SLR Magic 2x ANAMORPHIC lens
  • 804 Replies sorted by
  • The focus can work from 2.8m to infinity at f2.8 with decent IQ. Shooting closer than would require expensive and hard to find anamorphic diopters.
    The last time I used an anamorphic lens professionally (Panavision Primo) we used regular common spherical diopters (aka: "close up" filter).
    Min. focus of 2.8m is a bit far away, but, high minimum focus was common with older anamorphics. People will ask 'whats the minimum focus with my f1.4 lens wide open?'
    Solution 2: I am not sure if I understand the working procedure. Can I use the anamorphic adapter (AA) set to "normal", and just focus on the taking lens? Down to 2.8 meters and then and only then engage the AA macro mode? Or do I have to adjust focus on both lenses at the same time?
  • @slrmagic
    I like the second option better, as diopters are certainly a tricky thing to find. I'm more of a 2X guy myself, but if you come up with a good single-focus 1.33x solution, I'd be very tempted.
  • @Brian202020 that makes 2 of us here with a celluloid background. I bought the GH1 and GH2 for fun to use with my legacy glass, but, have found with it can be a serious tool for the right customers too.
  • Certainly not very knowledgeable about anamorphic, but would like to get into it. I like the options you listed today. (if I understand correction you affix it directly to the front of the lens, with no need for rails etc?). I don't see any downsides to the 2nd solution as it seems more flexible, but maybe more expensive??
  • We received some emails regarding the adapter solution. There had been requests for a single focus adapter. This is what we came up with and some feedback would be good.
    The first solution is more of what was hoped for. The second solution is a mod we made to the first solution as we think it is a more convenient option.
    The adapter now is 1.33x and can work up to 23mm with our SLR Magic HyperPrime 23mm F1.7 micro four thirds.
    Prototype solution 1) Single focus solution: Adapter is fixed like the LA7200 and you focus with the taking lens. The focus can work from 2.8m to infinity at f2.8 with decent IQ. Shooting closer than would require expensive and hard to find anamorphic diopters.
    Prototype solution 2) Single focus solution: Adapter is fixed like the LA7200 and you focus with the taking lens. The focus can work from 2.8m to infinity at f2.8 with decent IQ. If shooting closer than 2.8m, we have a macro focus mode where we allow the adapter to have a focus ring to move with focus markings that need to be matched with the taking lens. The macro mode can focus down to 0.9m as long as the taking lens can focus down to 0.9m as well. The design is similar to a dual focus design but not quite the same mechanically. The cons are some may think it is a dual focus design. The pros is the option to not buy diopters or having to change different diopters when needing to shoot closer than 2.8m
    Hope everyone can pitch in with opinions with the two adapter solutions or if we should stick with our single lens solution.
  • @CFreak
    I never owned a DSLR. GH2 is the closest i came and i rarely used it. I come from the 35mm/16mm film world, and in recent years the RED and Alexa and now the BMCC.
  • @soundgh2 lol. +1 for your post above.
    Having worked with the cream of the crop of anamorphics: The Panavision Primo, E and C series Anamorphics on Hollywood productions, there are definitely compromises. Even the Depth of focus behind the lens has a slight bow in it, then focusing it on a flat sensor, making edge to edge sharpness difficult to achieve. We'd project the lenses, look at them on a collimator, then tweak the flange focal distance in the camera to compensate, shoot a test, wait a day for the lab to develop it, screen it, and so on. And Forget about using them at f1.9 and then projecting it on a 100' screen and it being perfect.
    The MB speedbooster ( @Brian202020 ) and the use of Anamorphic (w/without diopters) is bring all these issues to the advanced DSLR user, but, few know what I am talking about.
    Speedbooster adjustment suggestion: http://personal-view.com/talks/discussion/comment/132764#Comment_132764
  • @kronstadt
    We mentioned earlier we were working on an anamorphic adapter that is around 1.5K. We are now working on an anamorphic lens instead and would cost slightly more.
    An anamorphic that would work well with our 12mm 1.6 lens is huge and expensive. It would be heavy as well and require to be racked up so it is not something we are working on.
    @apefos is working on the Apefos Scoperama Anamorphic Adapter that has different coating and very affordable. We have not been able to come up with an anamorphic solution close to the price. Custom coating is definitely not possible.
    Many have asked us a question when our Anamorphic lens is coming out. With so many legacy options available for such an affordable price, we hope to come up with something with really good image quality. It would take some time and not something we can complete within weeks. We suggest anyone with an anamorphic shooting soon to look into currently available options rather than ours.
  • Hi everyone,
    Some new updates on the project.
    @kronstadt the video you found was our first prototype. it was an adapter solution. however, we noticed two problems with an adapter. First issue is glass combination leading to compromise as @soundgh2 mentioned. Second issue is possibly a non-optimal set up (alignment) between the anamorphic adapter to the lens. We are now onto our second prototype. It is quite different to our first one. The second prototype no longer has the anamorphic mump. The IQ is slightly improved due to being an anamorphic lens solution for micro four thirds mount. Just curious, is there anyone here with experience in filming anamorphic and currently in Hong Kong at the same time?
    Best Regards., Andrew
  • @slrmagic and what about a focal reducer for old mounts ala Speedbooster-Lens Turbo, but anamorphic?
  • It's all what you make of it - having owned LA7200, Optex various 2x lenses and 35 mm Lomo - did I make anything worthwhile - of course not lol - have I seen anything all these years anything worthwhile - not a lot! Actually Voldy has a lovely shot of a bridge through his shitty Optex - is it worth it - no idea !! Why are you shooting you through a world of nightmare glass compromises? To make it more "Filmic"? there's the rub? Loving that the speedbooster is getting more shit than anamorphic shooting - work that one out! There's an analogy with old synths and desks (analogue) and recent analog emulation plugins - where there's a phalanx of people commenting on the plugin's analogue - (ness) having never - no really never(!) having ever heard a real Fairchild, SSL, Jupiter, 303 or 909 808 - you get the picture. Same with camera's, shooting - ethics of on set - all pretty much .........
  • @Riker 30 bucks at a garage sale. That's not the regular price. Lots of anamorphic adapters are overpriced and painful to use. I still dream of using some real piece of anamorphic glass sometime. I can live with my cheap Delrama 1.5X despite of its fixed focus for now.
  • 30 bucks?...damn...there seems to be an open season for anamorphic suckers out there...I haven't seen one single anamorphic lens under $400 in recent months...I'm not actively hunting, but I check it out from time to time, I would like to own one eventually....
  • @Riker I have one of those. Beautiful blue flares, focus distance about 5 meters or a bit shorter (PITA!), but sharp when you nail it. The heaviest piece of glass/metal I ever hold in my hand, so it's really cumbersome to use. I paid 30 bucks for it, but I hardly ever use it.
  • @Riker You'd do good to research anamorphics. The price of the Zeiss anamorphic you mention seems zounds above market value. Their closest focus distance is probably around 5 meters, so mostly unusable, and that's why these get far lower prices than anamorphics for 16mm or even 8mm photography. Don't pay rip-off prices for something that will not serve you good.
  • I've just stumbled upon Carl Zeiss 2x63 anamorphics on my local yellow pages listing...$420...what do you guys think of that price tag, good buy or good bye? It looks to be in very good condition...judging by the pics and sellers description...
  • Probably the best pairing for the LA7200 out of that list is the 14-42.
  • Hello all, have any of you used the Nikon 80-200mm 2.8 AF-D with the GH2 for video? I am thinking about buying a nice used one... I would be attempting to use it with the anamorphic adapter AG-LA7200 and a Tiffen Series 9 +0.5 close up, as well as a Cokin P +1, +2, +3 etc...
    I am setting up a for a short film shoot in Detroit Michigan.
    Also any suggestions for great lens combos for my anamorphic set up? I have:
    -Panny 14mm
    -Nikon 35mm 1.8G
    -Hexanon 50mm 1.4 & Nikon 50mm 1.8D
    -Panny 14-42mm (not sure if I'll get nice vid with this one).
  • What is the difference between Sankor 16F and 16C, for example?
    F has no rear thread C has 40.5 rear thread
  • Is Sankor 16F a good choice for GH2?
    Anyone using 16F and GH2 with success?
  • Please do not give up on your anamorphic lens!
    Many here seem unreasonable if they think that a quality lens can be made for under $1000.. They need to face reality - these are not toy - they are unique optics that are out of the realm of most lens makers. I am a serious buyer of this attachment, especially if it could be made for $1000. to $1200.. I would be using it with the 4/3 version of the Blackmagic Cinema Camera, as I believe many others will also.
    My input would be to go with a simple,focusing 1.5X design adapter, and let us sort out the best lenses to pair it with. I would prefer at least a 72mm mounting thread, but 77mm would allow much more diversity.
    But please have just the adapter do the focusing (and leave the lens at infinity), so that only one focus ring needs to be moved. We can use a diopter to focus closer.
    I am not one of those wanting to increase the anamorphic flare. I am all for having the best multi coated optics possible. I can add flare and other subtleties later. But you can't take flare back once it has affected a shot! And it can ruin shots where you don't want even a hint of flare.
    As a middle ground solution, you might consider a "kit" solution for optimum sharpness, where there is one adapter, but 3 or 4 prime lenses that can be paired with the adapter. These lenses could be refined for optimum optical benefit, but share just the one adapter. This would allow you to design a system of controlled lenses for critical use, but the anamorphic attachment could still be used with other lenses for versatility.
    Thanks for allowing this input, but please do not stop this project, as this lens will be bought by many!
  • I'm surprised that @slrmagic didn't post this video in this thread.
    It's still not clear whether this prototype is a single-fixed-focus (like LA7200)? It's also not clear what will be its price when it appears on the market? The 2 issues that are most important to me.
  • @maxmizer
    I can confirm that i bought my first LA7200 for a DVX100 less than £ 150 when it was release, the price go up after it was out of stock or after the production of the adapter stop.
    Anyway actually the anamorphic is totaly overated/overpriced, people just play around to push up the price in max they can and it's totaly unfair, i remember to sell my LA7200 not even 180$ because i never like to play with the price like that.
    @Kronstadt
    I'm not sure that slrmagic go to listen us, you can see how much they sell the 35mm f1.7 (almost 150$) and when you know that is just a cctv based lens (you can find for 16$) you understand why they doing this. how many product i saw that was overpriced and not even good for the price they sell.
    the best example of a good product, it's to check the sigma MFT, cheap, strong and very good to use. for me many company should follow them, public can't buy all the times lens at £ 1000 that just go close in quality with a £ 100 one.
    Anyway i really hope slrmagic listen us and release a nice anamorphic lens for MFT (low cost) i will be the first to buy one again.
  • @Kronstadt I can not remember the price LA7200, but I felt this was retail at £ 700 in the UK, however if you search among those who DVX100, LA7200 have and do not know its value, as I have purchased for € 300 ...
  • @maxmizer of course LOMOs are awesome and it doesn't hurt to push the envelope.
    If I remember right, when LA7200 wasin production the retailprice on those was like £110-£150. Now that they are out of production, the prices have sky-rocketed. But if @slrmagic could produce something to match the quality of LA7200 or Optex at a price point of £100, I'd definitely buy it.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
