  • 3230 Replies sorted by
  • I think it's about time Metabones get on with an active EF > MFT.
  • @kholi Would be awesome. Seems like it´s a pain to couple EF and MFT actively though, as so very little has happened over the years when it comes to this. Hope they solve it!
  • For the GH5 Panasonic needs to develop a 4096 x 3072 native resolution sensor to allow the 4096 x 2160 video without horizontal crop in the micro four thirds sensor, better shallow dof, better wide angle and better low light due to increase in pixel size. Also it will be good for still photos because 4096 x 3072 is 12.6 megapixels, enough for most photo work. Dynamic range increase to reach ARRI is the most expected improvement in the Panasonic now... maybe this will be implemented in the organic sensor they are developing. And why not 200Mbps IPB in 4k?
  • This claims to be some slow motion footage of the GH4. See the Youtube comments.
  • There are also some 4k clips from 2011peopleasia:
  • @anti12 Good moire test at the end of that first clip -- closeup of a man's checked shirt. I think it's not bad at all considering how tough the test was. I bet it would look clean if downsampled to 1080p.
  • @apefos I thought this was the GH4 thread? :P
  • @apefos or you can just purchase an ARRI. Panasonic didn't have to make a GH4 but they did and according to the specs/videos out there it meets if not exceeds most expectations, especially considering its price point. I don't believe pushing the GH4s native resolution or DR will make any of us a better videographer, at least not for quite some time.
  • @jamesgh2
    Neat video is a noise reduction and artifact plugin for a variety of editors and effects packages I used it in After Effects CC to get rid of noise and block artifacts quite effectively. It lost just a small detail level but cleaned up very nicely. Then used color correction tools on top and played with the image its quite a good codec.
    After you run NeatVideo on a 4K H.264 video you'll want to use an Unsharp Mask filter on it to completely obliterate any remaining original image details.
  • @LPowell
    Yes if you use defaults or auto area sampling. I have carefully made gray samples for all my cameras at different ISOs which I use and tweak them accordingly even after applied. I sell my work to all major networks and even some A film studios and I have yet to receive a complaint of compression.
    For the GH4 face footage I used a GH2 ISO 400 preset I made and enhanced it by reducing the effect in most color levels and the luminance to be very mild as I have no access to the camera to create a profile. The macroblocks tend to disappear because with movement it can tell between 2 or more frames that those are artifacts and constructs a less blocky image in the end by averaging but also because it it tuned to work with macroblock footage and detects it as an undesired artifact. As for the Cascade footage if it was available it will be useless even with this technique as there is no information of importance between two frames that quickly.
    If you apply defaults in Neat Video be prepared to loose most fine detail and end up with wax figures. you are right, you have to know what you are doing with it.
    Once my preorder fills and I get the camera I'll try to do some workflow comparisons. BTW I admire your work on the GH2 hack, has served me well this past two years. Thanks!
  • Someone mentioned that the GH4 will be in Park Cameras, in London. This is incorrect.
    It's actually going to be at Park Cameras in Burgess Hill, Address: Victoria Business Park, York Rd, Burgess Hill, West Sussex RH15 9TT
    https://www.facebook.com/photo.php?fbid=10152234431007570&set=a.277393362569.144137.16669522569&type=1&relevant_count=1
  • @jamesgh2 Hi, really interesting point on how to use neat video..would you mind sharing your gray samples for gh2?
  • @formalhaut3
    Record 10 seconds of a neutral gray or 50% gray card that fills the frame and make sure the exposure histogram is in the middle with no under or over exposure this is for every ISO in this case 400.
    Step 1 : Use that footage for your neat video profile sample and then tweak the settings to the minimum values you can dial down in order for the footage to still have organic noise but very few artifacts. Save this as a preset.
    Step 2 : Use footage of a detailed scene be it nature or a studio setup with fabrics and apply the preset. Now enter the advanced interface for the effect and play with the Y, Cr, Cb and their NR amounts and Noise Levels and lower them in order to match the amount of detail you want to preserve. Less is better as you only need to get rid of the electronic noise and preserve as much detail as you want.
    Step 3 : Ad digital Noise in post by the Add Grain or Ad noise effect conservatively like 1.3% and or use Noise plates. It will make the footage more organic and help with banding inherent in the GH2 codec.
    I added my ISO 400 GH2 Preset for reference which can be used with the GH4 face footage with minimum tweaking.
    GH2Iso400PresetNeatVideo.zip
    10K
  • @fomalhaut3 @jamesgh2
    Please use proper place for this discussion, like topic we have about Neat Video.
  • @AdamT Moire and aliasing should be minimal on the GH4 compared to other DSLR's. The higher resolution and especially the lack of line skipping will make edges very fluid.
  • @Vitaliy_Kiselev
    I should have known better, sorry about that!
    @IVIaverick52
    On the Yucatan video the Aliasing artifacts on the Macaw were confirmed to be on the original footage with pretty bad results too by the author. However every camera even Film has a hard time interpreting these patterns as even human vision can see them to some extent on the feathers "I have shot many of these birds in the past". However looking at fine textures it seems it will be an improvement over the GH3 and even the GH2 regarding aliasing. Since the GH4 is using a cropped EX Tele like mode for the 4k it should have minimal to no aliasing like that on the GH2 EX Tele mode.
    What I am most worried about 4k is the amount of noise it will produce in that mode. The GH2 EX Tele is full of noise and banding depending on the brightness level inside the image. Maybe the NR algorithm is doing a good job to suppress that in 4k. Also if the EX tele mode is still in there for 1080p which it seems it is, it will benefit from that new NR tech. Which in itself is worth the upgrade alone in my case as I use EX Tele on the GH2 a lot.
  • @ahbleza
    The AF in the first clip looked very good. Watch the blue truck in the background. Watch how the words on the truck blur very consistently as they run towards the camera. It looked like M4/3s depth of field and AF for that matter.
  • Watching 4K on youtube is like kissing your sister. You think it will be OK until you try it and then you realize why no one else does it.
  • @jamesgh2
    I guess that is why they have made efforts to minimize noise from the sensor.
    On a side note, the gh2 image still can kick some major ass. It just look really darn good in many situations despite all it's limitations (and of course we owe a lot to Driftwood and others for that). While cameras keep getting better and specs get all the more ridiculous for ridiculous prices - it's clear as day that tech is very unrestricting these days. The hand and eye that wields the image (and the mind behind what's told) is everything. Getting back to the gh4, I really hope it continues panny's tradition of making sensors that produces beautiful images.
  • Panasonic GH4 vs Blackmagic 4K by 2011peopleasia:
  • To me, it looks like GH4 have greater dynamics range and resolves more lines. Im little bit worried about GH4 skin tones and "vividness" of the colors and curve. I hope there is more s-curve type picture profiles available (like gh2 "smooth" or "nostalgic"). :/
  • What this "variable frame rate" mean in practice? How does it differ from shooting with "normal" frame rate?
  • @blackspot It's difficult to compare log footage to rec709, but I have to agree that highlights appear to clip in BMPC4K before the GH4 (without any visible increase in shadow detail). The uploader also claims more dynamic range is recoverable in Resolve with the GH4 files. Very interested to see what the cine-gamma modes look like as my understanding is that they are still not available in the preproduction firmware and testing to date has all been from the "standard" color profile. We could be in for another surprise as far as DR is concerned.
  • @mpgxsvcd not sure what's going on on your end, but most of the 4K Youtube clips I've seen look fantastic, at least compared to 1080p Youtube clips.
