I shoot this promo for the website of the Tango studio were I work. Moon T5, Nikon 50 1.4, no color correction, I used a cavision 4x4 polarizer. Sorry for the youtube compression...
@callan. My apologies. There was an error in my post. When @driftwood introduced, Moon T3 and T4, I heard the comments that T3 is too soft and T4 is too sharp. So what I did was to use T4 matrix and change the initial quantizer from 14 to 16 a long with bitrates I mentioned above. Moon T5 was released by @driftwood with similar changes & lower bitrates for stability. If you check Moon T4, you will find the numbers I posted earlier. Below are the original T4 and my version.
                  @rayycy. I had your problem with both 720p60 SH and 1080i60 using Sandisk 64GB 95mbs. What I chose to do is use Moon T5 and change the quantizer to 16 instead of 14, change the high and low bitrates for 1080i/720p from FSH/SH=93 to 88 and FH/H=48 to 58. I also adjusted the bitrate limits to match the new numbers. Those changes eliminated the card write errors for me. Spanning is still an issue with FSH/SH but not with FH/H. Hope this helps.
I use the same and haven't had issues other than 720 60p stops recording at 15 minutes... so no spanning but who cares. That said....
A fresh reload of Moon T5 on your camera is where I'd start first.
If all else fails you might consider a full over rite reformat of the card. I've done this in the past when a card started to get "finicky." See what others suggest first as some feel you should never have to fully reformat the card.
NOTE: only use the official SD formater application on your PC for this. (The 64GB 95Mb/s card must be properly formatted as ExFAT.) This is specific to this particular SDXC card and different from all the other cards "beneath" the 95Mb/s card. The formater app is free to download.
Good luck.
MOON T3, Smooth all -2.
it is a tricky beast, but i never head a problem with pluraleyes 2 with hacked gh2 footage, guess i'll go roll back
anybody else having trouble using the new PluralEyes3 (for windows) syncing audio with a hacked GH2? i've got a drewnet t8 hack and pluraleyes gives me a media error and won't do any syncing
@treeclown Wrong topic. :) It should go in the Sedna thread, not the ClusterX, just so people don't get confused.
@vicharris OOPS:) always had the impression that people just posted in the current Drift wood thread... I've reposteded to the senda thread
I am shooting a micro doc on a vintage car race (using Moon T5). Footage looks great, learning a lot in the process. Nikon 24 F2.8 glass mostly. Card sandisk is 32gb 95mb/s. Having learned a good bit from @shian on exposure, I feel I am starting to understand the need to light. Special thanks to @Vitaliy_Kiselev and @driftwood . Will share the finished piece next week.
iPhone photo-
@htf I am using 16BG Sandisk Extreme card. For me, 16GB is enough, I use many of 16GB rather than high capacity cards. I don't want to bet too much data on one card.
I just shoot a wedding video using Cluster X Series: 12/15 GOP - 'DREWnet' Trial 8 and it went perfect. Nice patch for long recordings thanks @driftwood !!!
