Driftwood ClusterX series 2:│moon│ЅріzZ│nebula│drewnet│Slipstream │Redshift
  • 1053 Replies sorted by
  • @rc444
    In my testing, I did find some quality improvements between Apocalypse Now DREWnet (my former patch) and Moon Trial 5 (my current).
  • T5 ... Grading Test ... it's Sian's 2-strip, with some curves underneath on a shot by shot basis.
    Cinema Standard, all -2 Minolta MD 24mm 2.8 and 50mm 1.4
  • I'm finding Moon T5 to be a bit too sharp. Anyone else finding this? My profile is Smooth -2,-2,-2,-2 Mostly using Nikon Ais primes and zooms and Tokina zooms.
  • Shot with Moon T5, 24H, Smooth -2 -2 -1 -2. Thanks again to Driftwood for your wonderful Moon hacks! They really make grading a breeze. :)
  • @driftwood: thank's! I really enjoy your work with the patches. With T5, the only thing I need to work on is a little bit of flickering in low light/ out of focus zone in etc mode, but, luckily, it is not so obvious on vimeo.
  • @tymeorama LOL! Very good. :-)
  • 14-42mm + Moon T5 Hack (thanks to Driftwood and Vitaliy Kiselev) 24H // 160 ISO // -2-2-20 // no color correction, only Neat Video denoiser Filmed and edited by Guillaume Muller for TYMEORAMA Productions Music: "Love at first sight" by Hot Butter // Hot Butter (Musicor MS-3242; 1972), composed by S. Gainsbourg
  • I continue to use T5 to crank out the day to day stuff and love it! Looking forward to T7 though :)
  • Some really great T5 moon footage guys. moon T7 is in development. :-)
  • I shot and edited an episode of Gaijin Pot here in Japan. I used the Moon T5 settings. Shot through the 14-140mm and edited/graded in PrCS6/MBL2. Pretty please with the results but it was a very bright day and as a result a bit blown out on some highlights but I was able to pull so much out of this patch. Cheers @Driftwood
  • another shot cluster x gh2 ,ob. Samyang 85mm f/1.4 Nikkor 50mm f1.2
  • Moon T5, 14-140mm.
  • Are the "12/15 GOP 'DREWnet'" tested for 1080i25p HBR? I got one Crash with complete Dataloss on the Sandisk Extreme Pro 64 GB @ 95 MB/s... First got the: Not fast enough for Saving and than complete Camera Freezed...removed the batteries and restarted...all Files on SD were lost.
    Could repeat that freeze at around 15 min recording time.
  • Are the Cluster X: Series 2 hacks better than the 444 Apocalyspe Now Drewnet hack?
  • another shot cluster x gh2 ,ob. Samyang 85mm f/1.4 Nikkor 50mm f1.2 canon
  • Hello i m french i shot with gh2 pana 14mm2.5 ,ntsc mode 60p with moon t5 using vegas render to mp4 35mps moyenne 90mps high upload in progress,,no color correction
  • Used Moon T5 on this one last night too. Talk about working with the tools available . . . I created and animated this in PowerPoint (I've been animating in PowerPoint since elementary school). I then played the animation on my dell 30" monitor and recorded the monitor with my GH2, Kowa anamorphic, Konica AR 40mm and Tokina diopter all on a tripod. Then I moved the monitor out of the scene and recorded various flares with a flashlight. Brought it all together in Final Cut Pro, set the flares as additive layers, and added some grain overlay effect. I think the outcome is something clean-cut but with a dash of organic mojo that is difficult to achieve with an all-digital animation.
  • Satandard, -2 -2 -1 -1 is what it is set to, has been for ages. I don't really touch that stuff. I just set it to what seemed to be the general consensus about a year ago. I should probably give all that stuff a revisit.
  • @B3Guy I loved it! Can you tell me which color profile you've used? Standard -2 all?
  • Just wanted to share, this is all done with Moon T5. Gorgeous patch, @Driftwood! It made grading a dream, and it was nice for some of the difficult lighting situations like the gymnasium.
  • Here's a couple of clips, one using Moon 5 and the other using Moon 6a. They were shot only minutes apart using the same lens and camera settings. (14-140/Cinema 0, -2, 0, -2/ISO 200)
    I am not certain if I changed the exposure between shots, but I know I did not change the ISO setting or anything else. What I see when the clips are blown up to 400% is more noise in the 6a shot. The 5 clip seems cleaner, especially in shadows.
    http://depositfiles.com/files/tx8ggux4d
  • @Jim_Simon Thank you kindly, that worked perfectly for me. Will proceed accordingly henceforth.
    Cheers!
  • @Jim, thank you, I was using before 3.6.5, where can I find the update?
  • I'm using 3.6.6 with success.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
