hi guys does anyone find absurdly mindfucking that the image showed on the back screen is far far from the "actual image" - where it switches - when we start recording. what the hell is going on with WB?!!! how are we supposed to manually fine tune WB when we are misled by the representation of recorded image?!!! did anyone find a way of colour matching EVF and rear display? could be mi-head working badly but this is a serious issue (for me). gashô
high-ranking officers at Panasonic and they can confirm that there is no technological limitation to prevent focus peaking to be added
This guys are very inconsistent :-) Btw, Pentax K-01 has good focus peaking :-)
Dunno if old news but:
Joe Fotosiamo from SLRLounge.com spoke to a couple of high-ranking officers at Panasonic and they can confirm that there is no technological limitation to prevent focus peaking to be added and that it is one of the features that are targeting to add in the next major firmware update.
Just wanted to finish up with my observations of GH3 audio matters. I also edited my previous comments deleting old information regarding audio levels.
The GH3's headphone volume can be adjusted of course but one has to go into the Setup menu instead of having it located next to Mic Level Disp. and Mic level Adj. which are located in the Motion Picture menu. This is certainly inconvenient.
Also, perhaps this has been mentioned before but the Headphone Sound (also located in Motion Picture) gives one the option to choose REALTIME or RECSOUND. REALTIME would be selected to minimize the audio delay from source to headphone but the fact is that even REALTIME has a delay and this is really annoying and although better than nothing, I find the headphone output of the GH3 very frustrating for critical monitoring say for positioning outboard mics where even a few inces difference will effect the tone of the recording. And monitoring live music while recording even when RECSOUND is chosen is not fun at all because of that delay. I wonder if this can be fixed in a firmware update?
So because of that delay problem on the GH3 headphones output, when using the Zoom H4N, I also used a custom Y cable adapter connected to the Zoom audio out so as to both feed the GH3 mic input and also monitor sound out of the Zoom. But this Y cable setup was actually part of my problem which during earlier sessions had caused excessive audio level readings on the GH3 - in order to drive my power hungry studio headphones and hear a nice full sound, I had to crank up the headphone/line output levels on the Zoom which required that the mic inputs be set to minimum on the GH3 and the Zoom. But this was a mistake on my part - I should have set good input levels on the Zoom and then turned down it's headphone Vol to feed the GH3 a perfect level. By switching to a more sensitive set of headphones I was able to lower the output of the Zoom feeding the GH3 and everything came into balance.
Not sure if anyone else has this issue... but i guess the others commenting on the hotshoe screws coming loose is similar. My flip out screen started to get "floppy" to the point that it had about an inch of free play. it sucked. im impatient, and didnt want to lose the camera for a month tho get it serviced, so i took the back apart and found that the screw that attaches the screens hinge had came completely loose. wasnt that bad of an operation, but disappointing.
@Lambo My 25mm f1.4 sounds like that when the camera makes an abrupt aperture change, but my 14-140 doesn't (well, its aperture mechanism is smaller). I'd even say this is normal when making relly fast changes, and Oly fans have been experiencing this with various Panasonic primes; however, my 25mm stopped sounding like that after I got ~150 shots through it except when changing like 4 stops really quickly. Perhaps the GH3 is driving your lens too fast?
@VicHarris I have no issue with my EVF also. I don't see the issue everyone is talking about. Must be some bad copies and some good. Glad I got a good copy I guess.
wtf is this ?
blumentopf March 3 @crowbar: You may want to try recording in MOV format, it records uncompressed audio so there should be no reduction in quality / no compression artefacts.
Hi blumentopf, yes I was recording in MOV format. There is no complaint in the audio quality as long as the meters of the GH3 are not going into the red. In my opinion this is strictly a matter of audio levels. Sorry if I an repeating myself but I believe that when using an outboard mic which also has pre-amplification built in such as the Rode Video Mic Pro set at +20dB, one has to be very careful to not overdrive the GH3 thus causing severe limiting. You cannot really tell how much limiting is taking place just by viewing the audio meters of the GH3. So in my opinion, at least with music recording, it is best to be conservative and try not to go into the red except maybe only a short blip here and there. What timfrakes says is excellent advice:
timfrakes March 4 @toxotis70, regarding audio levels, I simply make sure that I'm getting a good level, (3-4 bars) making certain that I'm not banging off the top end. Then, I forget about it. Adjustment take place in post. I find that you can always bump up a digital signal if necessary. You can't fix distortion.
My hotshoe also came loose, when I had a monitor attached to it. It doesn't seem to be secured well so I moved the monitor elsewhere and am only using lightweight shotgun mics on it.
Hotshoe is solid on mine, no issues. EVF is perfect also, very crisp. So no complaints.
@peternap Try a tablet or an eReader like a kindle?
The EVF on mine is excellent, I can pull accurate focus with it. I only had to adjust the diopter, and I don't have any sight problems. The hotshoe feels really solid; I've used the old Rode Videomic with no issues so far; nothing has come loose.
Not really an issue but it only came with the Basic manual. I hate reading manuals on the computer.
Farenheit, Sounds like your camera has the exact problem mine did, and similar frequency. Mine did it once when I first turned it on but also after it had been on for quite a while. I always disable sleep mode. My dealer said it sounded like a loose wire to him and they were a pleasure to work with--Unique Photo. If you send it to Pany I doubt it will be going to Europe with you... I hope your dealer exchanges it for you.
I'll speak up for my hotshoe. I knocked my camera off the back of an easy chair. It bounced off the seat cushion and landed on a hardwood floor. Mounted Rode video mic took the brunt of it and there was no damage to anything. Hotshoe still feels solid. Maybe that's the fix: mount something on your shoe and drop the camera on it. ;-)
Took my cover off mine I can't see any screws ,where are they located on the hotshoe hope mine don't fall off ,
Cool. Panasonic managed to fuck up in hotshoe department this time.
@collierlandry Yep, I have two Gh3s and both hotshoes are loose. The first has completely come off. Into warranty... Theyre pretty badly screwed from underneath if you slide off the cover of the hotshoe you'll notice the screws have either gone into the camera body or sheared off.
@h2otara Thanks, I'll reset to factory and hope for the best. It only occurred maybe a half dozen times over the course of 100+ operations and wasn't overly detracting from my enjoyment of the camera. The concern being that it increases in frequency. It's a relief to hear they gave you a replacement and didn't take your original unit for servicing. I'm heading to Europe in about a month's time and the last thing I need is Panasonic absconding with my travel cam if something's gone amiss.
Edit: Turned it on to do the reset and nothing happened (no green light). Half pressed the shutter button and it awoke as if from sleep mode: lens click, green light flashed on, OLED lit up.
Turned if off and on a further dozen times without issue, but on the next it turned on but went directly to sleep. Deactivated sleep mode in menu.
Seven attempts later it went directly to sleep upon start.
Reset factory defaults.
Tenth attempt it went directly to sleep. A half press made the lens click, but camera remained asleep. Another half press and it clicked again and awoke.
I'll contact my retailer tomorrow.
@ fahrenheit My brand new GH3 was randomly going to sleep as you describe yours doing, and I had "Sleep" turned off. I called the place I ordered it from and they took it back and sent me a new one as soon as they got one in. When I called Panasonic they said I might have some incompatible settings and wanted me to reset the cam. I recorded every setting I had, and immediately applied those settings to the new cam w/o any problems.
I've had an Australian PAL version now for about a week. A couple of times I've turned it on only to be met with a distinct lack of power (despite full battery). Turning it off and on again has it working fine.
Also on the odd occasion the power light has come on however the EVF/OLED have both remained blank. Half pressing the shutter a few times generally has it springing back to life within a moment or two.
the problem with EVF , reminds me another problem with DLP video projectors . Its called rainbow effect and some people are more sensitive to this than others.
I have GH3 also, and the only problem with EVF is, that if you look it off center is a little blurry. But thats not a real problem… you never have to look the evf this way!
@collierlandry Yes! Mine came loose on one side, and on next use it came off alltogether. I have now sent it in for a repair.
