bkmcwd "natural_3_BETA1" - setf.ini - Released 20/09/2013
I release the new "natural_3" setting with stock matrix.
This setting aims at spaning in all the rec modes.
And, this is the optimal setting for enjoying 3GOP with small file size.
*Please try this! And many thanks for feedbacks from you!
*If this is also still unstable, I will further adjust.
Special thanks to @Azo. :-)
NOTE:
Upto 110M for Top Quality 1080p24 at Q18
Upto 110M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 70M for Top Quality HBR/FSH modes
Upto 65M for Top Quality 720/50p modes
Upto 65M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24H and 24L both
Fully working iA and iDynamic range modes if you require them (Take care only in 720/60p)
Beautiful 3, 6, or 9 GOP bringing short GOP style detail & movement-rendition in all the modes
Bush of Death / Death chart tested
Spanning is available in all rec mode
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is available in all rec mode, at least available after reboot the camera
                  Hi,
Is the 444 Matrix the an improved version of the "Cinema Smooth Matrix", or is it complitely different?
These are different matrices. Please refer to explanation by @cbrandin in the link place. :-)
http://personal-view.com/talks/discussion/comment/101633#Comment_101633
Hi, just a little question : Is the 444 Matrix the an improved version of the "Cinema Smooth Matrix", or is it complitely different? Thanks
Hi mate,
Thanks for your beautiful footage! I'm looking forward to the completion of your movie. :-)
Valkyrie 444 TYPE-ZERO4 BETA4.5
@zilk The dynamic range of the image looks impressive! How much does it improve from stock? Do you plan on releasing the settings of it?
bkmcwd "Valkyrie 444 TYPE-ZERO3 2.2" - setb.ini - Released 13/09/2013
*Only 720p modes were changed from 2.1. :-)
This TYPE-ZERO3 is the version in which spanning is possible in all the rec modes.
I think that the freezing issue at the moment of the focusing and zooming was solved nearly perfectly also in Panny lens use.
Also on towi's Death Movie, span is possible for all the rec modes.
Cautions are required to use iDRC or iA only in 60p.
Please try it! And I am very glad if I can get feedbacks from you.
Special thanks to @Azo, @towi and all silent users of my settings! :-)
Of course, many thanks to @cbrandin and KING @driftwood!
Superb-looking Modified 444 matrix from my BETA Team in Japan is adopted in all the modes
Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q18 in 24H mode with 80% Slow-Motion Mode (No Sound)
Upto 65M for Top Quality HBR/FSH modes
Upto 60M for Top Quality 720/50p modes
Upto 60M for Top Quality 720/60p modes
80% Slow-Motion is available in 24H and 24L both with
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i/HBR modes
Beautiful 6 or 9 GOP bringing short GOP style detail & movement-rendition in 720p modes
Bush of Death / Death chart tested.
In camera playback is available in all rec modes,
*Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory at all.
*Although I have received the report that it was able to be used also with the slower card, I especially recommend you use with SanDisk 95MB/s 64GB SDXC card.
                  6GOP and 9GOP are adopted in 720p of TZ4 BETA4.5,
Image quality has been improved than 3GOP. :-)
In Valkyrie 444 TZ3 2.0, since there was a mistake type, TZ3 2.1 corrected is released. :-)
http://personal-view.com/talks/discussion/comment/140542#Comment_140542
bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA4.5" - seta.ini - Released 12/09/2013
*Only 720p modes were changed from BETA4.4. :-)
This TYPE-ZERO4 is also the version as which "balance of gradation and resolving" was considered in all the modes.
Although towi's Death Movie is cleared in all the modes, there is no telling whether spanning is possible in other than 24p.
*Probably, other than 24p or 720p, it may be unable to span occasionally.
Superb-looking Pure Original 444 matrix from cbrandin is adopted in 24p mode
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
Upto 145M for Top Quality 1080p24 at Q18
Upto 145M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
80% Slow-Motion is available in 24L only
Bush of Death / Death chart tested with Panny lens.
In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.
                  Now, I am working on new "natural" setting. With this, spanning is possible in all the modes.
In this week, I will release it. :-)
OK, I also study about MJPEG mode. :-)
Actually I combined it time ago - the 100Mbps anamorphic patch. But since there are newest best called settings for MJPEG mode, I'd like to see a patch which consists of those latest best MJPEG settings with anamorphic resolutions. It's easy to change the resolutions in PTool, but I think that some other parameters must be modified in accordance with the best normal MJPEG settings. That's my point.
Hi mate,
Please, make Valkyrie 444 TYPE-ZERO3 2.0 with anamorphic modification of the latest MJPEG 2k settings.
Honestly, since I do not use MJPEG mode, I am not detailed about it.
If the setting containing the MJPEG mode which you have used regularly is shown to me, I will combine it. :-)
I gave explanation to TZ3.
Spanning is thought as important in TZ3 of Valkyrie.
Image quality is thought as important in TZ4.
For the next, I would like to prepare GOP3ZILLA by which span was thought as important. :-)
bkmcwd "Valkyrie 444 TYPE-ZERO3 2.1" - setb.ini - Released 09/09/2013
bkmcwd "Valkyrie 444 TYPE-ZERO3 2.0" - setb.ini - Released 05/09/2013
Beautiful 3 or 6 GOP bringing short GOP style detail & movement-rendition in all rec modes
                  I am also preparing Valkyrie 444 TZ3 in which span is possible in all the rec modes. :-)
About a "Lite version", it is due to be unified with TZ3.
bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA4.4" - seta.ini - Released 04/09/2013
*All the rec modes were changed from BETA4.3. :-)
Although towi's Death Movie is cleared in all the modes, there is no telling whether span is possible in other than 24p.
*Probably, other than 24p, it may be unable to span occasionally.
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality 720/50p modes
Upto 75M for Top Quality 720/60p modes
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in all the modes
In camera playback is sometimes not available in 24p. (Standard) In other mode, Sometimes available after reboot the camera.
                  On the work in Spizz, Valkyrie was also further improved.
As a result of getting @Azo to try HBR30p, it is clearly better than BETA4.3.
Although I have repeated the test of Spizz, I plan to release it after that. :-)
Thanks for comment, mate! :-)
One question to Duke, did you use a different matrix than the last GOLGOP?
Yes, they are different. In Duke, resolution is more important than GOLGOP3-13s.
Why not making a unified patch ?
Because, there are several reasons.
This is the biggest reason in the first place, GH2 hack has not yet been elucidated all still. And there is a reason the picture of an ideal changes with people.
Anyway, we are still in the middle of a way. Based on the feedback from various users, it is the stage which I am also always improving. :-)
I've just finished my part on Spizz T6. @driftwood and @bkmcwd have to verify it now...
Here's a little "preview" of HBR/25p
1st three attachments: Codec Torture Movie
4th attachment: low key scene
5th attachment: medium detailed scene (underexposed)
                  Driftwood compared Spizz with FlowMotion and told us, Spizz wins the streamparser analysis game. But to be honest, I cannot see a quality improvement from Spizz T6 to Flowmotion in real life
No, he did not... he was referring to 24H only! All other modes are not yet ready for primetime. But personally I believe in the end it will be a very, very good setting.
For PAL modes you may also take a look at "HQ3GOP": http://www.personal-view.com/talks/discussion/comment/137327#Comment_137327
@bkmcwd I made a quality test of duke beta4 yesterday. I only testet my prefered modes (PAL) FSH and SH. The quality is much better than the actual Spizz (T6 preview) or former GOLGOP in my eyes.
Driftwood compared Spizz with FlowMotion and told us, Spizz wins the streamparser analysis game. But to be honest, I cannot see a quality improvement from Spizz T6 to Flowmotion in real life. In test settings with same lightning FM shows more texture the dark areas than Spizz. Duke handles these parts better, too. So for me, Spizz is out of the race. As I wrote, I only looked at PAL FSH and SH, maybe NTSC side or 24P looks different.
