I use Naztech Power Bank batteries - they cost a bit more, but I get long life and reliability. They have a variable output - the 9v setting should work with your gh4
He did that because of me lol. It was $89 when I looked at it. I asked about the item and he realised he was out of stock. He said he would put the price up until more came in late next week to avoid orders....
A friend told me this afternoon that he has tried these batteries and they dont perform well. The search continues.....
careful, the price on that ebay link is set to over $1000 even though the past items sold for ~$90. even though you see a lot of 'sold' items, be wary.
I think it would - use the 9v output and you should be good
Thanks for info mrbill. Do you have a link to the gear you put together ?
@s_maurice - don't use any gh2 parts. The gh3/4 mains unit is the same as they share the same battery. You need to go from your battery source into a voltage regulator (I mounted mine in a small plastic box) then from the regulator into the battery adapter. I have mine set to 8.8v and it works great.
Hope this is in the right thread. Just ordered a GH4 and trying to get a AC power solution ordered as well. I have a GH2 Panasonic AC adaptor. Do I just need the GH4 Battery Dummy (DMW-DCC12) to plug into that? Or is it a different voltage etc? If I buy the Panasonic ac adaptor ( DMW-AC10 ) is there anywhere on cam to plug it in without the DMW-YAGH unit? Got some jobs booked for end of the month and need to get this sorted. Thanks for any input
The PB70-GH4 PowerBase-70 Battery Pack is a 77Wh, 14.8V Lithium-ion battery designed to extend HD recording time for the Panasonic GH4. This battery pack comes with a base that accommodates the battery and a battery paddle to insert into the camera. It included GP-DV-GH4 Interchangeable Regulator Block and has a 12" cable. The PowerBase-70 delivers 6 times more power than the original battery supplied with the camera.
It is also intended to streamline your recording: the PowerBase-70 mounts under the camera and doubles as a grip, or can be attached to a camera support via its 1/4"-20 release plate or V-mount. Wired as a 14.8V battery pack, it can provide extended power for up to two additional 12VDC devices such as lights, monitors or HD converters as well as other devices requiring lower voltage (an optional XP power regulation cable is needed). The pack is also furnished with 1/4"-20 threads on either side to mount accessories.
So I got the voltage regulator in place and is now feeding enough power to my camera. So just wanted to post some photos of how it's currently rigged. Kind of ugly -- wish I had a case... right now it's just held together by electrical tape and velcro.
@Vitaliy_Kiselev Ah I see. I measured the DC off my GH3 coupler and I'm registering 9.3V. If that is the case, perhaps tapping off of the 9V output of my external batt is no longer enough power, and I would have to use the 12V output and step down to 9.3
You got it wrong. Panasonic bodies measure voltage, if it is above certain level they assume that it is AC adapter connected and do not make any checks. If it is below this level they run special checks ensuring that proper (read - bought from Panasonic) battery is inserted. Usually third party batteries try to look at AC adapter also, at least cheap ones :-)
Gotcha. I measured the output of the GH4 battery and it was something in the range of 7.8v. I measured the external battery which I used with the GH2 and it was around 9.0v I guess a bit too high for GH4 (but worked generally well for GH2). I'm going to pick up some voltage regulators off eBay as well to lower the voltage.
I think this is good place to look - http://www.personal-view.com/talks/discussion/5356/powering-gh3#Item_62
