GH2@ Stuttering when panning or with any kind of movement
  • 33 Replies sorted by
  • And the answer is almost always...
    What are you viewing it on?
    A 24p or 25p file being played on a 60hz monitor will always stutter and look strange. Watch it on your TV through HDMI and it'll look fine, or convert it to 30/60p in your editor and it'll look fine.
  • hello is it possible to create a codec for PC able to remove this stuttering? instead of trying to make it disappear from the camera. I think this solution is possible using break or a frame can not see why the stuttering?
  • As @vicharris once said,
    Is it me or does this topic come up every 6 months?
    To avoid this Ground Hog Day scenario, could we maybe put the explanation into the FAQ?
  • First test by really slowing down your panning...almost ridiculously slow. You may soon realize that the shot also looks way better with this slow pan - particulalry if you're doing narrative film work.
  • Maybe 25p and shutter 50 will do better. I have G6 with 50p for panning.
  • @Rivo_Kikkul
    Ok, thanks Rivo, so what settings should I use for panning?
  • 24p on GH2 will always stutter. At first I was really freaked out when I realized it :)
  • A faster shutter will make it worse, try 1/40th sec and slow your pan speed down if possible.
