Is there a physical difference on between USA and International models? Or is it just warranty?
The Olympus 12-40mm f/2.8 is a lens that fills a need for a lot of shooters, and I’m happy to report it does so with excellent quality. The lens is simply brilliantly sharp across the frame right from wide open and at all focal lengths. It’s really hard to ask more from a zoom. It might be the overall sharpest standard zoom I’ve had the pleasure to use.
http://admiringlight.com/blog/review-olympus-12-40mm-f2-8-pro/
anyone coupled this lens with a LA7200?
The lens is also very sharp through all the focal lengths and at every aperture. As usual, the best is found between f/5.6 and f/11 but the results are great also at its fastest aperture of f/2.8. The lens is very sharp at the centre but also at the corners at all the aperture and focal lengths.
@crazypete Thanks! There were a lot of conflicting reports of stepping in the manual focus process but I suspected the complaints where for those who didn't know about the focus ring clutching when slid back
@dancerchris it seems repeatable to me. I tested it on my GH2 last night with the lens set to 40 mm and F2.8. I focused between a bottle about 40 cm from the camera and another in the far corner of the room ~5 meters away using a Lanparte follow focus and flexible gear belt.
I use it manually with follow focus and zoom with zip gears. Focus is definitely repeatable, zoom can always be smoother, but is better than the Panasonic 12-35. I do not see sudden exposure changes when zooming in and out as some tests online show.
It has been asked but never seemingly answered: Has anyone used this lens clutched into manual focus with a follow focus rig? Is it repeatable, i.e truly mechanical focus?
I do think that the M.Zuiko 12-40mm F2.8 Pro lens is a great lens, suitable to be used by anyone.
If you have bought an OM-D system, and intend to have a high grade lens, just one lens to cover most of your shooting needs, this 12-40mm Pro lens should be in your consideration. It is versatile, does close up shooting well, and is sufficiently wide for most situations at 12mm focal length. That F2.8 bright constant aperture is also useful in many situations.
http://robinwong.blogspot.ru/2014/07/olympus-mzuiko-12-40mm-f28-pro-lens_6.html
@Azo What @mat33 said is correct, the only thing I would add is that I don't believe it is focus by wire once the focus ring is moved into manual focus position. At that point it is clutched to directly control the focus elements as you can't hear or feel any servo moves while you can feel the mechanical resistance.
Thanks for the input and feedback. I am vacillating back and forth between losing OIS with the Panasonic 12-35 or having the Olympus 12-40 which seems to be a better lens overall with a better build quality and manual focus mechanism. This is a very hard decision but more than likely I will purchase the Olympus due to the focus mechanism and what I perceive to be a better build over the Panasonic lens. I am a stickler for build quality and the Olympus seems to have that in spades.
I don't use a follow focus but the manual focus on the olympus is very well damped and smooth with hard stops. My other lenses are all contax zeiss which have very nice focus rings and feel, and the olympus comes surprisingly close to the feel given it's focus by wire. It is much nicer than my now retired panasonic 14-45. The build quality and feel is also great, and I really like the image it produces.
I am a Nikon shooter so most of my glass is full frame glass. I want at least one zoom for M/43 that is native glass but I have some concerns. My concern is the focus by wire mechanism on all of the M/43 glass. I had and sold the 14mm 2.5 and will likely sell my Panny 20mm 1.7 as well due to the small size (follow focus issues) but mainly the focus by wire mechanism. How is the manual focus on this lens? I read that it has hard stops in manual focus mode, that being said how does it feel with a follow focus. I plan to use this with my GH4 as well as the GH2's and a AF100 if that makes any difference.
