Driftwood ClusterX series 2:│moon│ЅріzZ│nebula│drewnet│Slipstream │Redshift
  • 1053 Replies sorted by
  • @driftwood : uploading a new testfile on wetransfer, it'll send you the link in about 10 min to your email. Already transcoded to prores422hq, now with moon t7c 24p and same settings. I noticed that my display shows the recording picture munch slower while shooting!? Could it be a problem with my sd card? Thank you!
  • @peaceonearth : its not the playback, its the strange stuttering blur in movements.
  • @danielortegajan your file plays smooth. mts in mPlayerX as well as transcoded ProRes in QT
  • Here's a pre-release trial of Spizz T6 for the early testers to confirm everything is right/working/not working. Enjoy and let me know if this is the best GOP3 setting youve ever seen? 1080i FSH is currently failing in iA mode and will be sorted.
    Spizz 3 GOP in the dark at 1600 ISO below
    Spizz T6 pre-release trial setf.zip
    1K
    1922 x 1080 - 3M
  • zaven13...
    no errors yet,,,
    using retro and iA mode for most 720p60 shots.
  • @danielortegajan Thanks - Ill take a look. Might have to lower the bitrate slightly to 'accomodate' lenses such as these.
    Ive had a look - this isnt too unusual for the GH2 at 24p hi bitrate with faster than your average pans on square objects. If youve got other example upload. However, I promise you Ill take a look at replicating this test and to see if we can improve the situation.
    Here's Spizz GOP 3 on a Death Chart resolving a minimum QP of 1 and a maximum QP of 5 on this i frame with a PSNR of 54. Pretty darn amazing.
    1650 x 957 - 128K
  • I'm heading out to shoot some stuff now. in 1080p and 720p for slowmo. Just a quick test in my office looks incredibly encouraging!
  • @driftwood yes also transcoded to prores 422hq, its the same. But please have a look on yourself. Settings are: smooth all -2, iso 400, 24p and 1/50s shutterspeed. Lens is a panaleica 25mm and saved on a sandisk extreme 32GB 45MB/S. Here is the file: https://www.dropbox.com/s/7abdjittkjw1b7f/00001.MTS
  • @danielortegajan Have you transcoded yet? Or are you just watching stuttering on your media player? Cus thats expected - those decoders cant handle it - transcode to prores.
  • @driftwood : Moon T7b unfortunately does not improve this kind of motion blur. Now there is also a kind of stuttering in it!? Maybe you know what that means? Uploading the mts file on my dropbox now. I'll post the link here in a few minutes. Cheers, Daniel
  • We're coming up for a new thread shortly once we reach 1000 replies so moon T7 on the series 3 new thread will be finalised version.
    BTW: 12/15 GOP fans don't forget to checkout DREWnet T9 (now up on page 1) with huge B frames on motion - totally insane quantisation at only 80Mbps for 24p. And Spizz T6 is nearing completion.
    Spizz 3 DESTROYS Flow Motion 202 with Average range of QP values of sub 'QP 5' at 24p even at 100Mbps (but it will go consume more bitrate upto 147Mbps for extra detail if it needs it!)
  • the next time I shoot I'll set to 1/50.
    if any of the changes made in 7b/c affect the quality in any way then don't adjust for my sake. I'll let ya know how 1/50 looks with 7c
  • @GravitateMediaGroup 7c also has the 720p GOP Related set to '1, 7, 0, 0, 64, 0' for you. Personally I didn't have an error when it was set as is moon T7 but you guys are the real testers / and on differing lenses. Good stuff :-)
    PS I want full moon shots tonight from you all! LOL @Zaven13 "..Go Dickies!"
  • @driftwood
    does T7c have the same upgrades as T7b?
  • @driftwood. Understood. Go dickies, no pussies.
    @flaschus. Did your GOP related change make a difference?
  • @flaschus has just notified me regarding GOP Related 72060p he'd changed;-
    '1, 5, 0, 0, 64, 0'
    to
    '1, 7, 0, 0, 64, 0'
    for a similar issue to yours @Zaven13.
    Overall, this version of moon (T7) squeezes everything it can out of all modes. If recordings stop on non 24p modes before a span file can be created so be it. This setting is not for pussies! ;-)
    Here's moon T7c updated 720p60 stable (we hope! @Zaven13) thank you @flaschus.
    Once everyones happy Ill repost on page 1. And don't forget, 24p may cause stuttered playback on windows media player/ etc... but once rewrapped to prores422 minimum your'e rocking.
    moon T7c - with 7 on 720p60 setj.zip
    1K
  • @driftwood. Here are my first observations with Moon T7 NTSC, Sandisk 64GB, 95MBs, Panny 14-140. Quality for all modes is great. - 24P H and L modes use the same bitrate averaging 140mbs as if 80mbs for L mode is ignored. 24p spans OK - HBR and FSH averaging around 70mbs both stopped after 5-6 minutes of recording pointing to TV and recording before reaching the 4GB limit. - 720p SH averaging 50mbs stopped after 8 minutes before reaching the 4GB limit. It also had a write error when zooming all the way to 140mm (in iA mode). For a first release of the hack, it is pretty stable and has great quality. I will post after more detail testing.
  • moon T7 motion blur DOES IT/DOESN'T IT?
    Two of you mentioned motion blurring artifacts in moon T7 release candidate. This has yet to be confirmed as a major problem - Can those who worried take a look at this quickly adjusted moon T7b with GOP Related x2 time edits (just a few switches off) and tell me if its improved/no change? Just wanna clear it up. Thanks
    moon T7b - x2 time adjustment - setj.zip
    1K
  • @DeployAerial. Excellent videography and aerial shots.
  • Latest News Driftwood Cluster X DREWnet T9 12/15/6 GOP is now up on page 1. @onionbrain
  • Thanks so much for the kind words @tymeorama @driftwood @GravitateMediaGroup @peaceonearth
    @peaceonearth and @GravitateMediaGroup , sorry for the omission, we're based in Hong Kong but we're certainly not limited to Hong Kong, or even Asia. We definitely hope that this work might give us the opportunity to travel and shoot in other countries.
  • @DeployAerial great shots!!I It would be helpful to know where your are located without having the effort to google +852 ;-) It's a pity that it's not +33, +41, +43, +44 or +49 ;-)
  • @DeployAerial that was REALLY nice, the rock climbing stuff was crazy looking. Where are you guys located?
  • @GravitateMediaGroup : yes, I think it's the same. Had this also sometimes with moon T5 but not so noticeable. Maybe I can upload my testfile this evening somewhere.
  • @haarec 1080
    @danielortegajan I think we are seeing the same kind of "motion blur" it's a odd kinda blur that ALMOST makes a clip appear in slightly slow motion.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
