GH2 Hack Technical Tests
  • 69 Replies sorted by
  • @mpgxsvcd
    Sure. Do you want the huge Photoshop files too?
    Chris
  • @cbrandin
    How about small app that could load png, set levels and plot unscaled histogram, and in the case of multiple files, plot 3D waterfall also?
    May be we'll find someone who'll be able to make it?
  • @Cbrandin
    I just pm'd you links to upload the original files if you want me to share them with everyone?
  • Note that Photoshop auto-scales the histogram. Although the peaks look the same size, they're not - they are actually lower for the high bitrate settings.
    Chris
  • The 66M sure does push the data to the left a little bit, couldn't really tell until it was blown up. I'd like to see 88+ on this histogram to see if it makes even more of a difference.
    Thanks for posting those histograms, sure makes more sense to me displayed that way.
  • @Hallvalla
    Very Nice! Thanks.
    @stonebat
    The chart I attached is just a thumbnail, so it won't work. The actual chart file is big (15MB+). It has to be printed using absolute colormetric color management settings and with a very good printer (I used an Epson 4800 with the Colorbyte RIP). If you want, I'll upload the file to you. No way it will work with most people's email.
    I have a resolution chart as well, if anybody is interested - it's even bigger:
    I have 48-bit super high-res version Photoshop files too, but they are 300-400MB each.
    Chris
    672 x 435 - 93K
  • Capture (make sure exposure is exaclty right) - import to editor (I use Vegas), export frame in lossless format (like PNG, not JPG). Import frame to Photoshop. Set levels to 0-31 (approximately, to spread out shadow details). At this point the image will look terrible. Use Photoshop's histogram tool. The chart you use should have a mix of detail stuff (like resolution targets) and (this is important) gradients. The GH2 camera outperforms most (if not all) printers, so you will see a quantization artifacts that are actually caused by the printer.
    It's not an easy test...
    Chris
  • @mpgxsvcd Print out the testchart, take video clips, extract frames, import into photoshop or lightroom, and capture the histogram chart? Not sure if editing tools like Premiere Pro has a histogram.
  • Sorry, wasn't sure how to embed.
  • I made an animated GIF of the histogram (blown up 400%)
    1018 x 393 - 132K
  • @Cbrandin
    Totally understood. Yes you have certainly proven what you set out to. What would we need in order to do this test ourselves?
  • @cbrandin Thanks for showing us how to do such technical tests. I'm sure some of us who can't bear to find out more stuffs would test out more cases :)
  • @vladnik
    Yeah, the GH2 codec is actually quite impressive. We aren't "fixing" anything that sucks otherwise, it's all gravy.
    Chris
  • @cbrandin
    that is more flexible than i thought.
    great.
    thanks Chris .
  • @vladnik
    Yup. Although sometimes P frames also get QP+2. The most common pattern I've seen with real world subjects is I=QP-2 to QP+2, P=QP, B=QP+2. The base QP appears to be decided at the beginning of each GOP and can vary according to image characteristics (motion, light changes, etc...). The QP setting in PTool determines what the lowest value can be - and you'll see that commonly reached with highly detailed static subjects.
    Chris
  • >I'd rather focus on other things now - like loop filter adjustments and film modes, for example.
    Good idea :-)
  • @mpgxsvcd
    I could, but it takes a lot of time to do there tests. I just did this test to prove, objectively, that quality does indeed improve with 1080p. I chose that because the 1080p rendering is already so good that the difference is less obvious than with every other mode. Running more tests seems like gilding the lily.
    Lower QP (higher AQ) will always improve quality - that's the very purpose of it and the AVCHD standard states that unambiguously. I just wanted to prove it empirically for the skeptics. I think I have done that. At this point I think it's reasonable (ridiculous not to, actually) assume that the GH2 codec behaves like it is supposed to when quality is raised. If it behaved any differently in another mode, like 720p - well... that would be truly bizarre.
    Chris
  • yes.
    constant qp is value for p frames.
    i frames goes plus minus 2 and b frames plus 2 .
    something like that?
  • @Cbrandin
    Could you do the same test with 720P? It would be interesting to see if we get different results with 720p(ie: without B frames).
    Outstanding test. Keep up the great work.
  • @vladnik
    I'm looking into the loop filter. It's proving to be a little difficult because Panasonic has implemented it in a non-obvious way, like most things.
    Actually, the codec is not fixed QP - it's more like QP within a fixed range with a fixed minimum. All real time codecs have to do this because the CPU can't keep up with actually trying all QP values. The QP range is typically limited to a range of 5 in I frames, and P & B frames use one value - although the exact value can vary slightly from GOP to GOP.
    Chris
  • @VK
    Interesting suggestion. It seems like a lot of work, though. I'm not sure I want to devote all that time to it right now.
    Chris
  • @cbrandin
    Thanks,its very very promising :-)
  • Thanks for the info Chris... makes sense.
  • @cbrandin
    If I understand correctly if we set bitrate and give constant qp codec will be forced to work in
    that bitrate limits . if bitrate is low we get rubbish.
    and no control over loop filter :(.
    Chris please kill loop filter :) .
  • @Mihuel
    I think it works the other way around - bandwidth not allocated to higher quality macroblocks is made available for other things - like better motion fidelity. The QA parameter sets the balance between the two. I have noticed, however, that with higher bitrates even at QA set to 4 all the additional bandwidth is not consumed by higher quality macroblocks, so even at that setting there are probably still significant improvements in motion rendering.
    Chris
