Sony A7s, FHD camera, with 12Mp sensor, big DR
  • 1100 Replies sorted by
  • somebody should try out the DRO function at max (since 8 bit video is not raw), cause so far I am lacking the 15stops dynamic range claimed by sony even with Slog2, ...I am interested how much noise would that bring about, cause you can clean a lot with neatvideo, but you cannot recreate blown highlights
  • Does anyone know where I could find properly exposed 720p 120fps S-log2 footage for download? Anyone has some spare footage I could take look into? I'm having hard time deciding between A7s and GH4. I have noticed that noise is pronounced while shooting in APS-C crop mode, so it might be too much shooting S-log2 and grading it without any noise reduction?
  • Hey guys, I just picked up the Sony A7s and only have it for a week. I'll be doing some low lights tests and a shootout with the GH4, but what would you guys want me to test? Let me know here or on my page: http://filmbrosmedia.com/sony-a7s-review-in-progress/
    2592 x 1936 - 1M
    1000 x 750 - 459K
  • Cinema5D has tested the A7s and says it has 14.1stops of usable dynamic range, which is surprisingly good. In the same test the Arri Amira get 14.4, the 5D mark III get 11.8 and the GH4 get 10.9:
    http://www.cinema5d.com/dynamic-range-sony-a7s-vs-arri-amira-canon-c300-5d-mark-iii-1dc-panasonic-gh4/
  • I'm very weary of anything from 'Cinema 5D' - just look how they are happy to bash the GH4: 'The Panasonic GH4 had the worst dynamic range in our test. This is in line with the rather videoish look and contrasty colors we can subjectively observe.'
    They are obviously Canon and Sony fanboys and sponsors. Not that I'm taking anything away from the A7s, its a beast of a little machine.
  • Any feedbacks about the "Shit-Log2" and the headhaches in post? Is it any better than "ShitStyle" ?
  • @apefos Try grading the slog footage posted earlier in this thread for yourself. Cannot be compared to flat styles on Canon cameras. Imo it grades very well, especially considering the codec. But you can try for yourself and see what you think.
  • @apefos yeah man it's giving me huge headaches thinking how i ever managed to live my life without this amazing image making box.
  • a7S S-Log2 Exposure Test:
    a7S S-Log2 ISO Test:
    a7S S-Log2 White Balance Test:
    For pixel peepers, I've also uploaded the high bit rate versions of these videos. You must log into 4shared to download: http://www.4shared.com/folder/w2Sapny9/Sony_a7S_tests.html
    A few of my initial findings:
    • The camera's S-Log2 output complies very well with the S-Log2 specification. The ACES IDT is transforming it into the linear color space very accurately.
    • S-Log2 gamma with the S-Gamut color space is the correct choice for ACES, and it's the default for Picture Profile 7. But S-Gamut is a bad choice if you want to manipulate log footage directly: choose the Rec.709 matrix instead. S-Gamut is shifted in CIE x y space relative to the rec.709 gamut, and standard color correction tools cannot fix it.
    • The ACES workflow is awesome. I can do exposure compensation and color balance nearly as well as with raw files in Lightroom, and easily match between shots.
    • S-Log2 at ISO 3200 (the minimum available ISO with S-Log2) has the same highlight range before clipping as a standard picture profile and ISO 320.
    • The best exposure for S-Log2 is the highest exposure you can manage without too much clipping. Around +2.0 on the exposure meter indicator is usually good.
    • So far I haven't noticed any 8-bit banding. S-Log2 has increasing precision towards the higher stops of its output range, so you'll minimize banding by using a higher exposure or high ISO setting.
    • In S-Log2 with zebras set to 100+, there is 2/3 of a stop of additional highlight range above where zebras are showing, encoded in the superwhite range.
    • Full-frame 1080/30p video is very sharp but has a pronounced rolling shutter effect.
    • Full-frame 1080/60p has much less rolling shutter, but the picture is slightly softer and suffers from binning or line skipping sampling imprecision. It's not bad at all, but just not quite as good as the other modes.
    • APS-C has good rolling shutter and very good sharpness both for 1080/30p and 1080/60p.
    • You can digitally zoom to about 1.3x before losing sharpness in any mode except full-frame 1080/60p, which is already a tad soft at 1.0x and just gets softer as you zoom.
    • The APS-C mode has a crop factor of 1.53x. With an additional 1.3x digital zoom, that's 2x.
    • The peaking is good, but not perfect. I find myself frequently changing the peaking level when I need to change focal lengths, and I often rely on the focus magnifier.
    • The focus magnifier works while recording video.
    • When the focus magnifier is engaged, peaking works on the new smaller scale of the magnified image instead of just magnifying the peaking, which is great for focusing precisely.
  • Thanks for the comments, interesting stuff.
    I'm curious about the focus peaking - how well does it work with Slog?
    As one thing I didn't like about it on the GH4 was it was very faint/scarse when you set the GH4 to be very flat - fine on a standard p-profile but not usable with cine-d and a low contrast image.
    Whereas on the BMPCC the peaking is fantastic and nice and strong even though the image is very flat, even in video mode.
    I'm hoping the Sony A7S peaking is very clear, like the BMPCC.
  • Good stuff, balazer. Very helpful. A question - the colors in your clips seem desaturated. Is that a personal choice or is that the way S-log2 is seeing it?
  • @andrew00, the peaking is less strong in S-Log2, but I don't find that to be a problem. The peaking level is adjustable. I usually set it to low for wide angle lenses, and high for my longest lenses. What's not great about peaking is that it only picks up high contrast details, and not everything that's sharp. So depending on what the camera is pointed at, it will light up with peaking, or you'll see just a few specks here and there.
    @Ralph_B, that's just the way it came out. I didn't touch the saturation. For comparison, here's an out-of-camera JPEG: http://www.4shared.com/download/AsuTSBSXba/Still_no_PP_ISO_320_shutter_16.JPG?lgfp=3000
  • @balazer Awesome for these downloads. Would you be able to make a few xvac s-log downloadable?
  • A7S APSC mode action shot and 120fps
    After jumping on the a7s bandwagon and getting one in the first week of availability, I got worried that I wouldn't be able to use it for anything but fully stabilized tripod shots. So I took it to a local skate park and asked some guys if they'd mind if I follow them around. I also wanted to play with the 120fps and some S-log. While the footage doesn't edit together very nicely, it made me feel a lot better about using this camera on paying gigs where motion is needed. I wish I shot the whole thing in S-log for consistency, but hey I was just playing around for my own edification and fun. All shot in APSC mode with a 16mm Rokinon Cine lens and a F&V magic arm as a handle. I don't see any Jello, do you? Loving this camera!
  • @kupchenpo looks awesome! Enjoyed that little test.
  • @kupchenpo Nice test! Could you provide us one ungraded 720p 120fps S-log2 clip straight from the camera for download? I would really like to check it with Davinci Resolve before investing in this camera. Thanks.
  • I get that it's great lowlight. I wish I could afford special cameras for a single purpose. The Sony hype train is in full gear after laying low early on. Don't believe that this wasn't a planned approach.
    4k is not a selling point of this camera, because it can't do it yet. Estimates now put the Shogun recorder at late sept now. No one knows if it will work well or even work.
    Photos are average at best.
    I'd just encourage everyone to read these two excellent reviews.
    Gh4 vs a7s this is a very practical look at which one is most usable in the real world.
    http://q8lavanda.com/8192.html
    a7s jello the a7s Achilles heel,
    http://andrewwonder.com/blog/entry/jello-shots-sony-a7s
    I'm very much on the fence about the gh4, won't decide until I see 4k with 422 color. There's nothing wrong with staying with what you have, if you are getting good results. I have a hacked GH2 and a BMCC. I haven't seen enough to make me leave what I have.
    To be blunt, the BMCC with all it's lacks and issues, puts out a more beautiful image than either a gh4 or a7s if you are a good colorist. Actually, it's not even close. Raw wins. Along with a sigma 18-35 with speed booster. That combination is hard to beat.
    I'll wait and see what happens when the already delayed 4k recorders hit the street.
  • "Photos are average at best" made me lol. It's like saying "In the A7S, the photos are not moving." Please, do post an example of an above average photo, taken with a Canon, Nikon or a Fuji DSLR. Show me what is "above average" so there is even a remote possibility of a sane discussion.
  • I would seriously consider this cam if there was a cheap way to record 2k and 4k direct to H265 external. The combination of small files and big quality would be a winner.
  • "Photos are average at best" means the photographic resolution and quality are average for flagship dslrs, actually they are below average. Other than in really dark conditions.
  • Someone know if the european version have the 24p selection?
  • I have no time to read the whole thread, due I have to take a purchase decision today. Someone know if american or no european version has 30' recording limit?
  • I believe they are all cursed with the 30' recording limit.
    Voldemort's 'evolving' review/propaganda is up. As expected, he jizzed all over himself about the High ISO ability.
