Any advantages to using a Micro Four Thirds lens (Panny, Olympus, etc) on an MFT camera over a lens made for a larger sensor via an adapter?
Main reasons to select active MFT are the possibility of lens corrections by the body and optical image stabilization. The advantage to use MFT in genral is the obviously fact you don't have to deal with an adapter, which has to be a good fit and will always increase the depth of your camera.
Well for me I can use gun and run with M43 lens, and stabilized too if you use pana body.
Thanks, specifically I mean is there an advantage in that these lens are specifically made for MFT cameras? Doesn't a MFT sensor use all of the glass on the lens, where it wouldn't on a full-frame lens?
