Official Final Cut X topic, moving to ARM and vlogging
  • 405 Replies sorted by
  • @kellar42: exposure and saturation are no problem. It's adjusting hue that is so painful. I have to figure it out from scratch each time.
    @parktraveling: +1 on the scopes.
  • I really like the color board too. It's actually a pretty intuitive interface. The scopes in FCPX are beautiful.
  • @CurtisMack I like plugins for several things grading related (and actually someone just released an interesting $99 plugin for FXFactory that gives you a full screen interface with color wheels that looks amazing) but, I have to say, the Color Board works very quickly for certain changes or touch ups. I don't get everyone's problem with it!
  • @stonebat - +1 about the color correction interface. Pucks suck. There are plug-ins that ease the pain, but Apple needs to redo it and provide better API's for plug-in developers, since all they get now is horizontal sliders. But I love the non-layer interface. I hate those training videos where they say, "It's just like Photoshop, it has layers." That whole Adobe way is a major time sink. After all, in FCPX you can stack corrections in the inspector, which approximates the layer thing. I tried color corrections in AE and I had to view a training video before I could do the simplest thing. Even the trainer commented that it seems you could just drag and drop the correction to your clip, but you can't. First you have to create a new layer and apply the correction to it. I like separate control of RGB and the gamma curve. But underneath, each interface is simply changing a number somewhere in code, a number limited by the clip's codec. Apple is apparently doing quite well now after several free upgrades. You can tell because there are hundreds of plug-ins. If FCPX were not doing well, the ecosystem would suffer, and it appears to be healthy. I got into this game right before FCPX came out, and I tried all the editors - Vegas was almost OK, but it only runs on Windows, which breaks the deal for me. When I tried FCPX, it became clear that the developers thought about this from the point of view of someone who had never used an NLE before, like me. Simple, straightforward, no wasted motion. It has a database built in, as well. No need to fire up Filemaker and export XML to know what you have.
  • @ahbleza-
    Thanks.
    The blem is in the middle of flesh, so it wouldn't be hard to match the tone.
    But she's modeling, i.e., twisting, throwing her head, etc.
    Any more hints?
    RBD
  • @RBD It all depends how much relative movement there is, and how many frames. Just last week I shot a music video, and one of the models asked me to "airbrush" away her double chin.... the difficult I do immediately, the impossible takes a little longer.... :-)
  • I have some really great footage of a model working, but she has a sizable scab on her chest from a skateboard accident.
    Can I remove this with FCP X?
    Will Motion be better?
    Is there any other reasonably priced software that might help me do this easily?
    TIA
    RBD
  • After using iMovie app for iPhone, I'm done with Apple editor. Since iTunes disabled a way to copy files into iPhone, I had to use DropBox app to copy footages. Yeah I had tried FCPX, too. Using 3rd party plug-in or Motion for using layers really sux. The weird looking color grading box... arrrrgggg. Sometimes I wonder if Apple is serious about this competitive market.
  • That's one expensive mouse to control FCPX.
  • I think there's a hack to get around that (yes - annoying that it must be a hack, but it apparently works) - make up some blank quicktime movies of your desired resolutions and frame rates and put them in an event. Then make a new project with the video format set to conform to the first media dropped in. Drop in one of those blank movies to start the project, then I assume you can remove it after you have at least one other clip in the project. Have not really tried this myself, but have heard it works.
  • there is another problem in fcp which is cinemascope 2k 4k supports. we can only set a project upto 2:1 which is 2048x1024 but for theaters we need 2048x858 which is 2.39:1. these settings are must for a NLE. more over custom frame rates is also essential. custom resolution & custom frame rate projects settings can bring more flexibility. FCP X lacks in broad project selections.
  • I think the adjustment layer thing is just a side effect of the way title objects work in FCPX - not really an intended feature. I too was quite hopeful and eventually let down when I first heard about them.
  • So, they lied. On the internet no less. Pitchforks, anyone? I've already got some torches :-)
  • Lame. The adjustment layer doesn't operate anything like Adjustment layers in AE, PP, Photoshop, or SpeedGrade. You can't adjust the opacity of the layer. If you lower the opacity it lowers the opacity of everything below it.
    It's really just an easy way of applying a correction or effect across the board in one stroke without copying and pasting attributes.
  • @shian hopefully they'll add that too. Gotta hand it to 'em, they keep adding stuff here and there.
  • @stonebat Premiere has adjustment layers built in. I find it very usefull for applying global effects and corrections
  • finally! Now they need to allow LUT importation, and my journey toward the dark side will be complete.
  • Had to do some digging to find the Conan sketch, since it was referenced so much Putting it here.
  • The only thing keeping me from buying it is that it doesn't easily export to audio programs. Hopefully Logic X is not too far off and they can communicate properly with each other. For what I do, I don't need powerful VFX or anything. FCX is already amazing for editing and integrates nicely into Resolve for grading. It really just needs audio and I'm set.
  • I'm very happy with FCPX, and it looks like the product is getting more industry acceptance.
    http://daredreamermag.com/2013/01/14/could-final-cut-pro-x-be-the-nle-of-the-future/
    Here is a review that thinks it's getting better, from a very experienced editor. This is part 1 of 3, but he summarizes his key points as follows:
    I do think FCPX could be the NLE of the future. There are three main reasons:
    Power. Despite the fact it’s called FCP X (X as in 10) it’s really more like a 1.x version. considering everything it can already do as a 1.x version (now officially, a 1.7 as of this writing), it can only get better from here.
    Proliferation. Specifically the proliferation of 3rd party developers. They are springing up everywhere, giving creatives more options and flexibility (and power) in their editing. As more developers come online, that will mean more people talking and marketing it.
    Price. At only $299 expect more first-time, student and indie filmmakers turning to FCPX. Think about it. It pretty much can do all the essential tasks the old FCP did, but at a third the price. That’s huge. More and more small Mac-based producers like me looking for editing help will find that a majority of applicants will be FCPX users.
  • No issues with importing footage longer than 1 hour (or any issues with FCPX 10.0.6): Cluster v7 'Apocalypse Now- DREWnet' 12-15 GOP Sharp
  • 10.0.7:
    I can report that it nearly imports hacked GH2 clips. I've imported about 20 clips with a 40% success rate.
    The ones that fail say 'There has been an error' but display with a camera symbol on the bottom LHS. You can use these to synchronise clips but if you use Lock and Load it will claim that you need to apply it to a clip in the timeline (which of course is just what you did).
