bkmcwd "GOLGOP3-13-MAX_BETA11" - seth.ini - Released 21/08/2014
This MAX is the version in which maximum size of I-frame is used in 24p rec mode.
I think that the freezing issue at the moment of the focusing and zooming was solved nearly perfectly also in Panny lens use.
Also on towi's Death Movie, span is possible for all the rec modes.
Cautions are required to use iDRC or iA only in 720p.
Please try it! And I am very glad if I can get feedbacks from you.
*If this is also still unstable, I will further adjust.
Special thanks to all silent users of my settings! :-)
Of course, many thanks to @cbrandin and KING @driftwood!
The original matrix is adopted in the newest GOLGOP3-13. It is the middle of a Sedna matrix and a stock character. If I say plainly, it will be the Sedna matrix optimized in 3GOP structure.
Upto 140M for Top Quality 1080p24 at Q13
Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q13 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 50M for Top Quality HBR/FSH modes
Upto 50M for Top Quality 720p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available only in 24L
Fully working iA and iDynamic range modes if you require them (Take care only in 720p)
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i/HBR modes
Beautiful 6 GOP bringing short GOP style detail & movement-rendition in in 720p modes
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.
*Supposing you use "SH" mode safely, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory with iA or i dynamic range control at all.
*Although I have received the report that it was able to be used also with the slower card, I especially recommend you use with SanDisk 95MB/s 64GB SDXC card.
                  bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA5" - seta.ini - Released 20/08/2014
*All modes were changed from BETA4.5. :-)
*The problem that BETA4.5 cannot often be spaned in 24H is solved.
This TYPE-ZERO4 is also the version as which "balance of gradation and resolving" was considered in all the modes.
Although towi's Death Movie is cleared in all the modes, there is no telling whether spanning is possible in other than 24p.
*Probably, spanning is possible in all the rec modes.
Cautions are required to use iDRC or iA only in 60p.
Superb-looking Pure Original 444 matrix from @cbrandin is adopted in 24p mode
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic range modes if you require them (Take care only in 720/60p)
Beautiful 6 GOP bringing short GOP style detail & movement-rendition in 720p modes
Bush of Death / Death chart tested with Panny lens.
Top quality 2K mjpeg Mode in HD by Nick Driftwood
*Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory at all.
                  It's been a long time. :-)
Many thanks for nice footage!
Although I do not have time to test or shoot these days, I have shot after a long time.
*No grading both
GOLGOP3-13-A2 24p
Valkyrie 444 TYPE-ZERO3 24p
Testing DaVinci's intergration with Edius. Shot with the latest settings. Excellent result so far. @24p. Sorry for the Greek HipHop lyrics, but I liked the beat so much.
Hi, I'm using GOP3ZILLA4_BETA2.1, and have just tested all the video modes, but in FCP X, both FSH and HBR mode at 1080p show up as being recorded at 25i. 24p cinema and slow motion at 80% both show up at 23.98 so are ok... is there something I've done wrong or is it to do with PAL NTSC differences?
bkmcwd "GOLGOP3-13-A2_BETA13" - setj.ini - Released 07/07/2014
This A2 is the version in which spanning is possible in all the rec modes.
Upto 110M for Top Quality 1080p24 at Q13
Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q13 in 24H mode with 80% Slow-Motion Mode (No Sound)
Upto 50M for Top Quality 720/50p modes
Upto 50M for Top Quality 720/60p modes
80% Slow-Motion is available in 24H and 24L both with
In camera playback is available in all rec modes,
                  Many thanks for feedback and so sorry for my reply delayed.
did you have a chance to use it on Class 10 card you mentioned for a longer time, for example 20minutes of constant recording.......because 85mbs sounds really high for a Class10 sd card
Sorry, I was referring to the GOP3ZILLA4_BETA2.1 Hack.
@bkmcwd hack is really reliable tested on a standard A-Data 16 GB Class 10 SDHC Card and no hiccups especially against my bush of death. in 24p I received average speeds up to 84mbs, and 720p 60p speeds up to 44mbs.
@ GOP3ZILLA lovers :-)
bkmcwd GOP3ZILLA4_BETA2.1 - setg.ini - Released 11/06/2014
I release the new version of "GOP3ZILLA" setting.
In this BETA version, the FB settings are adjusted more appropriately. I think that this is further stable from previous GOP3ZILLA settings in HBR or 720p.
Please try it! And many thanks for your feedbacks!
Superb-looking modified stock matrix is adopted in all the modes
Upto 110M for Top Quality 1080p24 at Q15
Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q15 in 24H mode with 80% Slow-Motion Mode (No Sound)
Upto 48M for Top Quality HBR/FSH modes
Upto 48M for Top Quality 720p modes
*Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory with iA or i dynamic range control at all.
                  @dado023 Hi,
Since the test in a slower card is endless, I myself am not carrying out. And I am glad if the results are fed back to me. :-)
bkmcwd GOP3ZILLA4_BETA2 - setg.ini - Released 31/05/2014
In this version, the GOP tables are adjusted more appropriately. I think that this is further stable from previous GOP3ZILLA settings in HBR or 720p.
                  bkmcwd natural3_BETA4 - setf.ini - Released 11/05/2014
*Only 60p mode was changed from BETA3. :-)
This natural3 is the version in which spanning is possible in all the rec modes.
Upto 110M for Top Quality 1080p24 at Q18
Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q18 in 24H mode with 80% Slow-Motion Mode (No Sound)
                  Thanks for your comment! :-)
what exactly is the difference between your BETA Team matrix from that hack and the matrix of the natural3 Hack?
The stock matrix is applied to natural3 almost as it is.
444 matrix which @cbrandin devised is modified and applied to Valkyrie 444.
Which of your hacks would you recommend for sharp vintage manual lenses (still smoother than panny's of course)? And would you actually recommend these over flowmotion v2.02 for possible grading?
I recommend you Valkyrie 444 TZ3 or TZ4 to you. That is because the matrix which attached greater importance than to resolving to gradation is applied.
I am glad if I can hear the comment on which you tried it.
Hey bkmcwd! First of all - Great work! I was a silent user for many years, settling for flowmotion v.2.02. It never failed on me. Now I got curious about a month ago and checked out Moon T7, but its crashing everytime i try it out. I think it's because of me shooting in PAL usually, but also I'm using Sandisk Extreme 45MB/s Cards which may not be fast enough. Your Valkyrie Type Zero 3.1 worked very smoothly today when I used it on a small weekend hobby shoot. But I'm curious - what exactly is the difference between your BETA Team matrix from that hack and the matrix of the natural3 Hack? Which of your hacks would you recommend for sharp vintage manual lenses (still smoother than panny's of course)? And would you actually recommend these over flowmotion v2.02 for possible grading? (since Moon is not really working for me)
Thanks for these great settings!
