I am looking around the possibility to use a tablet and a HDMI to wifi transmitter as a field monitor. The idea is the "HDMI to wifi transmitter" send wireless the video signal (working as a video server) and use the wifi funtionality of the tablet to receive the video. This could be used as a field monitor, probably not for video but good for photography, as you will have a good quality and large resolution display.
I appreciatte any help in this search.
@BG123 ...as Canon EOS camera monitor(only!) Thanks for the advertising anyway ;)
Here is a handy solution for using an Android device as a DSLR camera monitor:
Digging this up again. If we dont care about really low latency, does someone know of a cheap option out there? It seems it would be cheaper and have a greater range to use WiFi. Of course, the device should have an H.264 encoder or similar onboard, as Bandwidth and Tablet Capability would not be enough otherwise..
This may be cheaper and easier way to do a field monitor.
Usual WLAN is not very well suited for this task as you will need to fight hard to get low latency. Bandwith is to low as well.
At work we use this one to get cam signal live onto big screen so our customers can see what´s going on: http://www.cyberport.de/?DEEP=5899-12P&APID=204
You could then get a tablet with USB3 and add a BlackMagic Intensity Shuttle to it.
something like this http://www.alibaba.com/product-gs/449369005/WHDI_stick_wireless_hdmi_transmitter_and.html keep in mind that gh3 will very possibly have wifi and all this expensive stuff wont be needed!
