AT9945CM - stereo mike
AT9946CM - shotgun + stereo mike
AT9947CM - just shotgun
Via: http://www.audio-technica.co.jp/release/release_detail.php?releaseId=63
@trevmar Zoom implements their MS mic arrays with back to back cardioids for the side signal. For this reason or some other, the side mic signal is very noisy, at least on the H2n and H6 I've used.
Fran
It looks like the base is rubber. The two shotgun output is pretty good. I like it.
I just stumbled across an interesting new Zoom mike, apparently released 3 days ago... (with dedicated headphone jack, no less)
I like, too. Especially the combo mike. I just wish it had 4 output channels, or a built-in 4-channel recorder :(
Surely the hypercardioid pattern is going to be only at higher frequencies, as the 'shotgun' device is pretty short? (although they could enhance the length digitally, I am pretty sure they do not do that sort of on-board processing).
i like
I like how them are low profile. But handling noise will be probably a problem (unless if you add huge shock mount).
As I understand, in November.
Sleek! Link is japanese, any info on when/where they'll be available?
