After hacking my new GH2 with the flow motion 2.02, which works great by the way, I discovered that when I remove the battery and replace it, All my setting go back to the factory setting including that annoying beep.How can I replace the battery with out the hassel of resetting the camera each time?
It shouldn't do that. Turn the camera off before removing the battery. Try menu, setup, reset. Try reflashing.
Thanks for your answer. What do you mean by reflashing?
He means reapplying the hack.
Ah, I see. Thanks.
