 Driftwood to crash or fall apart. For my needs in low light and hard light this hack is right on.
    There is no noise that I can see and the color and focus through a prime 24mm is tack sharp. I do not see banding nor odd color readings. I will continue to try and stress the setting but at this point why.
    This is a monumental achievement and proof that people working in concert with talented direction can mark a difference.
  • f1lm3r,
    Many use Neat Video for noise removal. Look it up.
  • I just assumed that since traditional digital video cameras are ISO 320, that it was a good default ISO to work with. Figured the reason for the 160 ISO group was to stay on this multiple.
  • I don't use Vegas, but how did you remove that noise? And is there a way to do that in premiere?
  • Thanks @Hiroshi I stay @ Gamma 2.2 in Vegas myself.
  • hi,
    I played around drifwood's 178Mb GOP1 setting, it looks really nice however it seems the claim from some people is right - could be found some remarkably artifact in dark area.
    So, I tried to improve that problem w/ colour profile setting.
    - smooth profile
    - Contrast, sharpness, saturation, and noise reduction are set to '-2'.
    - White balance and temperature is adjusted to around 6500k.
    - +3 exposure.
    This setting tried to remove gamma from AVCHD-intra... I mean I tried to have 'Linear' gamma.
    I applied gamma(2.2) in post process.
    It looks mid to dark area had been much better.
    Of course 8bit dynamic range is not enough to use linear gamma, mid to hi-light tone was messed.
    This test sounds silly but hopefully some people might be interested. ;)
    Cheers,
    Hiroshi
    1570 x 661 - 1M
  • Is there a noob tutorial on this site on how to apply this particular patch? I just got my Gh2 yesterday, this is so amazing.
  • Its weird I thought I read somewhere that they made the 160 multiples as they would be the best case regarding noise. It seems the opposite is true, unless you shuffle back and forwards first.
  • Hmm...
    Very strange indeed.
    We will need more repeatitive testing for this strange ISO issue.
    It's as if the ISO function state does not always toggle, but manages to update the display to read the ISO values correctly. Maybe the times ISO320 is noisy may actually be setting it to somethings internally different like ISO640 for example.... WTF over...This is a panny issue no doubt. It seem like their programming for this is an issue.
    fucking bummer....
  • It leads a bit to the conclusion that pana started to join the club of those who think that public beta testing is a cheap and powerful instrumenent. Which it indeed is.. just with some side effects.. ;)
    edit: ah yeah, used manual lense.
  • Well Im gonna take along my EX3 tomorrow and shoot the same subject matter and see wtf happens... orange Bus LEDs... hmmm
  • I get flickering from my television (a samsung LED), and I've encountered similar issues with projectors f.i. (in PAL-land). Actually when I found a shutter speed setting that did not make the tv-monitor flicker, I got severe flickering on everything else from the light from the television. Maybe that makes sense to someone, I found it wierd.
    Flickering is a bit random though, for me too - sometimes some shutter-speed setting produces bad flickering (affecting the whole scene) and sometimes not..
    The good news is that it's normally pretty easy to spot from the display. One can then work around it by switching settings.
    Edit: on second thought, flickering from the television makes sense if it's, say 60 hz or something like that. (a 1/60s shutter speed would then counter that, but perhaps produce other problems with other light sources..)
    One has to remember to take care in a scene with complex artificial lighting though.. Even faint light from a source which produces flicker can make it appear in unexpected places in a shot.
    I guess many of the phenomena could be explained by light leakage, making it seem like there is an unstability in the shutter.
    However, the ISO issue above is clearly something else.
  • Actually if this proves the same with others, this is a serious issue.
  • I tried my tests on a few manual lenses, @Meierhans what lens you try?
  • I can confirm that the flickering issues are occuring in an inconsistent manner.
    (Quite happy you are in PAL land as well and seem to like the night.)
  • Its only on certain lights it seems.
  • @starstuff Im very aware of the shutter problem and how you should align it to the neccesary country lighting/hz whatever. Most flourescent lights should be in the 100Hz range, bus LED lamps should also be around 50.
    So 100 shutter should be suffice. However, I experienced from switching on recording at 320iso, seting to 100 shutter constant flickering, I then switched to 80, then 60 before it stopped, I then returned to 100 and it had stopped flickering. Something isnt right and tomoz Im going to repeat the tests.
  • @driftwood
    Unless I understand you wrong, afaik that is normal with all cameras?
    If the SS is not in sync with whatever flourescent lights you are recording, you get the flicker effect.
    There's even some plugins for post that specifically are designed to address this issue.
  • I get the strange feeling there is a potential shutter problem as well as the iso prob mentioned above or something we're doing with the hack is playing up with the gh2.
    Can someone confirm/ test 1080p24H on say flourescent strip lights or bus number LEDs - I was shooting today buses going by at 100 shutter (normaly no probs - PAL land) but in the LCD I could see flashing - as was confirmed by the recording, then I went shifted the shutter down, recorded at 60 shutter - everything fine, went back to 100, and everything was fine again. Strange indeed. I think I remember seeing this anomallity in my stock GH2. More tests I thinks... I was on manual.
    [*Setting tested was my GOP3ILLA patch]
  • I don't think it's in any way related.
  • At least its not purely related to hi bit hacks like the GOP1
  • Oh yeah...I don't know why I forgot about this bug. Thanks for jarring my memory.
    Still...it makes me wonder about what's actually going on at ISO 320.
  • Yep, same situation ... ISO 320 is very clean -after all the manipulations :)
