PR
Shenyang China, Apr 16, 2015 – The Mitakon Speedmaster 85mm f/1.2 is a ultra-fast portrait lens that delivers unbelievable optical performance. A maximum aperture of f/1.2 makes it extremely convenient for shooting without flash in low light conditions. Designed for the use of full frame cameras, the large aperture also provides fine control over depth of field for fascinating portrait photography. The truly circular aperture creates a shallow depth-of-field that brings attention to the subject and blurs the background, which is critical for portraits. The lens incorporates 9 elements in 6 groups with 2 pieces of Extra-low Dispersion elements & 4 pieces of High Refractive Index elements. This helps reducing aberrations and maintain excellent sharpness even at f/1.2. . Manual focus design and a click-less, silent aperture ring promote smooth handling and are especially well-suited to video applications. The lens is built of metallic enclosure with additional protective processing, which gives extra durability and aesthetic.
They made Sony A Mount native lens.
Wow. Now I need to get money for this one.
Available on PV deals
http://www.personal-view.com/deals/lenses/mitakon#mitakon-85mm-f12-lens
Mitakon now was a quite complete set from 24mm to 135mm! Now next is needed is a wide angle (even if just for Super 35mm / APS-C), in the 16mm to 20mm range preferably.
Unfortunately mostly just for mirrorless mounts. If they can replicate a similar line up for Nikon F mount (currently just have 35mm & 85mm. Strangely not the 135mm?? Even though it ships in Canon EF and Pentax K!!!) then I reckon I'll get a Mitakon set.
Speed Boosters don't go faster than a certain T stop with lenses that are already fast, somewhere around 0.9.
Insanity. Might pick one up just to play with. Colors look pretty good, wonder what the performance is like at f4.
A samyang 85mm on a speed Booster is already quite silly but this one + speed Booster would be really really fun to try :)
