Hi,
I own the GH2 with the 14-140mm Lumix lens, and I just started making films. I really like the 14-140mm, it has a very fast autofocus (for filming skateboard or whatever...), and when zoomed in it has a very nice DOF. But the problem is, it is way too sharp (even with sharpness at -2 and the Apocalypse Now DrewNet 'Soft' hack 444 matrix). I bought the GH2 thinking that it would have the same "Smooth" effect as the Canon T2i, 7D, 5D but with more resolution... because the GH2 IS a DLSR (or should I say DSLM). I know I could have this effect if I use non-panasonic or vintage lenses, but right know I own only the Lumix 14-140, and I'm not buying new lenses right now (or anamorphic adapters). The videos with those kit lens looks too much like a cheep Hi-rez camcorder and not like a DSLR or Cinematic or RED video... I know, I know, I should use a short DOF, reduce everything to -2... bla bla bla... But the 14-140 is still too sharp. It maybe even look a tad better on the GH1...
Now is there any type of HACK made especially for that type of lens, or any HACK that really softens the image down (canon-like) without a big loss of quality ?
I've already tried "soft" hacks (apocalypse now...etc), but it doesn't change anything, the edges are still too rough and sharp.
(And yes, I like parkour)
I know that there are already some posts that are about the same, but none of them really helps me.
Please help me !
Harvey.
I did some tests with 14-45. I had the same problem on any hack, tried every suggestion from your posts, without any satisfactory results, i also switched features such as OIS on and off with no satisfactory effect. But when i switched AF off, i noticed dramatic improvement, jaggies almost completely gone. I guess that is why some guys don't have any problems, cause they don't use AF at all, or they use non Panny lenses which has the same effect.
Honestly, I just throw on my Polaroid variable ND filter and it softens the image right up. Not something you normally want, but it works fine as I use vintage primes indoors, and the 14-140 with the variable ND outdoors. That somewhat rare occasion where I need super shallow depth of field outdoors, I have a .9 and 1.2 ND filter that I can attach and it softens the image less.
Not sure a "Pro Camera" is the right statement there. You can do that in post without destroying the footage like you did in RGB. All you have to do is throw on an overlay, invert the colors and bring down the level.
Hey everyone, I think I've found a way to get the effect I wanted, I've found this software called '5D2RGB', and once I've made the conversion, it looks exactly like a Canon or a Pro Camera :
http://www.cameravideo.net/forum/faire-de-video-cinema-un-apn/18716-gh2-and-contraste.html
( Scribble is my cat's name :D )
+1. You can pick up a canon fd 50mm f1.4 and a ciceo7 fd to m4/3 adapter for buttons,relatively speaking.
I also recommend trying a different lens. The 14-140 is a solid outdoor lens, but it would not be my first choice for video unless you are shooting outdoors and you want sharp telephoto stopped down. Indoors, it just is a tad slow and for some reason likes to be outside better. For the price of a filter, you can pick up a nice legacy prime.
Sorry, but I'm totally ignorant about filters, and I know nothing of them. Could someone please explain me what different types of filters exist and which one to choose for which scene, as well as explaining me what is the unity used : 1/8, 1/2... and what do there correspond to ? Thank you
Be aware though that softening filters will reduce your recording bitrate.
Which is exactly what you want, when the bitrate is recording details, including aliasing, you don't want to see. Black Diffusion filters, in particular, are quite mild -- at the low end, from 1/8th to 1, you'll need to look hard to see the effect of any unintended softening. These are not "glimmerglow" type filters.
I disagree, 14-140 is a fantastic lens, especially for video. Well, in some cases anyway :) To be honest, probably because it's a 10x zoom, imho it lacks sharpness for photos but it's great for filming when there's plenty of light! Combine it with the soft apocalypse patch and there you go! Regarding the film look in the romanfilms example: guys, it all about lighting and environment! He filmed it in beautiful golden hour lighting, very low contrast environment, there's tons of flaring going on and lots of slightly out of focus shots! Granted sigma 30mm is a great lens, but I'm sure that if he used 14-140 back then, he'd got pretty similiar results. Avoid harsh, high contrast lighting and environments with lots of diagonal fine lines that amplify aliasing issues. Also, you may want to shoot it in 720p and uprez to 1080p. Sharpness problem solved! ;)
Don`t forget, that gh2 makes software optical correction and sharpening for Lumix G Vario lenses
Romanlegionfilms - uses Filmconvert as part of his grading chain, I believe, so you should try the demo out :)
It certainly goes a long way to adding some character and grit, based on my tests with the demo. Removes that squeaky clean digital look
@vicharris I like your point. Really the 14-140mm gives a very videoy image in my opinion no matter what you do to it. It's a very good modern lens for shooting stills with, not so much for video. It's also very slow and this is what gives is a sharp feel because you are already at f4.0 before you even start. I prefer to use my Canon FD's as they just look nicer to my eye. I also have the .95 25mm Voigtlander which is just beautiful and really gives a very filmic look.
I'd also say that autofocus is certainly not "filmic". All these factors contribute to the look and so you need to minimise all auto when trying to create a film like image.
Using Driftwood's Sedna AQ20 C settings (these use Orion as a starting point but with softer matrix detail) takes the edge off the Panasonic lenses IMO.
http://www.personal-view.com/talks/discussion/2477/driftwood-quantum-x-settings-series-2-sedna-a-b-c/p1.
Whilst the choice of glass is very important for the look, the filmconvert plugin for after effects is certainly worth a try (there is a free demo with watermark) http://www.filmconvert.com/ the way that the grain is applied, produces a nice look to even the sharpest of lenses to my eye.
Good luck, I prefer a softer look and have explored a little, so I am interested to see your findings, so please do report back, thanks :)
Matt
So you want a camera that shoots soft. You bought the wrong camera.
A 1/2 or 1 Tiffen Black Diffusion filter will take the edge off the sharpening, without introducing a lot of other artifacts. Some people recommend a 2 or a 3, but that's far too much softening to my eye.
The footage still won't look like film, if that's what you're after. But it's much less likely to be objectionably sharp.
Here is one source for the AA filters, they work really well, and they of course also take the edge off ever so slightly, but to get exactly the look you want you would need to try them out. However, I would just try a basic Tiffen Soft FX or whatever is the lightest filter you can find. http://caprockdev.com/antimoire.htm
You should read Barry's recommendations if you want to try the Caprocks, I would still try the Tiffen's first since they are a cheap eBay item. http://www.dvxuser.com/V6/showthread.php?200980-Caprock-Anti-Moire-Filters-Tested-on-the-7D
Thank you uninexus, the effect that's looked for is the smooth Canon video effect but with the 14-140mm lens on the GH2 (in 24p), that "romanlegionfilms" achieved on his GH2
Instead of the "cheap camcorder-like effect" you get when using the Lumix 14-140mm lens.
I have used both Helios 44-2 and Minolta 1.7 and love the lenses. As far as 14-140 - I try to use it outside in decent light with 1/50 shutter speed at 160 ISO. I will gladly contribute to tests if I know what to look for exactly ?
Excuse me, but what is exactly rock glass and where can I find some ?
Just use a soft filter. They come in all grades from barely noticeable to ermine. If you want to get really fancy, use a piece of rock glass which will also remove any aliasing at the same time. Aliasing is a problem in skateboard vids when you have angled concrete surfaces, for example.
I think I've found what I'm looking for :
I came accross this topic on DVXuser : http://www.dvxuser.com/V6/archive/index.php/t-232116.html
Which showed what happened with the 14-140 lens at 720p and a bit of color correction :
And I've found someone on youtube which his videos are exactly what I was looking for :
http://www.youtube.com/user/romanlegionfilms
Apparently, the best thing I have to do for what I want is this :
Flowmotion and Quantum 9vb look like the best to me.
But the best option would be fast lens and that are NOT panasonic, and the best I've found are (cheapest) :
FlowMotion with Sigma 30mm :
Quantum 9vb with Sigma 30mm :
Panasonic lenses :
And about the 14-140, a LA7200 Anamorphic adapter looks incredible, but the price too is incredibly high.
Any anamorphic adapter with the 14-140 looks oustandingly amazing ! (See by yourself by looking for videos of them on youtube or vimeo) But it's definitley out of price range, otherwise, I would have taken it for sure !
The problem with the 14-140mm is it actually steps up a level in bitrate as soon as you go beyond 50mm. Instability begins at 70mm all the way to 140mm (especially handheld) almost as if there is something wrong with the lens firmware. Its a real battle to tame in 1080i and 720p modes and hence why it has become the defacto testing lens.
I shoot at 24p and 1/50, and I don't use any filter. But for fast action : 30p at 1/125 And for slow motion : 60p at 1/500 or 1/1000
