Yuneec sells currently its Q500 Typhoon quadcopter with a free handheld stabilizer to wich the CGO camera and the 3-axis gimbal from the quad could be attached for use on the ground as a steadycam. Short presentation by two Yuneec dealers in this video:
Yuneec Q500 Typhoon
Yuneec Q500 Typhoon
Walkera Voyager 3
Good article about necessary gear and using Phantom 2
http://alaskavideoshooter.com/a-drone-for-all-seasons-dji-phantom-2-tips-for-aerial-filmmaking-gold/
This thing can lift an LX100 - http://www.engadget.com/2014/11/22/3d-robotics-x8-plus-drone/
Unedited sample footage from this last review Vitaly posted looks a lot better than the 'real world inspire one footage' video above and is somewhat encouraging as in general the camera looks to be the weak spot of the system. Looking forward to flying one of these.
Short review-preview at http://visual-aerials.com/dji-inspire-1.html?lang=en
DJI Phantom II Ver 2.0
What's New for Version 2.0?
Redesigned Radio Controller
The radio controller (more commonly known as a transmitter in RC lingo) has been updated with some notable additions:
- Left Dial: Use this to operate the tilt function of a Zenmuse gimbal
 - Trainer Port: Connect the remote control to the computer to run a simulation application
 - Throttle Lock: Pull down the throttle stick to descend; the stick will lock into place and the aircraft will descend steadily. Push the throttle stick upward to release throttle lock
 - LED Battery Indicator: Foregoing AAs, the transmitter now runs on a built-in LiPo battery. Four LEDs on the front tell you how much charge is left
 - Micro-USB Port: Use the micro-USB port to recharge the built-in battery. The LED indicators will display charging status as the battery tops up
 New 2312 / 960 KV Motors
The new motors features a stator winding structure for a neater designed and improved heat dissipation. The new motors offer:
- Up to 200g per axis more thrust than the previous design
 - The single wire stator design improves motor efficiency and its ability to withstand a larger current
 - New bearings, with a higher durability and ability to withstand greater impacts, are used to avoid damage in the event of an accident
 - New insulation coating powder is used to improve the stator voltage capacity, helping extend the working life and stability of the motor
 - A new ESC (electronic speed controller) - ESC v2.0 - is used to ensure the efficiency improvements of the motors are maximized
 Updates Self-Tightening Props - Model 9450 Computational fluid dynamics (CFD) have been applied to the prop redesign, providing them with increased thrust and better efficiency.
Combined with the new motors, up to 200g per axis of thrust has been achieved - especially beneficial when flying with a heavy payload.
Improved Compass. The compass is now encased in a protective shell, and features added protection against static interference
http://www.bhphotovideo.com/c/product/1088688-REG/dji_cp_pt_000083r_phantom_2_copter_with.html
Inspire available at
DJI Inspire 1
Videos
Phantom 3 Triumph rumor is that it will have 4K camera, DJI Lightbridge for FPV and many other goodies.
http://fpvportugal.com/novas-informacoes-sobre-o-dji-phantom-3-triumph/
Wltoys V303 Seeker, $300 quad
Scout X4 from Walkera
The 3D rig is not so much about the heli. It's more a matter of there not being gimbals designed with that in mind (at least that I know of). You could probably find a 3 axis gimbal that's designed to carry a small mirrorless cam and adapt it to fly a 3d gopro rig. Once you determine the total weight of the gimbal and camera(s), you can then start looking at what type of heli you'd need to carry it. Definitely more than Phantom though.
Do any of these work with a dual GoPro setup ? As in 2x cameras in a GoPro 3d rig ? Just checking if the copters are specifically built for a single GoPro.
@Adam_Mercier It looks smooth maybe even too smooth :) Which x3 gimbal did you use in this clip?
