@joethepro It's very well documented in the manual.
@caveport Hm, I dont know. How do you use that? I made one, and put it in the proper folder with the other luts in c/program data/..... but it didnt show up in the list when I restarted resolve.
@joethepro No, I'm talking about the 'Generate 3d LUT' option when you right-click on the clip in the Color page timeline.
@caveport If you are talking about the "grab still" option, that does nothing to make hard stops in luminance values when applied to another clip. I dont see any LUT options when right clicking...
@joethepro You can make a LUT from a grade you have applied to a clip. It's well documented in the manual. From memory you right-click the mouse on the clip in the Color page and there should be an option in the pop-up menu.
Is there a way to set max and min luminance values for your footage? I like go to the first curves window and use the slider at the left to slightly flatten the curve. It brings out some shadow detail and gives a smooth roll-off. It ends up being a range of something like 32-990 instead of 0-1023. The problem is that you can go past those limits back to 0-1023 by simply adjusting... well... anything. I want it to clip at the slightly reduced values. Any idea how? The soft clip doesnt hold the values there either.
I just received my X-Rite Passport and have had very good results with my initial testing of Panasonic GH4 CineD profile in Resolve. VERY happy!
Is this your a7s video, Mike? I can't find it on vimeo. What conclusions were drawn? It looks like there's some color bleeding into the 2nd top row in the resolve corrected video
edit, found it
MTS files still need to be wrapped in a MOV format for Resolve 11. Resolve will not recognise them as plain .MTS transport stream files.
Do MTS files work with the latest release?
FCPX round trip now working using XML from FCPX 10.1.2
Good news. Free NLE for the poor.
Davinci Resolve 11 final just released!
I just downloaded DaVinci Resolve 11 Lite Beta onto my Macbook Pro Retina 13", and I can't resize the windows sufficiently to even use it. I can enable the window frame, but that just helps resize the full window to fit my screen... I can't adjust the individual areas sufficiently to make them fit and usable.
I have issues with the new beta 11, i can't resize the entire software window … for some reasons that I ignore is kinda stuck and to access the edit color and so on, I have to scale my retina display to a higher resolution so the entire software window gets smaller….so i can edit color etc etc.. weird..
