Fotga makes serious progress with their FF
    Fotga made Tilta like follow focus, but for guys who can't afford original :-)
    • This DP500 II follow focus is improved based on the previous DP500 version I follow focus.It is consisting of a improved dampened gearbox,which promise no backlash or less backlash(<0.5mm).There is a button downside can adjust the tension of of the gearbox to reach 2 dampen level.
    • Gear wheel on it can be detached and insalled in other side,which makes it suitable for both left-hand and right-hand photographer.
    • The white mark ring is made of magnet material.It can be detached or attached very easliy and quickly on matel-made follow focus.You can also buy additional mark ring.
    Specifications:
    • Material: aluminum (gear wheel outside is made of ABS material)
    • Improved design has dampening which gives virtually zero backlash(<0.5mm).
    • Long-life precision engineered gearbox enables accurate and reliable focusing
    • Compatible with industry standard Follow Focus Whip or Crank.
    • 2 levels adjustable dammping.
    • Gear drive can be mounted from both side.(Works for both right-handed and left handed)
    • This set includes flexible gearbelt can be used with any zoom or prime lenses with a wide range of lens diamters(any size from 46 to 110mm)
    • Adjustable locking systems
    • Mounts onto 15 mm Rod Support (60mm center to center difference).
    • MOD Drive Gear: Industry standard 0.8
    • Compatible with industry stand 15mm rods
    • Weight:425g
    Price: See our deals.
    Available at:
    http://www.personal-view.com/talks/discussion/562/special-deals-matteboxes-hoods-and-follow-focus
  • 94 Replies sorted by
  • Does anyone know where I might find a replacement gear for a dp500ii (Not S)? There are tons on ebay that claim to come with the adapter for DP500ii since they sell the updated DP500iiS gears (different teeth inside gear).
    I've purchased 4 times and it never comes with the adapter. Every description and photo on ebay clearly shows the adapter and lists it as both needed and included for DP500ii. They seem to all be wrong and no longer included.
    Has anyone bought one that did come with the adapter? Anyone have one to sell? My gear teeth have worn and no longer works.
    Thanks
    Sorry for digging up an old thread. Seems the best place to find one for this old model.
  • So far 3 of 4 items I ordered on 11.11 have shipped. The unshipped items have 1 day left to ship. Not sure if there's anything strange about that, I think they had a lot of orders. However, I am still waiting on something I ordered on Oct. 1st, that shows it shipped and left China, just hasn't arrived in the USA yet…, the seller said to wait another 2 weeks. It's a really slow way to buy stuff, but, if the price is right, people will do it.
    I bought an MP3 attachment for my car stereo last year, the item was crap (worked, but, not well) , so I exchanged it for an older one which works great. It's a PITA to return things to China bought on Aliexpress (at least that's what I am thinking today) but in that case something I couldn't have gotten in the USA at all.
  • I placed an order for something on 11.11 on Aliexpress and it hasn't shipped yet. If it doesn't ship by end of day Thursday the 17th, they will automatically refund my money. I wonder if they ever had any intention of shipping it in the first place, for the amount I paid.
  • @CFreak
    Most of this 11.11 discounts are fake on Aliexpress.
  • Looks like the Fotga DPIII is out. FYI, these things are 10% off on AliExpress for another 2 hours for their 11.11 sale:
    https://www.aliexpress.com/item/FOTGA-DP500-MARK-III-Dampen-A-B-Hard-Stop-Follow-Focus-for-A7-A7II-BMCC-F55/32596479121.html
    There is also an adjustable arm now available, the teeth pattern makes me think it's only for the DPIII it won't work on my DPII.
    https://www.aliexpress.com/item/FOTGA-Rocker-Arm-Extension-for-DP500III-Follow-Focus-Rig-5D3-A7-A7IIS-A7R-A7RS-GH4-C300/32624881118.html
    They seem to also be available on Ebay and Amazon without an 11.11 discount.
  • Tried latest DP500. Really good and very affordable thing.
  • Now to figure out the best way of getting this to India
    You can just wait weekend, I'll try to add most of DP500 stuff to deals, I think we could organize shipping to India.
  • Thanks Vitaliy. Now to figure out the best way of getting this to India
  • What's the main difference between the DP500II series and the DP3000 M series? Looking for a follow focus for a single shooter mainly.
    DP3000 has some plastic parts.
    Also gears and play is much better in DP500. And get as set of different gears.
  • Hi all. What's the main difference between the DP500II series and the DP3000 M series? Looking for a follow focus for a single shooter mainly. So trying to keep the rig as compact/light as possible. Will be using with photo zooms mostly so the focus throws are usually short. TIA
  • Try to carefully disassembly everything you can (filming process :-) ). It can be either loose screw that fixes knob to shaft. Or it can be gears.
  • I need some advice on a Fotga repair question. I have the older follow-focus rig, the one with only one marker point. It works fine, but there's a bit of play, or looseness, between the turning knob and the gear. I have to twist the gear a bit before the lens gear engages.
    If there a way I can tighten this to reduce this play? Or is it worth buying the newer Fotga unit (or a different unit)?
  • I should amend my previous comment: Fotga sent me the quick-attach rail mount in the mail afterwards. Thanks Fotga!
    Response like this is valuable to me, and I thought I'd share it with the rest of you.
  • I love mine, but the one thing I wish I can do is get a 2nd screw knob and attach another gear on the other side of the gear box, but I can only find some long screw that's for another version of the Fotga FF.
  • I got my Fotga DP500S2 in the mail today from Vitaliy's great catchit sale a week or so ago. It seems exceptionally well made for this price range, and my only complaint would be that it doesn't have the quick-attach rail mount shown in the picture but rather a standard slip-on-the-front rail mount, so it's a little less handy than I expected for just tossing on the rig as needed - you'll have to remove the mattebox to put it on. But otherwise, it's got all the features you'd expect: excellent feel with negligible backlash (not "none", but you'll have to spend over a grand to get "none"), gear that can go on either side of the drive box (not reversible, but side-swappable), and solid aluminium construction. I'm very happy with the purchase.
  • Got my dp3000 follow focus today. What an upgrade to my old DFocus v3, which was more than twice as expensive!
  • Just received a Fotga DP500II from eBay and immediately noticed that the resistance is not consistent throughout the 360' rotation. It would be smooth thru about 70% of a full circle and much tougher in other 30%, which is a big issue for an FF. Has anyone had such an experience? Shall I request a replacement, or will it resolve itself after a bit of use?
    Thanks in advance!
  • And some others, too. In these cases, while I am turning the wheel on the FF, it sort of turns internally without being able to transmit the movement to the lens' focus wheel.
    Something tells me that it is badly fixed FF knob.
  • Vitaliy - or anybody who has the experience with Fotga DP500 ii FF: My Fotga DP500 II S is very new to me, so far testing with different lenses. Unfortunately some lenses are stiff to focus, which causes the FF not to be able to turn the focus. I have e.g a Sigma 10-20mm f/3,5 that I otherwise so much like to work with - but not possible with the Fotga DD500 II. And some others, too. In these cases, while I am turning the wheel on the FF, it sort of turns internally without being able to transmit the movement to the lens' focus wheel. Is this "normal" for the FF-mechanism? Meaning that I just need to be sure that the lens is suitable for a FF? I have e.g a Sigma 10-20mm f/3,5 that I otherwise so much like to work with - but not possible with the Fotga DD500 II. Thanks, Gert
  • This is getting a little off topic, but does anyone know of any kind of band or belt that could be used to effectively reverse the drive of this follow focus? So rather than a gear driving the lens directly, the gear would drive a belt, which wraps around the lens (geared or ungeared). This could be an easy way to reverse the direction of a follow focus unit. For that matter, a very large diameter lens gear could maybe be turned inside out to have the same effect.
  • @Sangye @Vitaliy_Kiselev The Edelkrone FocusONE PRO too ;)
  • @Sangye
    As far as I know only Lanparte has optional reversing wheels.
  • I've been using this follow focus for about a year and a half now, and it's still every bit as rock solid and reliable of a device as ever. However, I recently picked up a Sigma 18-35 f1.8 for Nikon, which has an opposite focus throw from the rest of my lenses. Here's my question: is there any way to reverse the gear on this thing? I just can't get used to turning the wheel away from me, in order to focus closer. For now I'm mounting it upside down to my top rails, but that looks kind of silly...
  • Vitaliy is there any good fotga for Canon 5D mk 3 i just sold my GH3? thnk you
    What do you mean? What makes the difference here?
