Faster scan rate to reduce rolling shutter in 4k. Probably not possible in firmware though. ISO down to 50 or as low as possible. Higher bit rates for 4k including an all-i option of possible, even if its a little wonky. 10-bit video internally, even if 1080 only. I don't care about the color/res as much. Just the bits. Post-plasticity is way more important than accuracy for me. Improve the all-i codec. Nothing else for me, but I'm an all-manual and experimental sort there are probably a lot of important shortcomings others I don't encounter.
I'll echo the iso < 200!
(Not sure if it could be remedied with firmware update) Audio and autofocus in variable frame mode would be great!
Exposure Compensation functional in manual mode to adjust target exposure of AutoISO (photo and video)
AEL to lock AutoISO in manual mode (photo and video)
I also would like one push AE to work correctly. It seems to have changed
