The GH3 shadows are usually magenta after increasing exposure. The last test shows clearly that the flicker can bee not only green but also blue sometimes.
Someone suggested me to correctly exposing in camera for the shadows and using a grey grad on the sky to make the issue unnoticeable. It may works in some way (I will do some test), but I would like to increase underexposed areas without having this ugly color fliker too.
I have done another test for the raw color flicker in time-lapse. This time with a slower shutter speed.
I was comparing video frames to jpeg, I took a jpeg 2M burst at 20 frames per second. Took out the first 24 frames... size is 12MB, while a second at 24p 72Mb/s (64Mb/s recorded) is about 8MB/s.
I know it's not the same compression but there isn't that much size difference, but the quality difference is impressive.
maybe I maths are off...
Here is a very fast test ALL-I vs 20fps burst ISO 800 same profile
@larsarus also did a time-lapse in raw format with full manual settings, and he has needed to increase exposure in almost dark areas. He got the color shift that makes underexposed areas flickering.
It looks like this is a common problem and not specifically related to my GH3 camera.
@yellowapple I've been using all variants in dcraw (can't get more basic than developing by code) - see below - and I think you're right... the shifts are clearly there... maybe in previous tests I just mess up...
-w Use camera white balance, if possible
-r  "r g b g" Set custom white balance
+M/-M     Use/don't use an embedded color matrix
-o "0-5"  Output colorspace (raw,sRGB,Adobe,Wide,ProPhoto,XYZ)
-d        Document mode (no color, no interpolation)
-D        Document mode without scaling (totally raw)
-j        Don't stretch or rotate raw pixels
-W        Don't automatically brighten the image
-4        Linear 16-bit, same as "-6 -W -g 1 1"
m
@larsarus I think that for many "common" timelapses this problem may be unnoticeable: the color shift is evident only in underexposed/darker areas, and if you do not need to increase their exposure, you probably won't even notice it (that's the same for landscapes with lots of light). I have done several timelapses in the recent past, but I discovered this problem only after doing timelapses in places with wider dinamic range that needed exposure to bee increased in shady areas.
I am doing some tests now too see if this may be related to specific ISO value.
@yellowapple I use RAW for timelapse. I have not seen any color shifts yet, but I have just gotten started (so not that many shoots yet). I will be on the lookout for the problem in the future. Unfortunately I have to have my GH3 serviced soon after it fell down on its head and the internal flash broke.
PS. I do not use Adobe products BTW. I have FCPX, Aperture, and create the segments with one of Sequence, Timelapse for Aperture, or QuickTime 7, depending on my time of the month.
@leonbeas, I think you are right, I should try to contact them. I am also interested in understanding if this issue is a common problem or only a problem with my camera or editing. Because of @Maxr tests, it seems that he can replicate this issue too, and this make me think that this could be a common problem for GH3 users. It would be interesting to see if some more GH3 users can replicate the color shift like Maxr did, but maybe not too many of them are interested in using RAW files for timelapse.
I understand, @yellowapple have you tried to phone Panasonic service and check with them, maybe they will tell you how to fix this or what is causing it, or in last case replace your camera. Best Luck
I have tested Rawtherapee, Capture One and Apple Aperture with a timelapse in srgb and one in adobe rgb: I can confirm that color shift happens even with these all applications. It looks like that the shift is always noticeable, but depending on the application it's color is different. But, no matter what color is it, the shift ruins every timelapse.
I really don't know what's the reason causing all this trouble. The camera? The applications? This issue is going to make me crazy.
Anyone have issues where the camera wont playback files recorded after a still has been shot?
Looking at your pictures, it seems that the color shift reason is releated to the Adobe applications. I can clearly see that your two raws opened and edited in Lightroom have a noticeable difference in color, the right one is more green. I'll try some more comparisons tomorrow to confirm this.
I have tried Capture One anther time, an it looks like that this problem is less noticeable! I will check the RAW files with this application some more time to be sure.
though in capture one I checked all profiles, I 99% of times use the linear one
@yellowapple
screengrabs of 2 raws, color space adobeRGB and all specs as you but shutter 1/40th sec.
lightroom +4Ev • rawtherapee (open source) + 5Ec • capture one + 4Ev (linear)
I have already tried resetting the camera (setup>reset), nothing changed. I can't find any other ways for resetting the camera.
I don't remember exactly if this issue was also noticeable with firmware 1.0. I have started using RAW for timelapses only in the last month, before of this I always used .jpg so I can't say it for sure.
In the RAW timelapse tests I have done the setting were: 1) i.Dinamyc OFF 2) i.Resolutuon OFF 3) electronic shutter OFF (I also tried a timelapse with electronic shutter, and the color shift was still there) 4) Long Shutter NR ON (even if on, all the timelapses with the issue have been made with a shutter speed 1/40 or higher, so NR doesn't even activate) 5) I tried both Shading Comp. on and off with no difference
You are right, the colors shifts from green/blue to magenta, and in my tests I have seen that this shift sometimes corrupt lots of images in a time-lapse, sometimes only a few pictures.
I also tried changing "color space" from Srgb to AdobeRGB (rec>Color space), but looks like this has nothing to do with the color shift.
@yellowapple silly question: do you have i.Dynamic, i.Resolution, electronic shuter, Long Shtr NR and Shading Comp OFF?
I just did a quick (50 shots) TL - Gh3 firmware 1.1, pancake 20mm - all settings manual including the ones in my silly question.
SEEMS adobe camera raw/ lightroom colour shifts the files, pretty much like in your samples (I got shifts from green to magenta) and more visible when applying a 4 Ev boost. BUT, preliminarily, it also SEEMS an adobe issue; capture one, raw developer and even (open source) darktable don't render any of these colour shifts. my batteries are dead so right now not possible to further test TL.
m
@yellowapple Have you tried "Reset" in the Setup menu, or any other kinds of camera resets? (maybe there's something in the diagnostics menu?) Did the issue start with firmware 1.1 or did you notice it for 1.0 as well?
I have already done several tests inside with artificial light, and the issue happears just like outdoor. However, I think It can't be the clouds the reason for some photos to appear green/blue. Apparently there is no reason why color changes...
Do test only inside with artificial lighting. As outside all this can happen naturally due to clowds.
Another example of color shift with a RAW timelapse. The shooting interval is 1 second.
I have my camera updated with the last firmware (1.1) and the lens too are updater with the latest firmware. I have done around 10 different timelapse tests today and the issue is always there. I tried changing the interval with 2 seconds, I changed WB with the preset onces, I tried changing lens again, I tried using electronic shutter. Nothing changed. Some photos are blue/green compared to the others. It looks like (but I am not sure about this) that this happens when you you use quick shutter speed 1/50, 1/00 etc. If you want to do a test, you need to take a timelapse in a place with light and really underexposed objects at the same time (use black objects for the test). If you have this problem too, you will notice some green/blue shots, especially after increasing exposure for the darker/underexposed objects.
@yellowapple Also I Didn´t ask
Do you have the latest firmware installed? http://panasonic.jp/support/global/cs/dsc/download/fts/dl/gh3.html
And if are at it check the lenses also. http://panasonic.jp/support/global/cs/dsc/download/fts/index2.html
Folow the steps http://panasonic.jp/support/global/cs/dsc/download/fts/index.html
no need to upload, I can't do nothing by watching them.
Cheers
