At first glance, one might conclude that the USH-I cards are the way to go. But look closely at the chart "Write Throughput: h2benchw 3.13" on page 12. It looks like the Sandisk Extreme (16GB, Class 10) would be best for our purposes.
Whatever setup one uses to compare GH1 and GH2 seems subjective. Interpreting results is subjective, too. In other words... don't waste your time on it that has little or no value which is subjective statement by itself.
"Mount a GH2 on top of a GH1 with the same settings and pan."
Watched all the videos and did it myself. Looks different. I'm asking for a scientific approach, not another subjective study where half of the viewers see the difference and the other half don't.
Hi Vitaliy, could you publish high resolution images of your's "dump" gh1/gh2 bodies. It's very interesting to analize audio and remote controle related hardware.... and do you have service manual for gh2? Thanks in advance!
And what difference do they make apart from better encoding efficiency? No, strobing won't be and ISN'T caused by b-frames, and there's no actual difference in strobe between the GH1 vs GH2. Like _gl said, it's mostly likely to be a bad monitor in combination with a lot of in-camera sharpening. Anyway, this is the hack thread so we should probably continue discussing it elsewhere. ;)
It's already been proven that there's NO difference in 'strobiness' with the GH2 vs GH1. Any strobing people are seeing is merely from a purer, sharper image, when the settings are wrong (not 180 shutter).
ok, I don't know for sure. there has been some comparison and there seems to be a difference in the way the motion looks but it's a lot of opinion rather than scientific evidence. Can you suggest a good test for this?
>It's probably from the sensor's higher native frame rate (60fps) which gets cut into 24p in firmware (correct?) whereas the GH1 has a sensor with 24p natively.
I think that this is incorrect. Both GH1 and GH2 have 24p native sensor modes as I know. If you feel that motion blur is somehow different you need to perform scientific test.
I think he's talking about the lack of motion blur on the GH2. The GH1 has noticeably more motion blur it seems. It's probably from the sensor's higher native frame rate (60fps) which gets cut into 24p in firmware (correct?) whereas the GH1 has a sensor with 24p natively.
@crackermd 1/25 shutter speed is the closest to 23.976 fps in GH2 at 1080p24 mode. Wouldn't it be enough? Although I sure hope multiples of 23.976 for shutter speed become available in FUTURE bodies. Also multiples of 60p.
e.g. 24p, 25, 30, 40, 48p, 50, 60p, 60 (fluorescent lighting), 72p, 80, 96p, 100, 120p, 120, 125, etc.
>fs100 looks like the real winner this year for sure, I'm leaning towards the nano maybe the samurai, I think the ninja is not the answer for this cam.
Remember the samurai doen't have hdmi imput only SDI so it won't work with the fs100.
It's not that simple. lol r3d is usless and fat for a small sensor. Shot a feature last year on RED, great camera but it is just a camera. If you are interested in features for cinema release Red is good but you are not limited with any of these cameras, it all starts and ends with a story. fs100 looks like the real winner this year for sure, I'm leaning towards the nano maybe the samurai, I think the ninja is not the answer for this cam. This is the hack forum for gh2. I am a fan of gh1 and gh2. Not big on the Canon series but in the right hands any of these are fine. Stalin will be a success, can't wait. Happy Filming
All I need is for Vitaliy to write in a new Redspace R3D codec 5:1 raw. And 120 frames a second for that ultra slow mo. And to enable esata, So we caN plug in our own 1.8" SSDs.:-)
