My work just got a ProMediaGear Duo Slider. It has both a straight and curved track milled from solid aluminum.
Oh you are in EU - sorry man everything is more expensive there! Try Konova?
I have Shark S1. I like the flywheel. But mounted on Tripod it's not rock solid.. flywheel and heavy camera on one side, hard to balance. Same problem with all sliders though.
I have the Varavon also. I have the motor and the slider is good both ways. I also have an inexpensive slider in the "why did I buy that" pile.
Just FYI IMO sliders and anything but the heaviest tripods don't get along. I have a surveyors field tripod I modded just to use with my slider.
The flywheel system makes it easy to get smooth moves every time, and you can get extensions too for when you need a longer slider. I believe they have motion control available too.
They do, but it is far from cheap.
Also tons of fakes now available with low quality.
