The Definitive Hackintosh topic
  • 359 Replies sorted by
  • How the Hackintosh Suddenly Caught Fire
    Anarchy amid the abdication of Mac Pro
    By Mark Christiansen
    http://provideocoalition.com/mchristiansen/story/how-the-hackintosh-suddenly-caught-fire
  • @ninetto Thunderbolt working fine here on that board with various audio interfaces and monitors and drives so imagine should be fine
  • @soundgh2 @ninetto TB works but isn't hot swappable--that's not working "fine" to me but acceptable if you're just leaving a video card plugged in all the time.
  • There is that - but think that's not just a Hackintosh issue per se.
  • Oh really? I didn't know that. That's interesting. You're saying Mac TB ports are also not hot swappable? Because my older ASUS-based build was.
    I'm holding out hope that Gigabyte fixes this in a firmware update once/if Apple releases their new Mac Pros with similar support.
  • @ninetto For the record, although Nick and I both run an OC'd i7-3770K, my Hackintosh differs from Nick's in featuring a Gigabyte Z77-DS3H motherboard. Slightly different features (no Thunderbolt in mine, etc.) but same basic performance.
  • @jleo
    RE that inane provideocoalition article, a better title would be "In Which The Inexperienced, Tech-Unsavvy Author Lets An Air Quotes Friend Build Him An Air Quotes Work Computer With El Agua Pumping In And Out Of It, Almost Comically Bad Cable Layout Implying So Many Worrisome Things About The Builder I Don't Have Room Here To List Them All, And An Optical Drive So Ass-Cheap Its Power Supply Burns Up And Takes The Whole System Down With It". The article actually has almost nothing to do with Hackintosh and everything to do with why it's never a good idea to have a friend build you a work computer you plan to make the centerpiece of your livelihood.
    At the very least, I hope the takeaway here from the article is you should absolutely, positively not consider a Hackintosh unless YOU are the one who builds, maintains, and is ultimately responsible for its uptime.
  • Thats the fun part aint it :) No downtime here so far.
  • @soundGH2 I have two ML servers built around Z68 boards and i5 Sandy Bridges. They never go down. Most reliable servers I've used.
    I just want to make it clear that I build Hackintoshes for a variety of reasons - to own a higher performance Mac Pro than Apple currently offers at a fraction of the price, to deploy media servers and centers, and at home to provide family members with tiny and silent Mac workstations hanging off the back of the monitor. But I go into it fully accepting that I am where the buck stops if something goes wrong. I've been doing this long enough to not have this happen very often but the fact is OSX keeps evolving and you have to keep up with it. This is why it's folly to have someone build you a Hackintosh if you don't know how to design, build, and repair them yourself. It's not the same as building a Windows PC. The friend who builds you a Hackintosh today will not be your friend tomorrow when you've pestered him every time you run Software Update and ankle your rig again.
  • I know, Ive got 7 running now on the aforementioned Gigabyte TH boards that I put together, and I lose no sleep about them compared to my Mac Pros, and they're in frontline mixing suites working every day all day and never had a glitch yet.
  • @Shaveblog
    thought it might get a chuckle..
    I've had many phone calls in the wee hours from family members who clicked on Hack Killer button ( software update )...Now they have to buy the overpriced Realintoshes!
  • Buddy of mine wrote a neat little utility for unattended Hackintoshes out in the wild, to lock down Software Updates:
    No Update (see attachment)
    NoUpdate.zip
    154K
  • Thanks for No Update! That'll save a bundle of headaches. Now if I can get the family Hackusers to stop reinstalling Flash player...
  • The current apple software updates are playing nicely... Also using clover helps as its a true uefi boot loader- (can even see the recovery hdd).
    Currently clover is also the only way to get the ati7970 working without issues. Which is a beast for openCL, while 680 kind of took a downgrade in 10.8.3 due to correct reporting of core values. Unfortunately nvidia have sipped a bit.
  • @alcomposer I'm not as familiar with the Clover bootloader as I am with Chimera/Chameleon. I understand Clover is purportedly UEFI but what does this really bring in terms of advantages over Chameleon? I'm not dubious, I just don't seem to notice anything suboptimal about my installed base of Chimera builds that might be attributed to the bootloader. But as always I am open to new and better methods if they develop. Interested in what improvements you saw using Clover vs. Chimera.
  • Hey @Shaveblog,
    Well... during normal use you won't notice anything. However boot is faster, and you also get access to recovery HD.
    Basically its simply a way of using the built in system of UEFI inside supporting motherboards (ones that use UEFI- not BIOS) instead of having to use legacy boot.
    This is important when using graphics cards not supported officially by Chimera.
    Basically Clover installs onto the EFI partition of your HDD. I only mention it as its currently a very exciting way to make a very vanilla system- and currently it is developing very quickly- and most probably will become the default boot loader soon. (UEFI booting is the holy grail of Hackintosh anyway).
  • @alcomposer
    Very interesting. I don't follow the Hackintosh fora much but from what I gather from Google, there's a kind of nerd rage between Tonymac on the Chimera side and everyone else moving to Clover. I feel Tonymac did heroic work in consolidating a lot of disparate noise and dev chatter into one unified Hackintosh installer, and I owe much of my comfort level with this stuff to his site and guides. That said, if Clover does the job better and makes for an even more stable and vanilla OSX installation, I'm all for trying it. Any particular guides you recommend?
  • Ahhh Shaveblog, it sounds like you are falling victim to the "pockets of fringe tweakery" you debased earlier(! heehee).
    My creed: if it ain't broke don't fix it. AND, if you don't absolutely need the update, don't update. On a 8-yr-old laptop I am still running one of those "fake kernel distros" Tiger (10.4.11) by some Frenchman and still works like a charm since I just use the laptop for internet and subtitling.
    The new system I reported on (Gigybyte z77-up5-th) has just absolved its first heavy-duty edit with 60hrs of Canon 5d material without a hiccup. Color Correction with DaVinci Resolve, I ended up using a blackmagic Pci-x card for now, but am really curious to see if the USB 3 or thunderbird version of the Intensity-Pro line work with this system.
  • @ninetto Well, I don't know if the bootloader falls into the same category of secondary tweaks like SSDT. One you can't boot without, and the other is an add-on which even its proponents admit is mostly a cosmetic patch.
    If all Clover brings to the table is faster boot, then no, it's not worth it to me in terms of learning a whole new boot loader scheme with all its quirks, care and feeding. Chimera boots my Hackintoshes faster than any real Apple I've ever owned, so boot speed just isn't an issue for me, plus I rarely need to reboot anyway. But if Clover does bring true UEFI boot to Hackintosh, then there are significant reasons to investigate it as a Chameleon/Chimera replacement. Just making Hackintoshes more resistant to Software Update snafus would be reason enough to go Clover.
    In researching this over the past few days I feel Clover is more a work in progress at this point than a fully mature AIO installer like Chimera/MultiBeast, but there is impressive work being done and when it's ready for prime time I'll surely give it a try on a test system.
    Laptops I've given up on. Mostly because I'm iPad only these days when doing field work, by choice. But also because even when I'd get just the right combo of OSX-friendly laptop and all the right kexts, it still meant dealing with the inherent shitty experience of using an HP/Dell/etc. laptop. I know lots of guys own a single computer and it is a laptop but that's really no way to live and if you do live that way you're far closer to losing all your shit at any given moment due to any number of cost-cutting measures than you should be.
    Even when I did manage to align the stars and put OSX on a WinOEM laptop, the cheap construction, the inelegance of every parameter of design, the bendy creaky case, and just the overall dismal MTBF of Windows laptops permanently soured me on trying to find my perfect Hackintosh portable. Closest I came was an Acer a few years ago and even that was a POS compared to just spending a few hundred more and getting a refurb MacBook. I'm much happier on an iPad, and good riddance to laptops. I'll never buy another one as long as I can have a powerful OSX desktop in the studio and an iPad on the road. I've even done FCPX edits from the road using iTeleport to beam into my desktop.
  • jus curious for people who have hackintoshs on here what gpu do you guys use? I have the 650 ti 1gb and its fast jus want something better, ive been looking at the Gigabyte GTX 660 Ti SC 3GB is that a decent choice? it has almost as much cuda cores as 670-680. thanks for any advice.
  • My opinion is for video editing/color correction you are not really going to see that much difference between a 650ti and a 660ti.
    The jump in bandwidth would come with the 680 which has 2x as much. (256bit bus vs 192bit and an extra mem controller)
    Ohhhh, but just stumbled on this table at tonymac: http://www.tonymacx86.com/graphics/95703-nvidia-performance-benchmarks-10-8-3-geforce-gt-640-gtx-680-a.html
    which seems to show rather substansial differences, depending on brand and specific models of the cards you mention.
  • ok so the 680 it is, what 2gb or 4gb?
  • Depending on your needs you might find the previous GTX 5xx generation more performant, or the 680 being total overkill. That test on tonymac is with a game engine benchmark, doesn't say much about video editing (in case that's what you're after). Have a look here: http://www.personal-view.com/talks/discussion/3823/graphics-card-for-video-editing/p3
  • Answering your question, I have an EVGA GTX670 FTW 2GB. I didn't spend much time on selecting it. Needed something real quick after my GTX660ti started acting funky. It's been crunching my realtime openGL rendering in Max/MSP happily. The only game I've played so far is Need for Speed Shift 2 and it's butter smooth at 1920x1080 max quality (i7 2600k CPU). Haven't done any video editing with it yet.
    One of the considerations for taking this card is that it blows its hot air right out the back of the case. I have a compact mATX system so that's a plus.
  • @jclmedia I run an ATI HD5870 in my main video editing Hackintosh, as it's ideal for the apps I work with - FCPX and After Effects for the most part. It's plenty fast for what I do and with an aftermarket cooler it's all but silent. I've used Nvidia cards but I feel for a Hackintosh primarily doing FCPX, it's hard to significantly beat the HD5870 without spending silly money, and then you're dealing with more noise and lots more watts out of the wall.
    Apple coded FCPX for ATI GPUs at the high end and Intel HD3000/4000 integrated graphics at the consumer end, and this is what works best in my experience. Getting the very best from a high-end Nvidia GPU is still a bit of a crapshoot with a Hackintosh. Gaming performance and video production performance are not the same thing, and what you want to be looking at is Open_CL performance (Luxmark benchmark) not Open_GL (Heaven or whatever that elf village walkthru benchmark is called). It looks like Adobe is moving away from CUDA toward standard Open_CL as well so that's the benchmark you want to be looking at if you're building a machine to edit video.
