PTool v3.62d topic
  • 327 Replies sorted by
  • loaded 3.62 1080 24- 42/32 , 1080i- 32/24, gop 6, quantizer 1: some to detail . No more blip first second. Yeah.
  • Wow, already released for us newb! :D Thx Vitally, cbrandin (and strike teams!)
  • 24H and 24L are set to the same values as FSH and SH.
    (first setting file 32/24, second setting file 24/18).
    If i now flash the first firmware and record a movie in 1080i 24Mbit FH, then flash the second one and record with 24Mbit FSH, is there a difference in quality?
  • @swen24
    First. Read hints. You need to have 24H checked. Always, if you use any bitrate patches.
    Other patches won't be applied if 24H is unchecked.
    Second, that exactly "first setting FSH 32MBit/FH 24MBit and second setting FSH 24MBit/FH 18MBit" mean?
  • If i have two different setting files for bitrate in Ptool 3.62, like first setting FSH 32MBit/FH 24MBit and second setting FSH 24MBit/FH 18MBit, nothing else checked but AutoQuantizer Mode 2.
    Is then FH 24MBit exactly the same output quality as FSH 24MBit?
  • >Yes that's what I meant, so '0 - All to Motion' is the same as unchecked
    Yep.
  • Yes that's what I meant, so '0 - All to Motion' is the same as unchecked.
  • >What is the unmodified/default Auto Quantizer setting?
    What do you mean?
    If you leave it unchecked?
    Bitrate will go to motion, as in 3.61D.
  • What is the unmodified/default Auto Quantizer setting?
  • >do exist a page where you describe how the hacked gh2 should look like?
    Do you mean big black and hairy tail that you see after the hack?
    It is normal.
    Ears usually require a week of active patching.
  • thanks a lot Vitaliy!!
  • >anything in the works to let us use aftermarket batteries with an indicator?
    No.
  • anything in the works to let us use aftermarket batteries with an indicator?
  • Nice! Keep up the great work
  • Great, thank you for the hard work!
  • Great news! Thanks Vitaliy
  • PTool v3.62d released to public, see first post for links and info.
  • >Does 3.62 mean that every model below GH2 is forgotten already?
    No. This means that they have different encoder.
  • Does 3.62 mean that every model below GH2 is forgotten already?
  • >Vitaliy, when 3.62 upgrade will be available for ''ordinary' user like me?
    As soon as initial testing phase will be completed.
  • Vitaliy, when 3.62 upgrade will be available for ''ordinary' user like me?
  • How about higher resolutions than 1920x1080 in MJPEG mode ? How far can we go ? It would be wery usefull to have some stabilization and framing correction space around a 1920x1080 crop.
  • @rigs
    VK has mentioned before that the GH2 is very different in its AVCHD (which is were most of the work is now).
    I have a feeling not much, (possibly the PTool Software?)
  • Im not worried about clean hdmi out but will this version give us working etc with monitor out
  • Will any of the new ptool features be available for GH1 or are they just for the GH2
