Japan Display just presented what looks like the right display for your next 4k field monitor: http://www.j-display.com/english/news/2014/20140423.html. :-)
| 【Specifications】 | |
| Display mode | IPS |
| Screen size (diagonal) | 10.07-inch (25.58cm) |
| Number of pixels | 3840 (x RGB) x 2160 (4K2K) |
| Resolution density | 438 ppi |
| Dimensions | 231.6mm (W) x 140.9mm (H) x 2.35mm (D) |
| NTSC ratio | 71 % |
| Contrast ratio | 1100:1 (Typ.) |
| Viewing angle | >160 degree (CR>100:1) |
| Surface luminance | 400 cd/m2 (Typ.) |
| Power consumption | 2180mW Backlight 1800mW (at white 400cd/m2) Panel 380mW |
You can post specs to http://www.personal-view.com/talks/discussion/comment/168333#Comment_168333 were this news already reside.
