Audionamix® announces the release of ADX TRAX™, unique audio separation software built on the company's proprietary ADX® Technology. ADX TRAX separates full mixes into two audio files: a vocal track and its accompanying music track. This cloud-based technology allows musicians, mixers, audio engineering professionals and producers to achieve superior vocal isolation for a number of creative applications. The company is demonstrating ADX TRAX (booth #7523 in The Venue) at The NAMM Show in Anaheim, which runs January 23-26, and it is available to download at Audionamix | Superior Sound Separation Software & Services.
"ADX TRAX puts a piece of our innovative, melodic source separation technology into the hands of the professional music community," says Rick Silva, VP of Production and Product Manager at Audionamix. "We've designed TRAX to be a user friendly tool for speeding up the labor-intensive task of creating vocal isolations and instrumental tracks. By utilizing the power of cloud computing, the process is now automated for quick, high-quality results."
ADX TRAX features intuitive navigation and editing tools in an environment that is familiar to all DAW users. The software is unique in that it has the ability to perform separations on mono, as well as stereo recordings, and it is compatible with multiple file formats, bit depths and sample rates.
All-in-one AV Mixer with built-in USB port for Web Streaming and Recording
The Roland VR-3EX is the next generation 4-channel SD performance mixer which features HDMI inputs/outputs, USB streaming, HDCP support, built-in touch multi-viewer, an audio mixer all in a compact portable unit.Designed to be a live production switcher thebuilt-in audio mixer with up to 4 frames delay to “lipsync” your video source. Scaling on the output allows you to output up to 1080p HD Video and Audio quality.
- HDMI & Composite Inputs
- Standard Definition 16:9 Mixing Engine
- Scaled Output up to 1080p
- Advanced 18 Channel Audio Mixer
- USB 2.0 for 480i Streaming
- 2.5” Multiview Preview Monitor
- Pnp, Key and Video Effects
Behringer
ULTRADRIVE PRO DCX2496LE
The ULTRADRIVE PRO DCX2496LE is the answer to making your venue sound like it was tuned by the pros. Over the past years the DCX2496 has become an industry standard and several hundred thousand units have been employed in high-end touring as well as install applications. The new DCX2496 "LE" version offers the same impeccable audio performance as the original DCX2496, but with reduced functionality as many customers do not require the digital inputs and outputs of the standard version. The DCX2496LE is the perfect way to manage a multi-speaker sound system in any sized venue – from cinema to sanctuary to concert hall. Featuring 2 inputs, 6 outputs and 24-bit/96 kHz high-end AD/DA converters, this state-of-the-art processor will take your system to the next level and beyond.
http://www.behringer.com/EN/Products/DCX2496LE.aspx
X-Touch
Universal Control Surface with 9 Touch-Sensitive Motor Faders, LCD Scribble Strips and Ethernet/USB/MIDI Interface.
http://www.behringer.com/EN/Products/X-TOUCH.aspx#softwareContent
X-Touch compact
X-Touch mini
All presented Behringer products - http://www.behringer.com/landing/beh_namm_landing.html
MOOG THEREMINI
Assistive pitch correction allows each player to adjust the instruments level of playing difficulty. At the maximum position, the Theremini will play every note in a selected scale perfectly, making it impossible tonplay a wrong note. As this control is decreased, more expressive control of pitch becomes possible. When setnto minimum, the Theremini will perform as a traditional theremin with absolutely no pitch assistance.
A built in tuner supplies real-time visual feedback of each note as it is played, as well as its proximity tobperfection. This is useful for correcting a users playing position, or to educate younger players about pitch and scales.
The presets section allows you to select from 32 wavetable-based sounds, store a selected scale & root note, set and recall a specified playing range, and specify per-patch settings for the included stereo delay.
For live performance and gestural control, the rear panel features two line level audio outputs, a pitch CV output with selectable range, and a mini USB jack for MIDI connectivity.
- Pitch correction w/ selectable scales and root note
- Built in tuner allows you to learn pitch and scales
- 32 Wavetable based presets
- Built in speaker
- Headphone output
- Two 1/4" audio outputs
- Single Pitch CV output w/ selectable range
- User selectable scale and root note (stored per preset)
- User selectable range: highest note and lowest note (stored per preset)
- Adjustable Stereo Ping-Pong Delay
- Removable pitch antenna – built in storage compartment on bottom-side
- Built in 3/8” Mic stand and Camera stand adaptor
- High quality rubberized feet
KORG
TRITON controllers range
TRITON taktile controller feature a stylish design that projects a sense of presence, together with the same great-feeling semi-weighted keyboard that's used on synthesizers and music workstations such as the KingKORG and KROME. It's loaded with functions that make it fun to play and use, such as a touch pad inherited from the Kaossilator that lets you play melodies using just a single finger, trigger pads that let you generate chords in the key and scale of your choice and an arpeggiator that includes rhythm patterns. Of course, the taktile and TRITON taktile also delivers the functionality that you expect from a MIDI controller. It provides all of the basic controllers such as sliders and switches, and makes setup easy so you can start producing music right away. Convenience is not the only attraction of TRITON taktile; it's a MIDI controller that's full of features that will stimulate your creativity.
TRITON taktile adds 512 sounds from the TRITON, KORG's best-selling music workstation loved by top-ranking musicians around the world. From your desktop to live stage performances, it's a USB MIDI controller that you can use in any situation.
Tackile controllers range
Taktile features a stylish design that projects a sense of presence, together with the same great-feeling semi-weighted keyboard that's used on synthesizers and music workstations such as the KingKORG and KROME. It's loaded with functions that make it fun to play and use, such as a touch pad inherited from the Kaossilator that lets you play melodies using just a single finger, trigger pads that let you generate chords in the key and scale of your choice and an arpeggiator that includes rhythm patterns. Of course, the taktile also delivers the functionality that you expect from a MIDI controller. It provides all of the basic controllers such as sliders and switches, and makes setup easy so you can start producing music right away. Convenience is not the only attraction of the taktile; it's a MIDI controller that's full of features that will stimulate your creativity.
Synth studio
ALESIS
Alesis introduced a $199 wireless Keytar controller called Alesis Vortex Wireless.
Key Features:
Alesis introduced the new V Series and VI Series of full-size keyboard/pad controllers
Alesis V Series (V61, V49, V25) combine velocity-sensitive keys with eight drum/trigger pads.
Specs:
The Alesis VI Series (VI61, VI49, VI25) has semi-weighted keys and aftertouch.
Specs:
AKAI
MPK261 Performance USB/MIDI Pad & Keyboard Controller
EWI 5000 Wireless Electronic Wind Instrument
See more info and smaller models at http://www.akaipro.com/tradeshows/wnamm2014
