Shot with Moon T5, 24H, Smooth -2 -2 -1 -2. Thanks again to Driftwood for your wonderful Moon hacks! They really make grading a breeze. :)
@driftwood: thank's! I really enjoy your work with the patches. With T5, the only thing I need to work on is a little bit of flickering in low light/ out of focus zone in etc mode, but, luckily, it is not so obvious on vimeo.
@tymeorama LOL! Very good. :-)
14-42mm + Moon T5 Hack (thanks to Driftwood and Vitaliy Kiselev) 24H // 160 ISO // -2-2-20 // no color correction, only Neat Video denoiser Filmed and edited by Guillaume Muller for TYMEORAMA Productions Music: "Love at first sight" by Hot Butter // Hot Butter (Musicor MS-3242; 1972), composed by S. Gainsbourg
I shot and edited an episode of Gaijin Pot here in Japan. I used the Moon T5 settings. Shot through the 14-140mm and edited/graded in PrCS6/MBL2. Pretty please with the results but it was a very bright day and as a result a bit blown out on some highlights but I was able to pull so much out of this patch. Cheers @Driftwood
Moon T5, 14-140mm.
Are the "12/15 GOP 'DREWnet'" tested for 1080i25p HBR? I got one Crash with complete Dataloss on the Sandisk Extreme Pro 64 GB @ 95 MB/s... First got the: Not fast enough for Saving and than complete Camera Freezed...removed the batteries and restarted...all Files on SD were lost.
Could repeat that freeze at around 15 min recording time.
Used Moon T5 on this one last night too. Talk about working with the tools available . . . I created and animated this in PowerPoint (I've been animating in PowerPoint since elementary school). I then played the animation on my dell 30" monitor and recorded the monitor with my GH2, Kowa anamorphic, Konica AR 40mm and Tokina diopter all on a tripod. Then I moved the monitor out of the scene and recorded various flares with a flashlight. Brought it all together in Final Cut Pro, set the flares as additive layers, and added some grain overlay effect. I think the outcome is something clean-cut but with a dash of organic mojo that is difficult to achieve with an all-digital animation.
@B3Guy I loved it! Can you tell me which color profile you've used? Standard -2 all?
Just wanted to share, this is all done with Moon T5. Gorgeous patch, @Driftwood! It made grading a dream, and it was nice for some of the difficult lighting situations like the gymnasium.
Here's a couple of clips, one using Moon 5 and the other using Moon 6a. They were shot only minutes apart using the same lens and camera settings. (14-140/Cinema 0, -2, 0, -2/ISO 200)
I am not certain if I changed the exposure between shots, but I know I did not change the ISO setting or anything else. What I see when the clips are blown up to 400% is more noise in the 6a shot. The 5 clip seems cleaner, especially in shadows.
@Jim_Simon Thank you kindly, that worked perfectly for me. Will proceed accordingly henceforth.
Cheers!
@Jim, thank you, I was using before 3.6.5, where can I find the update?
