@flablo, I use 25 fps because I'm in a PAL region. I think the cadence problem may also be related to a variable shutter speed. Try using the M Video function and freeze the shutter speed. I found this cadence problem on other DSLR's when using the slider with automatic shutter speed.
@Conundrum not sure under which conditions the problem occurs. For sure the cadence become visible on the GH3 screen as soon as the scene becomes complex (more bitrate demanding): I clearly noticed during a pan how it became stuttering as soon as a certain part of the scene came into view. But if the stutter is only on screen, that wouldn't worry me too much. My main concern is, if the problem exist within the recorded files, the case in which it's not a basic GH3 issue but a failure related just to some units. In that case I'd need to know asap if my GH3 is faulty so that I could replace it.
And btw the video from where I extracted the clip contained also material shot on the Canon 1DC, and I didn't notice any problem on that ..
@Eno, did you notice the cadence problem on the GH3 screen, after hitting record, at least? Are you shooting 30p?
I have two GH3's and I cold not find any cadence problems at all. Maybe the files where not edited correctly. I made hand pans, slider pans and flayer pans, and no cadence problems on any of GH3's what so ever.
That looks truly terrible. It resembles what I was seeing when I had the camera. Have you tried converting to ProRes 422 and outputting to a TV via HDMI or playing the Quicktimes on a TV? Also, are you seeing the judder at 30fps - 60ss as well?
@jjj_ri_usa it was published by Vincent Laforet Visuals. The crew who shot the Freefly MoVi (hey I'm putting random caps) demo footage. I think this qualifies them as "prepared". Anyway it doesn't guarantee they could have made some mistake ...
I've not run into this issue on my GH3. I agree that the clip you posted on dropbox looks horrible. Who made it? It has a very odd frame size. 1920 x 1012 ? What's up with that? Maybe this mp4 was just encoded by someone who doesn't know how to use a NLE? :-)
I did the test on the MoVi footage and I got a different result, I think this clearly shows the stutter IS there. It's like every 3 frames going at a certain (constant) speed and then 1 frame going faster, then again 3-1-3-1-3-1-. And it's evident if you watch frame by frame. This is not a player issue ...
@Conundrum Totally agree. But if you search you'll find some people stated the stutter was gone when they made the final export (and playback) to BluRay, for example. But my mpeg export form Premiere didn't behave this way and the stutter was still there. Maybe the BluRay was progressive but encoded as 1080i (just guessing)?
@Vitaliy, yes I'm following that thread (I didn't post there because it was for GH2) and other related discussions, but from what I got the problem has not been really resolved, at least for GH3 (or al least shooting 30p isn't a feasible solution for me). I shot some footage last week and some pans came out really terrible, stuttering from the original clip to the final mpeg export ... so I'm trying to figure out what to do, or if, as some say, it could be a problem of "some" GH3s .... I downloaded the GH3-MoVi feature and some scenes looked really bad to me ... here a uploaded an extract, am I the only one seeing the hickup motion? https://www.dropbox.com/s/11iq015fabe6b2k/GH3-MOVI.mp4
Just look at the grass and the trees in the background . I think I'll try to do another tracking analysis on this footage ...
That's an interesting test and the results are encouraging. I'm just curious as to why we're seeing the stutter on a lot of Vimeo footage as well? That would seem to negate the demands made by the codec on the local CPU or GPU wouldn't it?
When recording 24p the camera's screen does seem to stutter; however, the clip plays back correctly in camera. This stutter doesn't happen in the HDMI output while recording.
I made a quick test to inspect the stutter/cadence problem. Basically I made a slow pan at different settings, of course the 50i was the smoothest (as it is interlaced), and trying the progressive modes I saw clear stutter as I pressed the record button. Heavier was on 24p and 24pIntra modes, judging by GH3 screen, it was definitely there. Then I looked at the same clips on my computer, stutter was definitely less but still present. It always seemed to me, looking at GH3 pans with stutter frame-by-frame, that the motion of object was "gulpy", as if every 3/4 frames of linear motion were interrupted by a frame where the motion was slightly interrupted and so on. So I took the clip (the 24p) into After Affects and tracked the motion, expecting to find this 3-1-3-1- motion discontinuity to shows in the results. Instead I found the tracked frames to be linear (see attached images for reference). Well, maybe this adds to the "player performance" theory, doesn't it? I'm somehow relieved by this result, as it seems to imply that the footage is correctly recorded, at least...
In my experience so far with the camera, GH3 has the next Issues:
The related video issues on this camera annoy me a lot. This little baby is extraordinary and a pain in the proverbial butt at the same time. I can not use it for video work except in full manual, or full IAuto (aka Idiot Auto) mode.
Maybe not a issue, but I cold not synchronize the time on two GH3 to work with them in Premiere pro.
Timecode Just checked on my UK GH3, when I try to input time code it is only allowing 24 fps, when I am recording 50fps, can others check this.... It appears to be only able to time code at 24fps
Just got my GH3 in. Has anyone found a way to view the manual exposure assistance meter while adjusting the iso with the dial or button?
used my gh3 with led for the first time at an event. an hour in and my hotshoe mount wants to fall off. bollox to pro-body. this is balls.
You can't use the flash when you have the electronic shutter enabled (just in case that's what you're missing)...
Anyone else having a problem with turning the flash back ON after setting it to off in the menus? The menu for turning the flash back on remains greyed out even though I've reset the camera and updated the firmware. Thanks, Kevin
@Arquer053 are you calling me colorist???!!! just kidding
@maxr Well I certainly could :) . However, I think my camera isn't representative of all since it looks like many issues from early batches didn't make it into mine from the late january batch (evf, flash firing when closed, loose hotshoe). For the wb shift, after testing through HDMI, I see it. It's not so much a wb shift, but a subtle gamma shift (however the camera's displays do change their balance slightly). Personally it doesn't bother me, but I know a few colorists who do find those things irritating. :)
@AdamT I see, could work in planned filming or stationary sets... I did a quick test: from presets (daylight, tungsten, etc.) the camera SEEMS to make a warm shift, also if you set manually the K or hue; while its "accurate" from custom (the one you shot) WB. thanks, let's keep building ;)
I find the colors on the rear monitor to be fairly accurate, while the EVF cannot be tuned to produce true reds and purples. Not a big problem for me as I always carry a gray card and set custom WB.
@Arquer053 but... now, tell me (laugh of the devil) are you remotely confident you can match them. I did try that but still a million pixels away from... accuracy nebula. thanks. my worst nightmare is the colour shift happening after record press. gashô
@maxr The EVF and the rear screen can be adjusted separatedly at the general settings menu.
