Change the ballasts out - get high frequency ballasts. You'll probably have to order them in through your lamp supplier.
Every gaffer I have met carries a box of 50 ballasts and 50 tubes at 3200 and 50 at 5500, specifically for changing out practicals on location. They've been available since at least 1986.
In my experience, shooting 24p with 1/50 shutter here in 50hz land doesn't remove flickering completely. I mean, flickering isn't there, but there is some sort of moving banding going slowly from top to bottom. It's very faint, but it's there. I shot using 25fps HBR and got rid of it, but although 25fps are OK with me the halved resolution HBR gives isn't. Hopefully the GH3 will be my savior in these situations! @azza_act I guess you can do that with no harm but having a little more motion blur than is desired, but will be no worse than using a 1/40 shutter, I think.
I thinking of getting a NTSC GH3 (I live in Aus) Will shooting 60p at 1/100 for slow-mo going to be an issue? Or should I wait for the PAL version.
