Key specs:
PR
Nikon has also introduced the AF-S NIKKOR 300mm f/4E PF ED VR, the world’s lightest 300mm full-frame fixed focal length AF lens, which is nearly 30% shorter and 1.5 lbs. lighter than its predecessor. Extremely easy to handle and built to suit the needs of serious photographers in the field, the new 300mm f/4 lens utilizes Phase Fresnel optical technology to help correct chromatic aberration and reduce the overall size and weight of the lens, making it easy to pack for any assignment. Capable of producing tack-sharp images and beautiful background blur at a distance, Nikon’s newest FX-format lens also features four and a half stops of VR image stabilization, a VR Sport mode, VR tripod detection as well as several of the latest NIKKOR optical technologies including electromagnetic aperture control, a Silent Wave Motor for quiet AF operation, ED glass for further controlling chromatic aberrations and Nano Crystal Coat for superior image quality.
http://www.focus-numerique.com/test-2214/objectif-NIKON-AFS-NIKKOR-300MMF4-E-PF-ED-flash-test-8.html
The amazingly compact design and moderate weight allows the lens to be used hand-held in most shooting situations. Sharpness is very high wide open at f/4 and remains high up to and including f11. Geometric distortions and chromatic aberrations are minimal.
http://www.photographyblog.com/reviews/nikon_afs_nikkor_300mm_f_4_e_pf_ed_vr_review/
We have confirmed that when the AF-S NIKKOR 300mm f/4E PF ED VR lens is used with the D800, D800E, D810 or D810A, images captured at shutter speeds of around 1/125 s with the VR function enabled (NORMAL or SPORT) sometimes exhibit noticeable blur.
To address the occurrence of this, we are offering a service for updating your AF-S NIKKOR 300mm f/4E PF ED VR firmware.
When cameras other than the D800, D800E, D810, or D810A are used, this firmware update is not needed.
Users of the D800, D800E, D810, or D810A who are concerned about this issue may take or send their lens to a Nikon authorized service center, where your lens firmware will be updated free of charge.
When sending your AF-S Nikkor 300mm f/4 E PF ED VR lens to a Nikon authorized service center, the user must pay the cost of shipping to the service center, and Nikon will pay for return shipping.
Firmware for lenses with a serial number of 205101 or later has already been updated
The Nikon AF-S 300mm f4E PF ED VR delivers very good sharpness and overall contrast even wide open. And that in a package that is the smallest and lightest 300mm f4.0 lens available for full-frame cameras.
http://cameralabs.com/reviews/Nikon_Nikkor_AF-S_300mm_f4E_PF_ED_VR/
Nikon have created a compact, portable lens, that is a decent upgrade over its predecessor. Sharpness is excellent across the frame from maximum aperture, vibration reduction system is effective, focusing is fast and the lens is small and light enough to carry around all day.
http://www.ephotozine.com/article/nikon-af-s-nikkor-300mm-f-4e-pf-ed-vr-lens-review-27097
Hands-ons
About Phase Fresnel
The PF (Phase Fresnel) lens, developed by Nikon, effectively compensates chromatic aberration utilizing the photo diffraction phenomenon*. It provides superior chromatic aberration compensation performance when combined with a normal glass lens. Compared to many general camera lenses that employ an optical system using the photorefractive phenomenon, a remarkably compact and lightweight body can be attained with less number of lens elements.
A general interchangeable lens forms an image on an imaging plane, using the photorefractive phenomenon. The degree of light refraction differs depending on the color (wavelength), and image formation is performed in the order of blue (B), green (G), and red (R) starting with the portion near the lens (see the diagram below). The color deviation referred to as chromatic aberration induces color bleeding, resulting in a deterioration of observed or captured images.
With PF (Phase Fresnel) lenses, on the other hand, image formation is performed in the order of red (R), green (G), and blue (B) starting with the portion near the lens (see the diagram below). By combining the PF (Phase Fresnel) lens with a refractive lens, chromatic aberration can be effectively compensated.
Due to the characteristics of a PF (Phase Fresnel) lens that utilizes the photo diffraction phenomenon, when there is a strong light source within the frame or when light enters the lens from outside of the frame, ring-shaped colored flare may occur according to shooting conditions. This phenomenon can be minimized with “PF Flare Control” included in Capture NX-D (see the comparison images below). Refer to the software manual for more information.
Chromatic aberration compensation with the PF (Phase Fresnel) lens
