Hacked GH2 reset problem
  • After hacking my new GH2 with the flow motion 2.02, which works great by the way, I discovered that when I remove the battery and replace it, All my setting go back to the factory setting including that annoying beep.How can I replace the battery with out the hassel of resetting the camera each time?
  • 4 Replies sorted by
  • Ah, I see. Thanks.
  • He means reapplying the hack.
  • Thanks for your answer. What do you mean by reflashing?
  • It shouldn't do that. Turn the camera off before removing the battery. Try menu, setup, reset. Try reflashing.
