Many thanks for using my settings! :-)
Since it depends on your liking which you finally choose, please try newest Valkyrie 444 TZ2 BETA2, Valkyrie CS TZ2 BETA3, and GOLGOP3-13-MAX2 or A2 BETA5, respectively.
Next GOLGOP3-13 which I am improving now is certainly better than BETA5 in FSH. Therefore, you try GOLGOP3-13 BETA6, after it is released.
I know driftwood settings are top-notch in 24p modes. But now i need a setting that is superior in FSH Mode. So, if i understood it correctly: When i want to shoot solely in FSH/HBR, "Valkyrie 444 TYPE-ZERO2_BETA2" should be the better choice for me.
I would like to have a setting with the best possible picture quality and the highest bitrate in FSH Mode - spanning is not so important to me in this case. I need a setting whith a matrix that does not delete information in FSH Mode !
Many thanks in advance for your recommendation.
Thanks for using my settings! :-)
what's the differences between "Spizz" and the "Valkyrie"
The type of the matrix adopted in each recording mode is different.
If I say simply ...
In 24p, Valkyrie and Spizz are very alike. These matrices are based on the concept which does not delete the amount of information as much as possible. Although there is a difference also in 24p, of course, it is a matrix of the same system.
In recording modes other than 24p, a difference is clear.
In Valkyrie, the matrix which does not delete information as much as possible as well as 24p is adopted.
On the other hand, the matrix which deletes information to some extent is adopted so that it may be easy to compress in Spizz, and it is an image like a hybrid.
Since Nick @driftwood designed the foundations of the matrix of Spizz, I am not sure about an exact reason, but I think that the reason for changing the concept for every recording mode is because the bit rate which can probably be treated in recording modes other than 24p is low.
Of course, it is dependent on your liking which is chosen.
Thanks always mate! :-)
New Valkyrie looks better quality than previous versions as we expect.
For non-technicals like me :) I use a lot Valkyrie 444, and I was wondering what's the differences between "Spizz" and the "Valkyrie" series?
I used "Valkyrie 444 TYPE-ZERO2_BETA2" HBR(30p) mode.
Thanks for amazing quality settings and your hard work!!
*FILM MODE is NOS.(-2,0,+1,-2) and the lens is LUMIX G X VARIO 12-35mm
*SANDISK Extreme Pro SDXC UHS-I (95MB/s) 64GB
In HBR and 720p of new Valkyries, I think that the bit rate and frame size in the time of general shooting increase certainly rather than the previous BETA versions.
Of course, reliability is a record level simultaneously, I think. :-)
NEW!
bkmcwd Valkyrie Cinema Smooth TYPE-ZERO2_BETA3 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix' and 'Modified Cinema Smooth Matrix' - setb.ini - Released 15/02/2013
This is the version which adjusted safer from TYPE-ZERO2_BETA2 in HBR and 720p.
And I adopted 3GOP as 720/50p, and adopted 6GOP as 720/60p this time.
IMO, this BETA is most stable and most reliable in Valkyrie series now.
I think that the freezing issue at the moment of the focusing and zooming was solved nearly perfectly also in Panny lens use.
Please try it! And I am very glad if I can get feedbacks from you.
*If this is also still unstable, I will further adjust.
Special thanks to @har_k, @towi and All silent users of my settings! :-)
Of course, many thanks to @cbrandin and KING @driftwood!
*There is no change from previous versions in 24p.
Superb-looking Pure Original Cinema Smooth matrix from cbrandin is adopted in 24p mode
Modified Cinema Smooth matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
Upto 75M for Top Quality 720/50p modes
Upto 60M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them (Take care only in 720/60p)
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p, 1080i and 720/50p
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.
                  NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2_BETA2 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - seta.ini - Released 15/02/2013
This is the version which adjusted safer from TYPE-ZERO2_Candidate1.5e in HBR and 720p.
Superb-looking Pure Original 444 matrix from cbrandin is adopted in 24p mode
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
                  I almost completed new Valkyrie 444 TZ2 and Valkyrie Cinema Smooth TZ2.
We are just going to do the last check now. If they pass these tests, I will release them soon. :-)
About the matrix, it has not been changed in this improvement. In Valkyrie TZ2, I am going to adopt the pure original matrix of Chris as much as possible.
About Spizz, since it is a domain of Nick, I may adopt his matrix positively.
I have already made the plan also about improvement next to Spizz.
@bkmcwd: thank you, looking forward to the new settings! I already enjoy Valkyrie now and am looking forward to improvements that include the new knowledge of the moon matrices.
I already released Spizz of the improved version. Please try it and give me feedbacks. :-)
http://www.personal-view.com/talks/discussion/comment/106865#Comment_106865
And I am working on Valkyries now. The know-how in Spizz is also poured into these. They become settings certainly better than the former BETA versions.
Please offer, if there are those who do the test by the side of PAL.
I begin to improve "Spizz", from now on. :-)
@ GOLGOP3-13 lovers :-)
"GOLGOP3-13-A2_BETA5" and "GOLGOP3-13-MAX2_BETA5"
I release the new "GOLGOP3-13-A2" and "GOLGOP3-13-MAX2" settings.
All of these matrices are the same as before. The main changed parts are having realized Freeze-les and high-bitrate in HBR and 720p.
In BETA5, as a result of taking care about how depending on which especially a buffer appears and improving, in all the modes, spanning became possible mostly.
*These have passed the continuation zooming test for 3 minutes or more.
*Please try them! And many thanks for feedbacks from you!
*If these are also still unstable, I will further adjust.
Special thanks to @har_k, @ojiko, @syoushow, @Mrhechang, @Shon, @spreeni, @kankala, @abraham1307, @jul and @towi!
And especially thanks to Nick @driftwood. :-)
NOTE:
*Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 120M in 24p, about 75M in HBR, about 65M in 720/50p, about 60M in 720/60p.)
*'MAX' version and 'A' version are completely the same except 24p.
*The original matrix is adopted in the newest GOLGOP3-13s. It is the middle of a Sedna matrix and a stock character. If I say plainly, it will be the Sedna matrix optimized in 3GOP structure.
*24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A2.
*24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX2.
*24p80%(30p) is available in 24H & 24L both.
*60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
*720/50p is 6GOP and 720/60p is 9GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
*In camera playback is available in all rec mode except 24p in GOLGOP3-13-MAX2, at least available after reboot the camera.(Not tested full yet, but probably)
*EX Tele, iA mode work.(Not tested full yet, but probably)
*If you will use "iA" in 720/60p, I recommend you use "H" mode.(In other modes, there is no problem with iA)
*Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. Also in other rec mode, almost available.
                  In which way will you improve valkyrie?
Also in Valkyrie, I am going to try the improvement performed in HBR of GOLGOP3-13 released tomorrow for high-bit rate & stability.
However, since the matrix of Valkyrie is very peaky, I am not sure whether it goes well in a similar manner.
Anyway, improvement of Valkyrie is on the schedule after touching Spizz. :-)
@bkmcwd, cheers for your efforts. In which way will you improve valkyrie? Thank you
I am going to release new GOLGOP3-13s tomorrow. And, I will touch "Spizz" after the release. And furthermore, I am going to readjust Valkyries to after that. About improvement of GOP3ZILLA, it is made after improvement of Valkyries.
Thanks for all your feedbacks! :-)
Thanks always for COOL footage! :-)
Now, since I am very busy with the work for my life, the verification work of New GOLGOP3-13 does not progress easily.
However, I think that a test version can be again passed to testers during this week.
This must be a setting better than old versions. I am interested also about the possibility of span in this setting. Please cooperate with the test again.
I am going to improve "Spizz" of Nick after the release of this GOLGOP3-13. :-)
Although I began to improve Spizz, improvement of GOLGOP3-13 is also under continuation simultaneously.
Since it is very difficult to clear the test which continues zooming 3 minutes or more, improvement of GOLGOP3-13 has also taken time.
However, probably, it is releasable in a few days, since it has almost completed. :-)
This is what I shot today. The Gh2 has officially blown my mind
                  Thanks for trying Valkyries and your feedback! :-)
Although these are not the same composition at all, it is very interesting that a difference can be seen.
