Slider recommendation 1 m, electronical and non-electronical
  • For shooting on the GH4 i not a reliable slider that can also be mounted on a tripod. Both, an electronial and manual slider would be great.
  • 9 Replies sorted by
  • I can't help but toot my own horn check out my Salamander Slider at salamanderslider.com . If you do any outdoor work you might appreciate it's weather resistance.
  • My work just got a ProMediaGear Duo Slider. It has both a straight and curved track milled from solid aluminum.
  • Oh you are in EU - sorry man everything is more expensive there! Try Konova?
  • Thank you for all that replies. The shark s1 slider seem to pretty reliable, also quite expansive. What about slider solutions up to 200 euro?
  • I have Shark S1. I like the flywheel. But mounted on Tripod it's not rock solid.. flywheel and heavy camera on one side, hard to balance. Same problem with all sliders though.
  • I have the Varavon also. I have the motor and the slider is good both ways. I also have an inexpensive slider in the "why did I buy that" pile.
    Just FYI IMO sliders and anything but the heaviest tripods don't get along. I have a surveyors field tripod I modded just to use with my slider.
  • The flywheel system makes it easy to get smooth moves every time, and you can get extensions too for when you need a longer slider. I believe they have motion control available too.
    They do, but it is far from cheap.
    Also tons of fakes now available with low quality.
  • iFootage Shark slider is amazing. The flywheel system makes it easy to get smooth moves every time, and you can get extensions too for when you need a longer slider. I believe they have motion control available too.
  • I have one of the Varavon sliders - i have a motor for it, but you can also get a manual crank as well. They are excellent. See the PV deals...
