GH2 AVCHD transcoded with 5DtoRGB vs AVCHD 8 bit 4:2:0 (Chroma sampling+smoothing)
  • I came across a real world example of 5dtoRGB's power while setting up some scenes and stuff for some upcoming Color Finesse 3 tutorials I've been asked to do . I previously stated here: http://www.personal-view.com/talks/discussion/530/5dtorgb-for-gh2-advantages-vs-disadvantages#Item_29 that with my adobe workflow and Color Finesse 3, I have had no need or advantages using 5dtorgb. I was wrong. To be honest, I really wasn't expecting any improvement, but 5DtoRGB did a spectacular job at upsampling 4:2:0 and it's chroma smoothing was excellent.
    The scene's background was lit with a blue tint and the skintones in the foreground were lit warmly so as to create a complementary color contrast. Now when I brought the footage into AE, I noticed these very harsh edges around the skintones with false color etc. at first I thought it was digital sharpening but at close inspection, I realised it was the 4:2:0 limitation. It looked awful and I could not perform any sharpening as it got a lot worse. Then I thought I'd try 5dtoRGB and it proved it's worth.
    NOTE 1: this improvement that 5dtoRGB brings will be augmented with further micro-contrast enhancements like sharpening etc. Try sharpening the avchd file=ugly mess. try sharpening transcoded file= normal.
    NOTE 2: Ofcourse, there are space+time disadvantages.
    NOTE 3: this scenario with the blue lit background is quite extreme as it's the perfect receipe
    for chroma down-sampled footafe disaster, so it doesn't mean I will be transcoding all of my footage ofcourse.
    settings and tech stuff: lit with 2 312 LED lights (1 312 Bi-color at 3200K with diffusion in fridge:) and 1 312 5600K with blue gel), nostalgic -2,0,-2,0. ISO 200, nikkor 50mm 1.2 Ai-s @F2.8, drifwood's 100Mb 3 GOP settings, transcend 16gb class 10, graded in Color Finesse 3, transcoded in uncompressed 10 bit 4:2:2 (overkill, 8bit and DNxHD should work fine)
    so here goes:
    pic 1: 1st detail transcoded (look at improvements) - compare with pic 3
    pic 2:2nd detail -transcoded-day and night difference! -compare with pic 4
    pic 3:1st detail untranscoded (look at false color and chroma down-sampling artifacts)
    pic 4: 2nd detail example- untranscoded ( look at awful false artifacts on skin edge!!!!)
    pic 5: untranscoded graded. compare with pic 7
    pic 6: transcoded ungraded for reference.
    pic 7 :transcoded graded (there is small difference in CC between pic 5+7 cause I changed a few things-this does not affect the edges though)
    pixel peepers enjoy!!!
  • 19 Replies sorted by
  • @stonebat
    you see that in your test, the transcoded doesn't offer worthwhile benefits, it just happened that my case was extreme because of the blue lit background; the same would apply if the background was green etc. And I think this is how 5dtorgb should be used, on a case by case basis, if you encounter a chroma issue, use it. if you don't, then it's probably not worth transcoding as nowadays, you can edit natively AVCHD.
    couple of other pointers to test:
    -setting a more contrasty gamma should yield a gamma closer to the original
    -try applying heavy sharpening to both files, I'm suspecting that the transcoded might behave better.
  • 5DtoRGB for Mac doesn't support DNxHD. Only Win version supports DNxHD.
    709 & 1.8 gamma options.
    1st is original. 2nd is transcoded. Both ungraded.
    1920 x 1080 - 1M
    1920 x 1080 - 2M
  • @producer
    Thats not selling it to me, it looks like in the second image that it's lifted the black point, badly, creating a fog. Or incorrect gamma, or both. Does it do that if you uncheck the super black and super white settings ? Or are the frames the wrong way around on your post ?
  • @producer
    what are you trying to prove here?
  • The first frame is straight from the camera, the second one is after transcoding with AJA codec. No 5DtoRGB used!
    1920 x 817 - 315K
    1920 x 817 - 305K
  • AJA 10-bit YUV 4:2:2 v210 or AJA 10-bit RGB 4:4:4 R10g with compression and decompression YUV HD Matrix = 709CGR. "Allow Super Blacks" and "Allow Super Whites" checked. That's all.
  • @ producer
    can you describe your workflow?
  • I use AJA codec 10-bit and it does faster and better what 5DtoRGB does...
  • I believe they are saying the RGB conversion is higher quality in CS5.5. If you can put your source files and project files somewhere for me to download I can try it for you. The trial version unfortunately can't load AVCHD.
  • @sam_sickland
    I use cs5 at the moment. Do you mean that transcoding through after effects into the upsampled codec of your choice has been improved(in CS5.5)? or A.K.A high quality RGB conversion, similar to 5dtorgb? If that is true then the benefits would be in time, and those could be pretty big with AE 64 bit engine, multi thread tech, mercury engine etc
  • @stefanos Which version of AE are you using? According to this thread the chroma upsampling was significantly improved in CS5.5
  • @Mezomorf
    if it helps:
    output format: uncompressed 10 bit 4:2:2 (v210) 23.976 (10 bit uncompressed is probably overkill)
    decoding matrix: .709
    gamma flagging: 1.8 (2.2 will be closer to original file but when color correcting I prefer 1.8 as a starting point)
  • tell us your settings in 5dtorbg (output format, decoding matrix, gamma, chroma mode)
  • I just learned ProRes and DNxHD are Intra-frames only codecs.
    ProRes422 has 147Mbps bandwidth. Divided by 24. Each intra frame would be about 6Mb for I-frame bigger than 6Mb from GH2VK. If I-frame is 10Mbps, each frame (I or B or P) gets compressed to 6Mb Intra frame? Or lossy transcoding?
    ProRes422HQ has 9Mb intra frame. ProRes444 13Mb intra frame.
    Suddenly... 5~7Mb I-frame size looks big enough for practical purpose. I'd stick to 44Mbps GOP12 AQ4 and transcode to ProRes422 or DNxHD175.
  • It sounds great. But it's gonna slow down the workflow. I must try it by myself to see if it's worth.
    If everyone uses same gears and same settings, what would differentiate among final artifacts? Lighting and post-processing :)
  • I don't know about other people, but if you open pic 2+4 and switch between them , I see a world of a difference. Pic 4 is just so wrong and ugly in comparison. I think the biggest benefits from transcoding with 5dtorgb will be in post processing: chroma keying, sharpening and boosting contrast curves etc.
  • 115 sounds good. It produces 1.2min/GB bandwidth which seems pretty close what 100Mbps setting produces.
  • @stonebat mmm, not entirely sure, this specific chroma sampling issue has to do with 4:2:0, so with regards to amending this specific issue, 10 bit and super high bitrates shouldn't play a role, good 4:2:2 conversion should, but low bitrates might introduce other compression issues. But I'm guessing 115 should be sufficient for not super processed footage.
  • 8bit DNxHD... 36? 115? 175?
