Sorry if this question is a bit silly, i just want to be absolutely correct about the use of this thing but using search didn't give me the answers, most likely because m42 in other words is a screw lens adapter itself.
My adapter has a tiny screw inside the barrel that mounts to the camera. Is there any reason for it? I guess it is there to help to fit the adapter in case it is not 0.1 mm perfect or to fine tune focusing, but i´m really not too sure.
Thanks for the info! Yea, it makes kinda sense. : ) I found that the c-mount adapter also has this thing. I edited the topic of this thread, should be more searchable to others with same question.
It is not adjustment screw. It is stop screw present on many adapters. Prevent you to turn adapter too much / in different direction or insert it wrong.
Sorry about that, i posted there a long time ago and nobody seemed to know or answer. Here is the tiny screw i was thinking about: http://i.imgur.com/VKpiMGF.jpg There also seems to be some torx-like thing : http://i.imgur.com/ZdppaLx.jpg Is there any practical reason it to be/exist there? : )
Make some photo, I also suggest to use existing topic about m42 adapters - http://www.personal-view.com/talks/discussion/comment/144881
