GH4 4K Panasonic video camera, User reviews and opinions
  • 1273 Replies sorted by
  • I shot this entire piece with 2 GH4's. It's a music video for LEGO, and their new season on the show Ninjago.
  • Slow-mo vid, shot on a GH4....please like on youtube & share :)
  • Slow-mo 96fps, filmed with my GH4 trying to achive a cinematic homevideo with a story...
  • @digitalflaskpost Nice video. Try to put it in 2.35:1 format and you'll see what doing almost nothing introduces so much to this kind of video.
  • @digitalflaskpost That was beautiful.
    @jopereira Widescreen is great for many films, but some films need 1.85:1 or 1.77:1 treatment because of the subject matter. Most of the shots in his video are of a single childs head. There is no service to the story telling by adding more background to the left and right.
  • Thnx for the comments. I also didnt think I needed that kind of cinematic element for this kind of film. I also didnt outputed this in 23,976fps either. Its actually in "noncinematic" 29.970fps :)
  • I should note that for a dead-simple remote run/stop trigger for the GH4 all you need is a standard LANC TRS (3-pin) 2.5mm stereo micro-plug (the one size smaller than a standard mini headphone jack). You don't need the 4-pin plug shown in most panasonic trigger schematics. You also don't need the resistors. Just short the tip to the sleeve momentarily to start and stop. I use a momentary pushbutton switch between the two. Works like a charm. I wired it into my handgrip, but I would assume most standard remote triggers for normal cameras which use a similar trigger schema will work as well, if you need inexpensive remote triggering a pair of flash remotes will also do, with a simple custom cable! A lot easier than trying to use a smartphone, pair the wifi, etc.
  • plugged into where? -
  • Well, you cannot go wrong: "Remote" label on left side of the camera. Also, there is no other 2.5mm jack on the camera.
  • shot this music video in a studio with two GH4, pretty happy with the BW result!
  • @olegkalyan
    Nice ... the missus noted the great way you'd moved the light across the scene at times, which was very effective. And I noted the sound which I assume was coming from the rather nice audio capture/process/mixing gear in that studio ...
    Neil
  • @olegkalyan Nice music video. I also liked the practical light effects and mixed cut transitions.
  • @olegkalyan
    Agreed with above, great mixing of cuts & transitions, so one doesn't even "see" them. The missus wants to know if you had someone panning the lights on your direction ... how you got the moving-light work done.
    Neil
  • Might be a stupid question - but by any chance when shooting in Video mode - is there any difference if you press the red REC button to start/stop video vs. the actual shutter button on the GH4? Thanks!
  • The shutter button is bigger & easier to press.
  • Just finished this music video for Italy-based American artist Elisabeth Cutler.
    Shot with GH4 + Leica 15mm/f1.7, 25mm/f1.4, 42.5mm/f1.2, Panasonic 7-14mm/f4.
  • GH4 - 4K - LUMIX 14-140
  • GH4, 4K, TAMRON 500MM,
  • Just did a test on recovering sky detail with GH4 set to Natural and all other settings at 0. I did a bracketed exposure and chose the best dynamic range on the waveform display in DaVinci Resolve. There was no highlight clipping. In-camera zebras were visible across most of the sky and were set to 100%. Video range was set to 16-235 and was shot at 100MB 1080 25p.
    Before and after grading screengrabs below. Extra colour added to sky to reveal the sky as it appeared to the eye.
    800 x 455 - 685K
    800 x 456 - 766K
