  • 3230 Replies sorted by
  • Pretty impressive DR on the GH4 with Cine-D, it does seem superior to the BM in shadow detail with the untouched files. That's not to say there isn't any more to be found in the ProRes files but what will the noise levels look like after they're lifted?
  • That's a little bit of a rough test. Were they all supposed to be graded different? Did you use a vectorscope to get the skin tones there?
  • Obviously gh4 takes exposed incorrectly (compared to Driftwood test) but ... judge yourself.
  • If you go to hangouts here and start at minute 17 or so there was kind of a NAB panel discussion on '4k in Film' centred around the GH4. http://us.panasonic.com/lumixlounge/
    I turned it off after awhile but might be of use to someone. I feel like Panasonic has so much to offer and is so funny about getting information out there.
  • First announced HDMI 4K recorder (can do 10 bit 4:2:2) -- Atomos Shogun:
    http://www.personal-view.com/talks/discussion/10085/nab-atomos-shogun-4k-recorder#Item_9
  • @natureflixs
    Cine-D isn't actually log footage, but it should probably be treated in a similar way, at least until we learn better. What this usually entails, with actual log or log-like footage, is putting an appropriate s-curve or LUT on the last node of the grade, to normalize the gamma before you go to work refining the look, on earlier nodes -- this way, everything plays through that final normalization. Otherwise, there are likely to be errors in the way the light values get mapped, thanks to characteristics of LOG footage, which is optimized for capturing maximum range, not an accurate representation.
    Or you can just adjust levels in an NLE-- pull the blacks down to zero and the highs up to 100 -- and hope for the best as you refine the grade and work with the mid-tones. This step alone would vastly improve the appearance of most of the BMD "film" footage which gets posted here, but it apparently isn't being done in most cases.
  • OK, I was looking at it as simple write throughput but should be looking at it as total encoder processing throughput instead. So it's a math crunch issue rather than an offload pipeline issue?
  • Panasonic said they couldn't get more than 100Mbps in 4K due to throughput but I'm not completely certain that is true with the "other" 200Mbps codec existing in the camera for HD.
    It means that it is good idea to read something about codecs :-)
    4K 200mbps is not equal to FHD 200mbps. 4K codec has many areas with big overhead compared to FHD, so it become very hard add to this high bitrate.
  • Based on the footage I've graded thus far it seems the internal codec could surely benefit from a boost up to the 200Mbps range. That would give it 50Mbps per HD quadrant just like the GH3, which never seems to exhibit any macro breakup issues with heavier grading. Panasonic said they couldn't get more than 100Mbps in 4K due to throughput but I'm not completely certain that is true with the "other" 200Mbps codec existing in the camera for HD.
  • @jrd
    Obviously there will be plenty of more water under the bridge before it's possible to say anything conclusive, however, I really liked the look of cine-d from the video on the previous page (or was it 63?) in harsh lighting. Such scenarious have usually tended to turn out chunky on the forerunners in the gh series. Now your typical beach shots looks far more pleasant in highlight rolloff.
    Should be some interesting encoder tests when the final product is available.
    @natureflixs
    Keep in mind there is some heavy speculation going. These things will be thoroughly tested once the camera is out on the market, for sure.
  • So in overcast low contrast situations shooting in cine-d is applying a s-curve the only way to go or is there some other camera setting to use.
  • @RRRR
    Based on very limited testing with posted footage, I'd be more worried about how the codec handles high contrast/saturation. Others seem to find the footage highly gradeable, but I'm getting unpleasant results when attempting a heavier grade. It goes plastic -- dreaded word! -- very quickly.
  • @jrd: it does bring out macro-blocks in monochromes, like discussed a few pages earlier. Obviously, if you want a desaturated look it's not a bad start.
  • @EliasD at Adorama, Amazon does not ship to Germany and I don't remember what it was but there was something that kept me from ordering at bhphotovideo
  • Agreed about cine-D! On @driftwood's "Man in the Hat" footage in PP CS6, just throwing on a fast color corrector, bringing the blacks and whites in a touch on the slider, and then adding about 28% saturation made the footage look phenomenal to me. Talk about an easy grade!
    BTW, regarding playing the 4K footage, initially I was only able to play it on my personal computer within PP CS6 because my VLC Player didn't like it. I have to test more with a recent release, but I noticed that on my wife's computer and my daughter's computer that I built recently, it played perfectly and I had VLC Ver. 2.0.8 on them. One of them is an i5 2500K with NO VIDEO CARD. The other is an AMD 6350(?) 6 core with a Radeon HD 5570 video card. Perfect play on both. After uninstalling VLC on my computer and reinstalling 2.0.8, it plays perfectly as well. All of these computers are running Win7 Ultimate.
    Just for fun I put the latest Quicktime on my computer for a minute, and it played the footage fine too. Mine should play it fine though, it is an i7-3770K with 16gigs of fast RAM, and GTX760.
    My slowish i5 laptop was having trouble with playing it in VLC, and that has a recent release version of VLC on it. I'll swap 2.0.8 back onto that soon and see if it does better with it.
  • @RRRR
    Don't think you have worry much about low saturation/contrast in cine-d. This is a driftwood shot with nothing but a mild s-curve applied:
    2304 x 1296 - 286K
  • @olli66, where did you pre-order us model? thanks
  • I'm thinking, CineLikeD looks great for situations when you want to preserve maximum latitude, in other words hard contrast shots. For overcast days I'm guessing that it will pay off to have a lot more punch in colors and contrast. Depending on the look you want and how clean you want the end result, of course. :)
  • thanks for the info driftwood I pre-ordered the US model, I need it for continuos shooting (concerts) for as long as the battery and space on the SD card lasts so I will order myself 2-3 Sandisk 95 MB/s cards now... how many people will buy the new expensive SD cards? great marketing move for filling the pockets even more
  • Sandisk 95MB/s cards will record till you stop the recording (e.g. 30 mins)
    Here's some more screen grabs from forthcoming 'GH4 People Test'. Ungraded CineLikeD of course.
    2048 x 1152 - 1M
    2304 x 1296 - 1M
    2560 x 1440 - 2M
  • I have quicktime installed...but an older version...some of the new versions always gave me a black screen on some mov files in Vegas so I didn't install newer versions...never change a winning team! but when those new files now don't work I have to update I guess...hope my old files will still play then (some even were upside down depending on the quicktime version)
  • I couldn't import that original mov file into Movie Studio Platinum until I installed Quicktime, then it worked great.
  • @mrbill I know, but he still wanted to do a long run with highest bitrate settings and report...
  • @olli66 - go back a few pages to driftwoods post - he talks about shooting 4k on older cards there
